Tire loosing air but no puncture or wall damage?
Discussion in 'The DIY Room' started by don2222, Jan 25, 2018.
  1. don2222
    don2222
    Salem NH
    I have a tire question? My tractor tires loose air after a week but do not have any punctures. It seems that instead of just inflating them, I need to make a better seal of the tire to the rim. When I was young I saw my friend mount tires he would clean the part of the tire that touches the rim with a paint brush and soapy water. Walmart has a bearing sealer solution that looks like it contains patroleum products because it is so flammable?
    What should I do?
    Here is more info I found,
    How to Stop Leak on Tire Rim Seal
  2. billb3
    rim leaks usually show up with the soapy water test just like punctures.
    LongShot likes this.
  3. Warner
    Take the wheel off fill the tire with air then put it in a tub of water. find the bubbles where the air is getting out and fix it.
    I’m assuming you are talking about lawn tractor tires. May be hard to find a tub for a rear tire on a farm tractor.
  4. bogieb
    Take it to Tire Warehouse or VIP and let them deal with it. VIP re-seated my old snow blower tire for something like $5 last winter.
    Horkn, Brian72, papadave and 3 others like this.
  5. Rich250
    Rich250
    Berks County PA.
    My tractor tires used to do the same thing until I put some of the green tire slime in them it's been 5 yrs. now and haven't had to add air since.
  6. ironpony
    ironpony
    Mid Ohio
    tire bead to rim, or valve stem
    1) break tire down clean rim of rust, paint rim, re install tire.
    2) take to local tire shop for 5-10 bucks
    Horkn, papadave, bogieb and 2 others like this.
  7. chris
    Green slime - Tire guys hate that stuff
  8. LodgedTree
    LodgedTree
    New tube...$50 bucks. Done.
  9. Rich250
    Rich250
    Berks County PA.
    true, would not use it on car tires especially with the TPMS but on tractor tires that most people will never have to change it's a quick easy fix
    Horkn, papadave and bogieb like this.
  10. Blstr88
    Blstr88
    One of my front tires was losing air slowly for a while...I think 3 times I took it out to use it and it fell right off the rim. The last time I wiped down the bead and rim and rotated the tire a bit from where it was, then reseated it using the time-tested starting fluid/lighter method...hasnt leaked since.
    Just try cleaning the tire/rim a bit before reseating it next time. Seemed to work for me anyway.
    Horkn, savemoney, don2222 and 4 others like this.
  11. bushpilot
    bushpilot
    Eastern Washington
    I'd use Slime.
    Horkn and Boomstick like this.
  12. lukem
    Did you check your valve stem?
  13. don2222
    don2222
    Salem NH
    Yes
    Horkn likes this.
  14. clay shooter
    clay shooter
    ENGLAND
    this is the same with my quad bike,been like it for 2 years cant find where its coming from, i just live with it,
    Horkn and bogieb like this.
  15. stihl sawing
    stihl sawing
    Arkansas
    If there is no puncture then it's either leaking around the rim or valve stem. You didn't say how big a tire it is. but if you want to fix it yourself, let air out and clean the rim and tire where they meet. or an easier fix just take it where they can dismantle it and clean it. by the time you buy the cleaner and stuff to do it with, you'll have more in it than taking it somewhere.
    Horkn, don2222 and bogieb like this.
  16. Boomstick
    Boomstick Banned
    Saratoga county ny
    Green slime works great. I use in in my atv I'll notice a tire is soft, and slime ooses out of the hole seals it usually before it's flat. I've got half a dozen sealed holes in more than one tire.
    Alot of people use it as prevention in case of a puncture.
    bogieb, stihl sawing and clay shooter like this.
  17. saskwoodburner
    saskwoodburner
    x 2. I had a tire that had mystery/old age leaks, and tire slime limped it along until I changed the tires out. Months.
    bogieb and Horkn like this.
  18. clay shooter
    clay shooter
    ENGLAND
    thanks will give it a try.
    Horkn and stihl sawing like this.
  19. Horkn
    Slime is good stuff. I won't use it on auto tires though, especially if you have tpms.
  20. The Wood Wolverine
    For all the guys that use Slime, please tell the tire shop it's in there. :handshake:
    Yerp!
