So begins the trailer rebuild.
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2018.
  1. triptester
    triptester
    S.E.Wisc.
    I have found that running the ground wire directly to the lights rather then just using the trailer frame for grounding greatly reduces problems.
    Need2Saw, Horkn, savemoney and 7 others like this.
  2. brenndatomu
    This! ^ ^ ^
    Horkn, Chvymn99, Beetle-Kill and 3 others like this.
  3. chainsawsoldier
    chainsawsoldier
    NE Kansas
    Dedicated ground wires make troubleshooting light problems a LOT easier
    I also use a 7 pole junction box at the front of the trailer. It makes the connections easier, and also easier to replace the pigtail
  4. Pallet Pete
    Pallet Pete Moderator
    Ovid
    The rest of the amazon goodies showed up today!! Just leaves fenders:Dand ramp hinges:D
    Gasifier, milleo, Horkn and 6 others like this.
  5. Pallet Pete
    Ovid
  6. Pallet Pete
    Ovid
    Well this is what I am coming up with so far. Half welded half mock-up. It is free standing off the front of the trailer.
    I’m trying a new flux wire out and it is complete crap... I can barely strike an arc let alone keep the pool moving I may be taking it back and going back to forney E71T-gs good as Lincoln or Hobart wire and cheaper.
    The new wire just plain looks like crap... I had to fill a few very large gaps and grind down two welds then fill again do to that wire o_O
    papadave, Gasifier, WeldrDave and 8 others like this.
  7. Pallet Pete
    Ovid
    Well so went to farm and home and picked up more forney 035 flux what a difference that makes... looks so much better!
    papadave, Gasifier, milleo and 9 others like this.
  8. Pallet Pete
    Ovid
    It’s almost ready and crazy strong!
    6985E179-5896-49C5-9B1A-5BEF6A57535D.jpeg F15C554D-DE5C-4118-B62B-0D673330CC33.jpeg
    papadave, Gasifier, milleo and 7 others like this.
  9. Chaz
    Chaz
    Southwestern NY
    Definitely looks like better welds.
    Quality materials definitely make for a better outcome.:yes:
    edit.. Someone's been busy today. Good work.
    milleo, Horkn, savemoney and 5 others like this.
  10. Pallet Pete
    Ovid
    :thumbs:
    Mocking up fenders now!
    papadave, Gasifier, milleo and 8 others like this.
  11. Chaz
    Chaz
    Southwestern NY
    You shouldn't mock your fenders, they'll help keep slop off your logs.
    Git 'R Done®:cool:
    papadave, Gasifier, Horkn and 8 others like this.
  12. Pallet Pete
    Ovid
    Gasifier, Horkn, eatonpcat and 4 others like this.
  13. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Lookin' good !
    Horkn, Chvymn99, brenndatomu and 2 others like this.
  14. Pallet Pete
    Ovid
    You think that top square tube will hold? Thats the one thing I dont like on the winch stand. I am thinking about boxing the ends for strength.
    Horkn, Chvymn99, Chaz and 1 other person like this.
  15. Beetle-Kill
    Beetle-Kill
    Box the ends, and run a gusset plate from the back of the receiver tube to the diagonal supports, one per side. Some flat bar will work fine. Should spread the force and not have that cross tube want to "rock" under load.
    papadave, Horkn, leoht and 5 others like this.
  16. Pallet Pete
    Ovid
    I like it! I have some scrap left I can make gussets out of.
    Horkn, leoht, Chvymn99 and 4 others like this.
  17. raybonz
    raybonz Moderator
    Carver, Mass.
    Looking good Pete! I've heard anti-spatter spray works well for mig flux welding Lincoln Electric Anti Spatter Non-Stick Spray-KH505 - The Home Depot .. BTW I did order a small stick welder to play around with.. I bought it at Ebay with a 13% off coupon for $126.65.. 160 Amp Digital Display LCD Stick/ARC DC Inverter 115V & 230V Welding Machine Now I need some scrap metal to practice on..
    Horkn, Chaz, Beetle-Kill and 3 others like this.
  18. Pallet Pete
    Ovid
    I use anti splatter spray also forney brand except it’s almost gone and I forgot to grab more....
    Scrap can be easy to find if you know where to go. I get it from steel yards as dirty metal and sometimes mild steel leftover from work.
    A lot of job sites give it to you free as well... Don’t pay box store prices you’ll go broke.
    Horkn, eatonpcat, Chaz and 4 others like this.
  19. brenndatomu
    Yeah, a couple pieces of 1/4 plate welded on each size would make that rock solid!
    Like this...
  20. Beetle-Kill
    Beetle-Kill
    Yes!!! Exactly what I had in my mind. 2 x 1/4 flat would be perfect. :yes:
    Allows lots of vertical weld strength. Perfect.
    Horkn, Chvymn99, Chaz and 2 others like this.
