Let the demo begin.........WOOHOO!
Discussion in 'The DIY Room' started by papadave, Sep 13, 2017.
  1. papadave
    Pretty sure that isn't going to be an issue. :headbang:
    Thor, Stinny, yooperdave and 3 others like this.
  2. bogieb
    :bug::bug:
    Thor likes this.
  3. papadave
    Not a huge deal, as there's only one piece of siding over it. Easy fix.
    One of the guys is here to finish the west side of the house, so I let him know about it.
  4. Stinny
    With any luck... you'll be able to heat the place with a couple well placed candles after they git done mistah man... :dex:
    savemoney, wildwest, Thor and 4 others like this.
  5. papadave
    Wife grabbed a lockset for the rear door while she was out shopping yesterday. I'll be putting that in today. That should pull the door a bit tighter.
    So when I got up this morning, it was still 70 in here without the furnace kickin' on at all, and the OAT at 5F.
    I'll take it. Used to be anywhere from 63-maybe 66 in those conditions.
    Hangin' at 73 IAT with 2 Maple splits in the stove. I'm cautiously optimistic.
    Oh, and the Great Stuff is starting to wear off mah fingahs. :thumbs::picard:A little............
    savemoney, wildwest, milleo and 6 others like this.
  6. papadave
    Revision: Can't do that until I remove the gas line for the old DV heater. That won't happen until I can get my hands on a couple pipe wrenches, which are in brother's work van, which is downstate with him. :headbang::rofl: :lol:
    savemoney, wildwest, bogieb and 3 others like this.
  7. Stinny
    They got a pipe wrench store in town?... ;)
    wildwest and papadave like this.
  8. papadave
    I'm sure I could buy a couple, but if you've priced 'em, you might not want to buy one.....or two. :hair: I'd never use 'em again, so they'd end up in his truck like the pipe thread cutter set I just bought. :loco: :crazy:
  9. yooperdave
    C'mon man...you are downstate! :cool:
    wildwest, Stinny, bogieb and 2 others like this.
  10. papadave
    Everything's relative, isn't it? :rofl: :lol:
  11. papadave
    So, they're getting much done, despite the cold. Doubt they'll be back after today until the warmer days we have coming next week.
    Just some of the back (south) wall to do, and a small section of a gable where the bedroom roof is shorter than the main house.
    West wall..........The Forsythia is blocking the view a bit
    Well Seasoned, Steve, HDRock and 8 others like this.
  12. papadave
    North gable wall of stove room, and front porch.
  13. papadave
    North wall of main house, and you can see the lower roofline of the bedroom.
  14. papadave
    East end (bedroom) gable, and back (south) wall.
  15. Woodwidow
    Progress looks good. You will be glad when it is finished.
  16. papadave
    Thanks. House is already a bit warmer and easier to heat.
    Looks MUCH better now too.:thumbs:
  17. wildwest
  18. ironpony
    ironpony
    Mid Ohio
    looks great, So how did they do the gable before the wall, curious might be a better way?
    love ranches, no scaffolding,
    savemoney and papadave like this.
  19. papadave
    The upper part of the gable is basically offset proud of the lower wall, so instead of filling the lower part with osb to make 'em flush, they're doing the upper, then using J between the two.
    I've seen a LOT of houses up here with T1-11 with that offset and I don't understand it. Maybe they put up the end/gable truss slightly proud of the wall to allow an overhang equal to the thickness of whatever T1-11 is being used to avoid a z flashing. I dunno.
    savemoney and Stinny like this.
  20. ironpony
    ironpony
    Mid Ohio
    Kind of looked like J channel, thats why I was wondering why? Sounds like an original framing oops, set truss and forgot about sheeting/OSB thickness?? or possibly a better idea to shed water??
