What is wrong with this poor old little Gnome? - see video
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by don2222, Jan 23, 2018.
  1. don2222
    don2222
    Salem NH
    Hello
    It does not feed on high and the cleaning cycle does not seem to work?
    In Low and medium it works but sounds like a variable speed noise?
    See vid
    Click here to see Thelin Gnome noise video
    So what is wrong?
    slvrblkk likes this.
  2. don2222
    don2222
    Salem NH
    Today we pulled the auger feed assembly and before we put the new assembly in we changed the T1 and T2 sensors and installed the upgraded set screw in the auger motor collar for a stronger connection for better pellet feeding.
    Sounds better but still a little whirring noise. Any thing else can be done? Still not working on High?
    Pic 1 - Skanky old Auger feed assembly has some rust
    Pic 2 - New T1 & T2 sensors
    slvrblkk and Luneyburg like this.
  3. badbob
    badbob
    Bad brushes or bad motor,I would think.
    slvrblkk and imacman like this.
  4. badbob
    badbob
    Waiting for a reply of what fixed this unit?
  5. badbob
    badbob
    Waiting,Don.
  6. jtakeman
    He was hoping you'd tell him how too..........
    :p
  7. ksks
    ksks
    MO
    Sounds like a normal Tardis to me...
  8. jtakeman
    Had to google dat one!! :emb:
  9. don2222
    don2222
    Salem NH
    Since the whole auger motor assembly with new brushes was replaced, I conferred with Thelin (I.E. Sierra Products now) and the plan is to replace the old rotary knob Potentiometer Circuit Board. (10 pin board not the slightly newer 8 pin board). That part was on back order at Thelin until the first of this week. Therefore I just got it in the mail today. :)
    jtakeman likes this.
  10. don2222
    don2222
    Salem NH
    New Pot on Circuit Board fixed it!
    See video.
    The Temp is 20 Degrees Outside and the Thelin Gnome is keeping the 12' x 22' insulated workshop 75 Degrees running on the medium heat setting!!
    Russell and peterfield like this.
  11. badbob
    badbob
    So,you replaced a POT on he circuit board?Poor reply,better explanation is required.Info is required!!
  12. don2222
    don2222
    Salem NH
    I replace the board with the pot and showed a pic,
    It is the heat selector pot. See both pics
  13. savemoney
    Always good when you return the stove to a useful life! Nice looking unit.
    imacman, jtakeman and Russell like this.
  14. don2222
    don2222
    Salem NH
    Yes I agree.
    It is an older unit but sometimes they have a lot more life in them?
    This pellet stove has all 12 VDC motors and red and black banana jacks to plug in a deep cycle marine battery.
    You can also hook a solar panel array and live off the grid with heat!!!
    See Solar Panel Fact sheet.
    http://thelinco.com/wp-content/uploads/Solar-Panel-Fact-Sheet-MP-REF-SLS-202-Rev.-A.pdf
  15. badbob
    badbob
    Cool nice repair,hope customer is happy.
    don2222 and savemoney like this.
