So begins the trailer rebuild.
Discussion in 'The DIY Room' started by Pallet Pete, Mar 4, 2018.
  1. Pallet Pete
    Pallet Pete Moderator
    Ovid
    I’m a huge fan of rusty metal primer and have used it with good success over the years on everything from cars to diy builds but the favorite by far was a log splitter that got totally rebuilt and painted so that’s what the axle is getting after a good wire wheeling and wipe down.
    Can’t do much today so I am hitting the axle with a couple coats in preparation for paint.
    2D8FDC51-0AC4-49AE-A20F-93F2718046AC.jpeg 643ECF3A-FE5A-476A-8517-91C31822EA01.jpeg
    Gasifier, chipper1, Horkn and 8 others like this.
  2. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    My .02 if you havent found springs yet
    2,300 - 4,000 lb capacity
    I had these on a utility trailer that i have since sold and regret selling. Trailered sooooo nice and the rubber torsion dampers acted like shocks. Very little sway and trailered sooo smooth.
    chipper1 and Horkn like this.
  3. Pallet Pete
    Ovid
    Finally a warm day to really have at the trailer it’s almost ready for the springs! I’ve got brackets on one side welded up so tomorrow will be the opposite side then get the springs bolted on and trailer hauled outside so I can get the gate welded up.
    The wheel wells where welded on to stay! Man that was a lot of grinding to get them off:hair: the trailer.
    I’ve also got to figure out what to do for wiring protection the tubing that was on the bottom was collapsed in and rotted through in a few places.
    I’m debating using pex to run the wires through to act as protection it would allow me to run it almost anywhere I wanted.
    E8761362-7CCD-406B-9A22-2938A7A23F89.jpeg 26F0B83C-4D23-4267-A34F-63CB01724A6D.jpeg
    Gasifier, chipper1, Horkn and 10 others like this.
  4. Pallet Pete
    Ovid
    I also took the hinges back they are total crap... I can make better hinges than those :loco: :crazy: they where not drilled even side to side and the welds on them are just dragged accrost fast not even lapped for strength. :startled:
    Time to either make em or buy a better hinge I don’t really want to fiddle fart with making them so....
    Gasifier, chipper1, Horkn and 5 others like this.
  5. huskihl
    huskihl
    Hard to beat a good set of chain falls
    chipper1, Horkn, leoht and 3 others like this.
  6. Pallet Pete
    Ovid
    I got sick of hunting and getting screwed over and lied to by all the craigslist and Facebook sales. Almost nobody is honest and wants new value for old garbage....
    Ended up buying this cheapo until we can save for a good one with a ceiling trolly and it’s been alright so far. I greased it up changed the nuts to lock nuts and so far so good. It’s got a decent amount of slop but that doesn’t appear to be to big of an issue as long as I don’t forget....
  7. huskihl
    huskihl
    As long as it lifts chit up and down......
    chipper1, Horkn, eatonpcat and 3 others like this.
  8. Pallet Pete
    Ovid
    So far it does it skips a link every now and again but it appears to hold and only skips going up.
  9. savemoney
    $200. sounds like a bite, but it could be so much more. Are you going to be an oak floor bed on it? you will have enough invested when you are done, but you will have something that should serve you well for years to come. Getting into what will be the busy time. Spring is always too short.
    chipper1, Horkn, leoht and 2 others like this.
  10. brenndatomu
    Exactly what I was thinking...could use PVC conduit straps to hold it up...use SS screws on 'em
    Chvymn99, chipper1, Horkn and 5 others like this.
  11. Pallet Pete
    Ovid
    I’m still debating the floor it’s going to be expensive no matter what I do but I’m thinking about treated and calling it good for now. We need this fast and don’t really have time to wait this year... Major pain right there... My plan is to be done by the middle of April if not sooner. It might happen...
    Gasifier, chipper1, Horkn and 4 others like this.
  12. imwiley1
    imwiley1
    Wisconsin
    In regards to using Pex for the wiring, find out if it is uv resistant or not. I had some leftover from water lines in the house and used some to cover a cable for a kids swing. It became brittle and cracked surprisingly fast.
    chipper1, Horkn, Screwloose and 3 others like this.
  13. Pallet Pete
    Ovid
    This some VERY hard to clean and weld on metal UGLY! But it’s on there...
    Gasifier, chipper1, Horkn and 12 others like this.
  14. clay shooter
    clay shooter
    ENGLAND
    coming on very well. good trailer when its all done.
    chipper1, Horkn, savemoney and 2 others like this.
  15. Pallet Pete
    Ovid
    She just got axles and a bath!
    75E60A02-D80B-4555-88F9-E28FB0DEE7F1.jpeg 9DBB4E1B-38B2-4DD6-B002-6C7D48309B02.jpeg
  16. Chaz
    Chaz
    Southwestern NY
    Hey, it looks WAY better in the sunshine. :yes:
  17. Pallet Pete
    Ovid
    Indeed! Good thing too I’m exhausted lol
  18. Chaz
    Chaz
    Southwestern NY
    It looks good for logs, but those shorties will fall right through the holes in the bottom.;)
    chipper1, Horkn, savemoney and 4 others like this.
  19. Pallet Pete
    Ovid
    I am attempting to figure out where to put the tie downs at. There isnt really a good spot on the trailer for them. I think maybe along the bottom of the c channel outside of the bed would do ok. and then some recessed in the bed.
    What do you guys think?
    They bed is about 52" wide...
  20. ironpony
    ironpony
    Mid Ohio
    you could use 1/2 black pipe and weld it to the frame....that what I did.
