Septic system saga
Discussion in 'The DIY Room' started by basod, May 1, 2018.
  1. basod
    basod
    Mount Cheaha AL
    This started thanks to a thread from 2015 by papadave. I decided to do a maintenance pump, and after trying to find the tank found that most of it was under a 21x16' deck less than 4" off the ground. I managed to hand dig 1 of the end lids and upon opening pumper guy said the system definitely wasn't working. Mind you that was likely the first pump in 35yrs on this tank.
    Now I've removed the deck and taken down a huge oak so prior to deck rebuild want to make sure everything is in order before rebuilding.
    This time around it's a bit easier digging
    Maina, WeldrDave, yooperdave and 12 others like this.
  2. basod
    basod
    Mount Cheaha AL
    I lifted that far lid after no luck in finding an outlet pipe. There is a black funnel shaped piece on the far end that goes down 18".
    Happy to report the tank is not slap full like before it's a good 6-7" below the lids.
  3. milleo
    milleo
    Total bummer it was under the deck...:hair:
    Maina, yooperdave, Eric VW and 4 others like this.
  4. basod
    basod
    Mount Cheaha AL
    Deck needed rebuild anyways, pretty good sag from center posts rotting off and the oak tree had grown into it and shifted it 2-3" out of plumb.
    Maina, savemoney, brenndatomu and 5 others like this.
  5. milleo
    milleo
    Lol...Kill 2 birds with one stone...:)
    Maina, savemoney, brenndatomu and 6 others like this.
  6. basod
    basod
    Mount Cheaha AL
    Plus the spigot under the deck leaks and had no way to be removed.
    4" frost free faucets should be here this week
    Always need 6-8 things going on at once otherwise I'd be sane and sober. image.jpg
  7. wildwest
    Are you replacing the tank, or field, or the deck only (with better access for pumping if needed?)
    Yummy septic tank :hair:
  8. milleo
    milleo
  9. basod
    basod
    Mount Cheaha AL
    I plan on adding risers and hopefully determine condition/construction of the leach field.
    The tank is really going to cut into deck space on that side and I'd like to add a covered porch section if the roof line and pitch will work.
  10. Chaz
    Chaz
    Southwestern NY
    I think I remember that week for me, very boring.:rofl: :lol:
    Hope the septic gets straightened around for you. No good when it doesn't work.
  11. Thor
    Thor
    Genoa City,Wi
    Bummer about your septic. Now what's this sober thing you speak of?:cheers:
    Maina, brenndatomu, basod and 5 others like this.
  12. basod
    basod
    Mount Cheaha AL
    I should reiterate for those coming aboard this thread, The leach feild or whatever is out there functions normally - never had a backup.
    Then again this is just the two of us most of the time, and has likely (from previous owner history) only been a two person residence, but 3 bedrooms.
    I don't want to build a masterpiece deck & cover(the first for myself, built many for others) and have to deconstruct in the future if the leach field decides to quit with no access.
    Maina, yooperdave, Thor and 7 others like this.
  13. wildwest
    I forgot, sexy tractor!!
  14. chris
    Why not build the deck so that you have trap door access to the septic? Course all depending on local codes and such.
    Maina, Eric VW, brenndatomu and 4 others like this.
  15. basod
    basod
    Mount Cheaha AL
    IMG_1115.JPG IMG_1116.JPG Pumper guy couldn't make today so...
    Ran a hose test today after cleaning some gunk from the funnel. My suspicions are confirmed- NO Leach field :headbang:
    The outlet of the funnel over flow tee just goes into the formed opening in the tank, into which some pieces of asphalt have been jammed.
    The tank just filled up no draining.
  16. Canadian border VT
    No liking that!!!
    Maina, yooperdave, Eric VW and 2 others like this.
  17. coreboy83
    coreboy83
    NW of Twin-Cities
    uhhh,, you'll be waiting on the deck build until after you run a proper drain field. be thankful if you don't need a lift pump. when our house was transacted, the previous owners had to "correct the problems". they replaced every inch of the entire system from the foundation out to the last run.... never heard how much it was, but i'm sure it realllllly ate into their profit from the sale
    Maina, yooperdave, Eric VW and 3 others like this.
  18. Canadian border VT
    If you have to add a leach field anyway, you might as well replace a tank it's only the additional $500. Move the tank pass the deck and put the Riser on it so it's the ground level and build the deck you want!!
    Maina, papadave, yooperdave and 8 others like this.
  19. chris
    local codes might just make you do that anyway
    Maina, TurboDiesel, Eric VW and 5 others like this.
  20. wildwest
    Or get a large vault and get it pumped? And it looks like the pool is close, will have to run leach pipes around it
