Tomorrow is the day
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Rich250, Feb 19, 2018.
  1. CleanFire
    CleanFire
    :eek: I heard you up here in NH. :singingintherain:
    bogieb, imacman, ivanhoe and 3 others like this.
  2. don2222
    don2222
    Salem NH
    What is the TC model and is it better??
    CleanFire, Rich250 and IHATEPROPANE like this.
  3. Rich250
    Rich250
    Berks County PA.
  4. Rich250
    Rich250
    Berks County PA.
    Started the install plans for the Allure. I figured since it's not that cold out I would take some extra time and completely redo the corner that the stove is going in. 2 yrs ago over the winter we redone the stove room but worked around the stove so that will get finished now. The Ravelli sits on a raised hearth on top of the carpet so that's getting changed. Picked up the vent for the Allure oak since that needs to be changed to 3". If it ever stops raining I will go pickup the sheet of paneling i'm gonna need for the back and side wall. I'm figuring 2 solid days of work until the stove will be ready to fire but it should look nicer then it currently does. Here is the vent I got for the oak with a 4" - 3" reducer Shop IMPERIAL 4-in Dia Galvanized Steel R2 Exhaust Dryer Vent Hood at Lowes.com I removed the damper and installed a piece of screen. The vent will pass through the wall and then flex pipe too the stove. My goal is to have everything on hand so that when I tear in I can get it done in the projected 2 days. :whistle:
    bogieb, Eric VW, CleanFire and 5 others like this.
  5. slvrblkk
    slvrblkk
    Northampton, PA
    Wishful thinking? :whistle: :D
  6. Rich250
    Rich250
    Berks County PA.
    yeah tell me about it.
  7. don2222
    don2222
    Salem NH
    Hey Rich
    Are you using 3” flue Vent or going with the Stainless Steel lined Pro 4” Vent? What about the one hole Selkirk DT that is rated for 50-50 corn mix, with the easy vacuum cleanout, it works great with Harmans and you get 10% more efficiently? I also put a WiFi T-Stat on one leg of the room probe for remote access.
  8. Lousyweather
    Lousyweather
    Harman makes a wifi stat for the Allure......no wiring required.....it works quite well
    IHATEPROPANE, CleanFire and Rich250 like this.
  9. don2222
    don2222
    Salem NH
  10. imacman
    imacman
    Denver, NC
    I've looked at the DT literature on the Selkirk site before, and don't remember seeing that claim. Care to refresh my memory with a link to their literature where they state that?
  11. don2222
    don2222
    Salem NH
    No they cannot make that claim because of all the different climates, altitudes and configurations of installations!
    However in my experience, I installed a fresh air liner and insulated the fireplace to block heated room air from going up the chimney and my friend’s electric bill was 8.7 % less that season which was more mild than the previous season. So I believe it is saving some energy and the results can vary greatly. I would not say more than 10% because that is just not true. I would also say in dryer climates savings may be less. Also it is more of the concept of warm fresh air not just the venting itself. I really like the DT venting just because the ash is dryer and fluffier here in the damp North East so it is easier to keep the stove cleaner and a good chance of less rusting. :)
  12. imacman
    imacman
    Denver, NC
    So how do you come with a claim like that????
    IHATEPROPANE, CleanFire and subsailor like this.
  13. don2222
    don2222
    Salem NH
    Sorry, I lost some of the post, I just put it all back in. :)
  14. imacman
    imacman
    Denver, NC
    OK, again, how do you come up with the 10% claim??? I sure hope you're not using that when you try to sell the pipe to a customer....it's false & misleading.
  15. Rich250
    Rich250
    Berks County PA.
    I'M reusing my current 3" duravent I just have to move the pipe over 6". I think I could have just used an adjustable 90 and made it work but I don't want anymore elbows then absolutely necessary. So the exhaust will come off the stove straight out and up 5ft. Only about 6" of pipe will be inside. My existing oak is 2" so I have to change that. At some point I may invest in the Harman wireless sensor but for now I'm gonna try putting the wired sensor where I have the Ravelli sensor and see how accurate it is. The Ravelli is within 1 deg. Of my thermometer in the next room.
  16. don2222
    don2222
    Salem NH
    No, I never do and there are some many variables there is no guarantee. I just explain the configuration and they like how only 1 hole is needed for the flue and OAK. The people who do choose it, really like it after using it a while. :)
    So far I have seen it installed on a Whitfield Quest, Englander 25-PDV , 25-PDVC , Hudson River West Point, Harman P61 and Advance Pellet Stoves all with very positive results. :)
  17. Lousyweather
    Lousyweather
  18. gbreda
    gbreda
    NH
    Does it come with a soap box? :rofl: :lol:
    Wait, I have one too and they are Da Bomb !!!! :thumbs:
    artc, IHATEPROPANE, CleanFire and 4 others like this.
  19. gbreda
    gbreda
    NH
    Whats getting updated or is it a new model?
  20. Lousyweather
    Lousyweather
    :zip:
