So begins the trailer rebuild.
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2018.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I just did some digging I don’t have any 2*1/4 flat but I do have a huge sheet of steel that’s close I can cut them out of. No idea where I got it but I’ll do it tomorrow.
    I think all that’s left is tailgate, fenders and lighting then paint. The lighting will take a while to do but the rest is a few nights and done.
    Time to find some better ramp gate hinges:whistle: I’m half tempted to go and buy some solid round stock and make sleeve pins. The hinges are resiculas $$$$ add a grease zerk to the sleeve and call it good.
    Gasifier, Horkn, eatonpcat and 5 others like this.
  2. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Cool. For your gussets, 3/16 would work, but don't go thinner. I don't recall your winch rating, but it's gonna cantilever and create some issues if you're yanking heavy stuff (#1000 lbs. +) I think you're good to #1000 with this set-up, straight line pulls. The cantilever situation is my only concern, the rest looks good.
    For hinges, 3/4" sch. 40 pipe and 3/4" cold rolled round bar stock works well. Sloppy enough you don't need to grease them, but strong enough to do the job.
    3/4" sch. 40- ID= .824- but you have a weld seam to deal with, it works out with some usage.
    Build it like a piano hinge, you'll never have an issue.
    Horkn, savemoney, raybonz and 4 others like this.
  3. Pallet Pete
    Ovid
    Nothing crazy puking the splitter up in, occasionally an atv or riding mower. I’ll weight and see if I can find 1/4 drops somewhere close to me... There is a tooling shop in town they might have some.
  4. brenndatomu
    I dunno Pete, puking the splitter sounds pretty crazy to me! :p ;) :rofl: :lol:
    milleo, Chvymn99, Horkn and 6 others like this.
  5. Pallet Pete
    Ovid
    I need the gate to be able to slide off the trailer too otherwise I’d do the piano hinge.
    Hmm thinking cap time...
    Chvymn99, Horkn, savemoney and 3 others like this.
  6. brenndatomu
    You can still use this type of hinge, just leave gaps instead of solid the whole way across. That way the gate/ramp can be slid sideways to disengage the pins. If you use 6" long pipe sections, then leave a 7" gap so that your 6.5" pins (for example) can have a cotter pin/clip to hold it in, and still be able to slide over and out
  7. Chaz
    Chaz
    Southwestern NY
    ^^×2
    Chvymn99 likes this.
  8. Pallet Pete
    Ovid
    What guage expanded metal should I use for the ramp ? i stopped and looked at TSC and Farm and home they all have realllllly thin expanded steel... I think to thin.
    brenndatomu, Chvymn99 and Horkn like this.
  9. Pallet Pete
    Ovid
    Actually come to think of it it doesnt need to be crazy heavy I am putting supports where the tires from the mower and splitter will be.. Its mainly going to hold stuff from falling out the back anyways.:picard: we have never had a drop gate on this trailer before or any gate for that matter :whistle: thats the icing on the cake for us!
  10. Pallet Pete
    Ovid
    Just found that gem in my scrap! Time to make gussets!!! heavy as it can get!
    Gasifier, milleo, eatonpcat and 5 others like this.
  11. Pallet Pete
    Ovid
    One down
    Gasifier, milleo, Chaz and 8 others like this.
  12. raybonz
    raybonz Moderator
    Carver, Mass.
  13. Pallet Pete
    Ovid
    My old trusty angle grinder. She isn’t pretty or powerful but it does the trick! I use scrap as a straight edge usually.
    Gasifier, milleo, Chaz and 9 others like this.
  14. raybonz
    raybonz Moderator
    Carver, Mass.
    I have a Ryobi too.. How thick is the cutting wheel? I have used it for cutting firebrick too with masonry wheel.. Nice work Petey!
    Chaz, Chvymn99, brenndatomu and 2 others like this.
  15. Pallet Pete
    Ovid
  16. Pallet Pete
    Ovid
    I e had that grinder for many years it’s the only one I haven’t burned up yet..
  17. Horkn
    I don't know how I missed this thread, but I just read it all.
    Seeing that the trailer is 52" wide bed, how long is that trailer? It seems narrow. Also, the crazy weight ratings on the springs tell me it's longer than it looks.
    papadave, Gasifier, milleo and 8 others like this.
  18. Pallet Pete
    Ovid
    It’s a solid axle 52” wide by 14’ long bed total length is just over 17’.
    I’ve had it scaled at 5000 lbs before with firewood, hauled bricks and had it maxed which now I know the springs that where on it where 7+k was probably close to 6000 lbs of bricks.
    It’s gonna be mostly firewood, splitter, lawn mower and home projects like lumber plywood and so on.. Probably the kayaks too but those are light and don’t count.
    Its in need of a lot of love and my plan is overkill but better to be overdone when I need it than to be not enough if I need it. I’m a bit OCD do it once type of thing I guess. It’s also getting cup holders somewhere. :rofl: :lol: Just thought of that!
  19. Horkn
    Make some chainsaw scabbards on it too. On the rails. I need to do that to the 4x8 trailer.
  20. Pallet Pete
    Ovid
    And done...
    papadave, Gasifier, milleo and 9 others like this.
