Ideal Steel Season #2 Tips, Tricks, and Improvements.
Discussion in 'Modern EPA Stoves and Fireplaces' started by JA600L, Sep 13, 2015.
  1. chance04
    chance04
    Denton Md
    It looked a lot like this, just over on the latch side
  2. Hollywood
    Hollywood
    The door gasket is quite thick you can fluff it up by squeezing it togather and achieve an almost new seal without messing with the handle.
    M2theB likes this.
  3. chance04
    chance04
    Denton Md
    I'll be trying that when I get home this evening.
    Has anyone removed the washers between the latch and the stove body, or is it just time to hit up WS for some maintenance parts?
  4. Hollywood
    Hollywood
    Give it a fluff I think you will be happy with the result.
  5. chance04
    chance04
    Denton Md
    I fluffed the gasket tonight when I got home from work. Instantly the latch is tighter, and the gap is gone. Thank you Hollywood for your insight. I do think I'll drop WS an email and order a gasket set and cat to keep on hand for next season.
    Sent from my SM-G900V using Tapatalk
  6. Oldhippie
    Oldhippie
    Ashby Ma
    Hmmmm.... I don't read these big IS threads all the time,but I try to follow whats going on. When I came across this "door gasket" discussion and talk of star washers behind the gasket material because some material has more density that others. Now I'm thinking this is my issue on my Absolute Steel as I discuss in this thread.
    WS Absolute Steel Door Adjustment
    chance04 likes this.
