So begins the trailer rebuild.
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2018.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    According to the diagram anyways red, brown and yellow. I’ve never seen that before. It’s always been two wires....
    Chvymn99 and Horkn like this.
  2. Pallet Pete
    Ovid
    Aha! Ok so it’s just like a 4 way then. :salute: Good grief the diagram for a seven way shows red as stop lights, yellow as turn.
    So yellow is stop and turn correct?
    Chvymn99, Horkn and huskihl like this.
  3. saewoody
    saewoody
    Central CT
    This is a little clearer. Agreed with what huski said
    Chvymn99, Chaz, Horkn and 1 other person like this.
  4. Redneck
    Redneck
    Burton mi
    Looking at the three wires hanging from your light
    First picture after wiring questions
    Brown to brown / red to red and yellow to white on left side and green to white on right side.
    Should be correct
    Chvymn99, leoht, Horkn and 2 others like this.
  5. huskihl
    huskihl
    This^
    is how the truck should be wired. I use a similar downloaded pic
    Chvymn99, leoht, Horkn and 1 other person like this.
  6. Redneck
    Redneck
    Burton mi
    Thats not what the wiring diagram is showing
    leoht likes this.
  7. huskihl
    huskihl
    The only thing a designated "stoplight" wire would be used for is the 3rd brake light like on all new cars today on top of the trunk
  8. savemoney
    if not this one, there are several others, I.E 4 to 7 pin
    leoht and Pallet Pete like this.
  9. huskihl
    huskihl
    Are both lights identical? The wires coming from each one are identical colors?
  10. saewoody
    saewoody
    Central CT
    Yes, but that original diagram is also showing a completely separate brake light in its own housing, which I don’t think is the case with Pete’s trailer. I think that particular wiring diagram may be the issue, and is causing the confusion.
  11. Pallet Pete
    Ovid
    Yes same colors. After testing it’s white ground no question there
    Red is stop so that must be yellow from the trailer.
    Brown is tail lights ( running )
    I think the diagram is not correct. Talk about annoying...
  12. huskihl
    huskihl
    I suppose those particular lights could each have their own separate turn and stop light bulbs.
    brenndatomu and Pallet Pete like this.
  13. Pallet Pete
    Ovid
    They are led lights does that make a difference?
    leoht and brenndatomu like this.
  14. huskihl
    huskihl
    Thats where I would go next. Brown to brown, red to corresponding turn signal, white to ground
    Pallet Pete likes this.
  15. huskihl
    huskihl
    Don't know. Never used those particular lamps. If white is definitely ground, then no, since there's no extra wire for it.
  16. saewoody
    saewoody
    Central CT
    Shouldn’t. Just took a pic of mine. Looks like very similar light to yours. These are LED. It’s a four pin, but that really shouldn’t matter as far as the lights go in terms of wiring. Sorry for the pic quality. It’s dark out.
    Horkn and Pallet Pete like this.
  17. Pallet Pete
    Ovid
    Green trailer eah! :startled: They do look the same! Creepy.
    I’ll try to wire it all up tomorrow night I’m beat.
    Thanks everybody! Pretty sure that diagram is the problem:whistle:
    papadave, leoht, Horkn and 4 others like this.
  18. saewoody
    saewoody
    Central CT
    Yup! But mine is only about half the size as yours. It’s a 4x6, but it’s rated for 1,500lbs, plus the previous owner reinforced the axle and suspension. I haven’t been able to overload it yet.
  19. Pallet Pete
    Ovid
    Thanks Larry I watched a few of those but didn’t get the answer I was looking for. Apparently the link I got for a diagram is the issue. Shoulda just wired it like a 4 way.:picard: I can do that blindfolded. Changed enough lights on the old light hangers.
  20. Redneck
    Redneck
    Burton mi
    Hey Pete does this help its the simplest example i found 1EB99ABB-D32C-4A6D-BF14-EDCBE0064F0E.png
    papadave, Need2Saw, savemoney and 5 others like this.
