New gasket crush
Discussion in 'Modern EPA Stoves and Fireplaces' started by Beetle-Kill, Feb 27, 2018.
  1. Beetle-Kill
    Beetle-Kill
    Near the Divide, Colorado
    Just replaced the door gasket on the BKK. Had to back the catch out 3 turns. Turned back in as it takes a set, but it seems too much now. Passes the "dollar bill test" now, but if I back it out 1 turn, I can pull the bill out.
    So, how much crush can I expect? Will it take a set overnight? Stove is cold. Thanks.
    Dam, finally hit #3000 posts! I'm too mouthy I guess. ;)
  2. Eric VW
    Ooohhh bogydave....?
    Oooohhh bobdog2o02 ...? (Princess Ultra owner/operator)
    Chaz, Beetle-Kill, yooperdave and 3 others like this.
  3. bocefus78
    bocefus78
    Not a bk owner but when I upgraded to a newer thicker gasket, I also had to adjust the door latch. I made it pass the bill test and never adjusted it again. It was a little stiff closing the latch at first. It's been a year and it's finally to the point where I can feel a difference (easier to latch) but it's still sealed.
    Id leave it be, burn it, and let the burn tell you iffn it's sealed.
  4. Backwoods Savage
    Okay, you are mouthy. :rofl: :lol:
    FatBoy85, Chaz, Beetle-Kill and 2 others like this.
  5. bobdog2o02
    bobdog2o02
    Drury Lane, PA
    It will take alot of crush. I wouldn't be bashful about it being really tight at first. More than anything make sure your bill test is good all the way around the door, it is possible for it to be loose on the hinge top and bottom too.
  6. Beetle-Kill
    Beetle-Kill
    Good on sealing, and it took a set overnight. I can close it with one hand now, last night was some effort. :yes:
    Chaz and Backwoods Savage like this.
  7. stumplifter
    stumplifter
    near Tomahawk, WI
    I azz-u-me that the indication of a leaky gasket would be similar to the door being slightly ajar? Flames dancing from leak instead of a nice smooth secondary burn?
  8. bocefus78
    bocefus78
    You got it. I actually had a couple spots on the glass that would never clean up with increased temps. That was my main indicator.
    stumplifter and bobdog2o02 like this.
