Old St Croix - Lazy Flame and Pellets pile up in burn pot?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Mar 29, 2018.
  1. don2222
    don2222
    Salem NH
    Hello
    This one bag of pellets created a lot of creosote in this St Croix Hastings since the last time it was cleaned!!
    See pic of exhaust blower!
    After cleaning the stove again and using new different pellets and a new exhaust blower it seemed better but after an hour the pellets built up, the flame was a little lazy still!!
    Finally found the cleanout cover behind the ash pan. Stuck a brush in there and some more hard black chips of creosote came out and all of a sudden we felt the cold air from outside! Bingo the stove works fine and the flame is dancing again!
    Has anyone seen such shiny black creasote and the hidden cleanout behind the ash pan on these old St Croix Pellet Stoves??
    Could it be that the wood pellets had tree bark with creasote mixed in???
    mat60, CleanFire, ivanhoe and 3 others like this.
  2. ttdberg
    ttdberg Pellet Pig
    CT
    Holy crap is that creosote caked onto that fan?
    :eek:
    mat60, CleanFire, ivanhoe and 2 others like this.
  3. PelletHound
    PelletHound
    SE Ma.
    Looks like it.:eek:
  4. don2222
    don2222
    Salem NH
    Yes, and the fan was nice and clean before those cheap pellets from the variety store were burned!! :hair:
    CleanFire, ivanhoe and PelletHound like this.
  5. bogieb
    My former 2008 Hastings had 3 cleanouts; one to either side of the chute (basically) and 1 behind the ash pan (I had to search since manual isn't real good at telling you exactly where that one is at). I not only had to empty the ash pan weekly (faithfully), but I had to clean out the 3 ash traps and baffle plate at least every other week or it would burn poorly. Also, any time I changed pellet brands I had to mess with the damper or it would burn poorly. Once I got the damper dialed in for the pellets it would be okay - but made it a PITA at times.
    Just some of the reasons I jumped at the opportunity to get the P43 when it came up on CL (and negotiated a great price for it)
    CleanFire, ivanhoe, imacman and 3 others like this.
  6. CleanFire
    CleanFire
    There's a fine line between that type of negotiation and stealing in some jurisdictions.. :whistle:
    :thumbs:
  7. CleanFire
    CleanFire
    Only time that happened here w/ the Francesca was when we started burning in '15 , w/ those chit P$%^@!nnton pellets that were loaded w/ Bark and Plastic bits. :picard: It took hours to clean all that crap out, even on the small stove here.
    slvrblkk, bogieb, ivanhoe and 2 others like this.
  8. bogieb
    No lead throwers or pointy objects involved, so that fine line wasn't quite crossed :D. May have been a bit of coercion since they had no other recourse . . .
  9. don2222
    don2222
    Salem NH
    CleanFire likes this.
  10. bogieb
    I never had any issues with it feeding, but I only used it for one season and pretty much stuck to FSU's that I got from HD
    CleanFire, don2222 and imacman like this.
  11. krooser
    krooser
    Waupaca, WI
    I think that stove was run for a long time with a vaccum leak... loose ash pan door or versa-grate cleanup rod pulled out. I had that happen right after I installed my stove... but one service call and some directions from the service tech fixed that. He also taught me the leaf blower trick.
  12. ChimneyCharlie
    ChimneyCharlie
    Have a St. Croix Afton Bay stove. Do they all have the third ash clean out behind the ash pan?
  13. don2222
    don2222
    Salem NH
    The older stoves do Not have the cleanout behind the ash pan. Therefore for those stoves you must remove the exhaust blower and brush out this area as deep as you can go and then blast it with an air compressor.
    badbob, BHags and bogieb like this.
