  1. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    Current temp.
    Was 48 under at a friends cabin this morning . Down in Copper Center. Coldest we had here was 42 under. 44 below in downtown Glennallen this morning . Winds fairly calm. 20180202_223307.jpg
    Stove is loaded for the night . 1 split of white spruce . The rest is poplar.
    Horkn, BigPapi, wildwest and 7 others like this.
  2. Heat550
    Heat550
    Minnesota
    7f feels warm but still burning oak slabs . Not much wind ..Here is my winter slab cutting pal . Takes alot of dog food .
    Heat550[​IMG]
    Sent from my LG-H900 using Tapatalk
  3. OldJack
    OldJack
    Saskatchewan, Canada
    8° below F here tonight (-22° in Trudeau math). No warming forecast for a week.
  4. bear 1998
    bear 1998
    S.C.Pa
    10* now....burnin black locust mixed some white ash.....only 6 more weeks folks....LOL..:D
  5. Rope
    Rope
    Alaska
    Spruce is keeping us warm. A4D693F5-DAA5-4D15-8573-DBC8C2BE014E.png F371DEF0-261C-43CE-A2CC-9A0854186F03.png
    Sean, Horkn, BigPapi and 7 others like this.
  6. Backwoods Savage
    Seeing the constant below zero temperatures is getting so it makes me shiver. And to think, we once seriously considered moving to Alaska and we both enjoyed the cold and snow back then. Seems as we've aged a bit, we no longer like the cold nor the snow and especially hate the ice.
  7. Rope
    Rope
    Alaska
    If anyone is wondering, spruce will keep ya warm. It’s light to move and easy to split. 0405F59E-E848-4A2D-B017-37A87CBC13EB.jpeg
  8. Gasifier
    Yes. I use some Spruce here as well. Need to give it good time to dry.
  9. Gasifier
    0 degrees here with Maple reloaded in the Wood Gun. Light snow.
    I didn’t get that eight hour burn time last night. But it was close. Still had just enough embers to stir up and toss a couple small pieces of dry Pine on and watch it take off in seconds. The big tank was cooled down though, because the Wood Gun was not throwing any more heat. The bubbling goo boiler kicked on once or twice :emb: until the Wood Gun started throwing heat over 170 about 15 minutes later. It had only cooled down to 165.
  10. Well Seasoned
    We saw -13°F last night with a wind chill of -24°F Woke up to no water & lightly frozen pipe in the pump house- both lamps went out. No damage as far as i can see, everything back up and running.
  11. NH mountain man
    NH mountain man
    WMNF N.H.
    Thank God you found it early, it could have been a nightmare.
  12. JustWood
    JustWood Guest
    10
    Half load of beech
    Supposed to hit 30 early afternoon . Letting it go out so I can sweep the stack and change door gasket this afternoon
  13. NH mountain man
    NH mountain man
    WMNF N.H.
    3 here this lovely AM, Elm, soft & hard Maple dancing with the coals at the moment.
  14. Well Seasoned
    Oh, i know! I have a temp monitor out there and it shows the temp from inside the house, but i need something with an alarm.
  15. papadave
    You folks in Alaska (Rope , Cold Trigger Finger , bogydave , and whoever else) must have ice in your veins or sumthin'........too cold.......too cold. :shiver:
  16. Mwalsh9152
    Mwalsh9152
    Pelham NH
    I wasn't expecting to see it only 6F this morning. I've been burning borderline punky maple and some solid red maple because it's been fairly mild. It was 64F in the house when I woke up. That was an unpleasant start to the day.
    No kids this morning, so I was gonna get an early start and work outside, still on the couch saying nope. Don't even wanna make the dump run. Need to go plug the truck in for a bit I guess.
  17. Cold Trigger Finger
    Cold Trigger Finger
    At the moment temp.
    Poplar in the stove. It's Saturday, what am I doing up so early. Well Seasoned ; glad you got it flowing again. I have to run fans to keep my water system flowing. And it is all inside.
  18. Well Seasoned
    Thanks! You've been having some wicked cold!
    Sean, Horkn, NH mountain man and 5 others like this.
  19. saskwoodburner
    saskwoodburner
    image.jpg image.jpg Still chilly.
    Sean, Horkn, OldJack and 7 others like this.
  20. Backwoods Savage
    We've used a lamp in the pump house for years but this year finally just gave up and put heat tape down there. No problems so far.
