Chain sharpening
Discussion in 'The Wood Pile' started by Grahamt, May 2, 2018.
  1. JCMC
    JCMC
    Just outside of Shushan, NY
    Get yourself a Granberg G-106B. I've had mine for years still works well.
  2. BigPapi
    BigPapi
    The hills of Western MA
    I have learned that the key to hand filling is to touch up the chain often so the cutters stay sharp. A couple passes with the file every tank or two of fuel will keep things sharp and in proper geometry longer. I'll knock the rakers back very half dozen touch ups or so.
    When I've exhausted my abilities using this method I can usually tell because my cuts don't want to go straight any more. At that point I bring my chains to the saw shop and have them get everything cut down on a grinder. I have purchased a cheap grinder to try my hand, but haven't set it up yet. Maybe this winter when I'm itching to do something firewood related besides load the boiler. :)
  3. Erik B
    Erik B
    Western Wisconsin
    I have found the Stihl 2 in 1 works well for me. It sharpens the cutter and lowers the raker at the same time.
  4. mirnldi
    mirnldi
    I just had this problem last weekend. Got a brand new chain a little dirty. Hand filed and it was cutting C’s real bad. So I filed one side until it was cutting straight again.
  5. concretegrazer
    concretegrazer
    Southwest MO
  6. Sourwood
    Sourwood
    Popcorn, IN
    I can’t seem to get the knack either. Have the Pferd most recently, still can’t G.T. it right. I can make them last a bit with the round file, but my best success is to have two or three chains and have them sharpened at the shop.
    I can keep them going a while with the round file, so it’s not like I take them in all the time. When a big tree is down and I can get it cut into rounds in half the time, it’s worth the money. I save so much burning wood my ROI makes it a no-brainer to spent for good equipment.
    Marvin, brenndatomu, milleo and 6 others like this.
  7. Grahamt
    Grahamt
    Leeds
    A toothpick to you lot
    Sthil 170
  8. Grahamt
    Grahamt
    Leeds
    Thanks
  9. Grahamt
    Grahamt
    Leeds
    582D985B-3A5E-4B56-B9F2-5155EF6E1E6C.jpeg 6CAA21EC-9E17-4D78-AD5B-FBE9844184AA.jpeg Note to self .
    IDIOT YOU KILLED THE ANGLES . Angle file ,tight chain,vice and glasses . Only brought three teeth back in line so far
  10. Grahamt
    Grahamt
    Leeds
    63763688-33CB-44D0-BB5D-636516EDB0D6.jpeg 0061E4EB-642C-4934-BC1C-88F0637B0498.jpeg I’ll officially embarrass myself.
    48 strokes to pull this one tooth to 30 degrees.
    Chains probably goosed and I’ll have to do the other side to bring it back to been equal
    Hopefully I’ll stop some other newbie making the same mitsske
    Ok you can laugh or cry now
    Marvin, brenndatomu, milleo and 7 others like this.
  11. Maina
    Maina
    That’s a lot of filing graham. At least you got it figured out. I’d clean the filings off the chain before using it with that many.
  12. Grahamt
    Grahamt
    Leeds
    It’s getting airline on it all while I have it at work on the bench
  13. Grahamt
    Grahamt
    Leeds
    Based on Day that files had its in the bin
  14. Grahamt
    Grahamt
    Leeds
    ECBECE94-11A4-450C-9A58-9AE222373270.jpeg Long time since I had actuall wood chips . How did I not notice sooner
    Marvin, brenndatomu, milleo and 9 others like this.
  15. clemsonfor
    Your file is shot if you had to file 1 tooth 48 times o_O
  16. clemsonfor
    So sounds like you got it?
  17. clemsonfor
    I ask cause I was going to tell you what chain it runs.
    That saw is probably running 3/8 low pro.
  18. Grahamt
    Grahamt
    Leeds
    Spot on
    Backwoods Savage and Maina like this.
  19. Grahamt
    Grahamt
    Leeds
    Eventually , thanks everyone
  20. Grahamt
    Grahamt
    Leeds
    Look at pics of how bad I had previously unsharpened it, this ones half done
