Echo cs 730 hybrid
Discussion in 'Chainsaws and Power Equipment' started by Red97, Dec 19, 2017.
  1. Red97
    Red97
    Mi
    Some different to mix it up a bit here. Something besides the big 2...
    Just your average firewood saw, not a race saw or anything fancy.
    I have a build or 2 of my 590's here. Love those saws for what they are. Wake up well with some port work. Inexpensive and plenty durable.
    Why not take that chassis an add 14cc displacement.
    Started with a cs 600 (45mm bore x 37.6 stroke) 59.8 cc
    Swapped in a cs 670 jug 50mm bore x 37.6 mms stroke =73.8 cc
    Had to make a spacer to raise the jug.
    Spacer/adaptor on ex flange to change the angle, and provide a wider bolt pattern for the exhaust.
    Rather extensive muffler mod..
    Found a rod bearing to fit, allows the use of a 12mm pin vs stock 11mm used a 268 xp window piston.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
    Sent from my SM-G950U using Tapatalk
  2. Red97
    Red97
    Mi
    Made the intake port match the cs600 boot. Has the make a .080 spacer to get the boot to fit the tank proper.
    Widen the ex just out to the bevels. Lower transfer tunnels had to be blended on the ex side. Just matched it up with the window in the piston
    Squish had to be cut to fit the 268 piston.
    Had to use the taller piston, to get useable port timing
    Current #'s
    Intake 75.5
    Exhaust 100
    Transfer 115
    Squish. 023
    Pic show ing the jug and muffler, shows the leaned back angle the case has.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  3. Warner
    Cool man. I have a few echos In the garage. Mine are all stock but I like their products and warranty. Looks like some good work there
    Loon, Barcroftb, Leadfarmer and 5 others like this.
  4. Red97
    Red97
    Mi
    All put together.
    These carbs have a bypass nozzle on the h side. Nozzle with the hole in the bottom allows fuel to bypass even with the h needle allk the way seated.
    I swap em with a solid nozzle allows the carb to tune out like normal.
    Comp after a little bit of run time.[​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG][​IMG]
  5. Red97
    Red97
    Mi
    Filled the decomp hole. Have and unlimited cs 620 coil and larger cs 620 carb.
    They really seemed to help the performance with the larger displacement. And the 620 coil has more ignition advance built in.[​IMG][​IMG]
  6. Red97
    Red97
    Mi
    These videos ^^^ have 5 +tanks through unlimited coil larger carb. SOFT poplar, only sizable wood I had at home.
    First couple tanks. Different operators, limited coil and smaller carb.
    Runs well, but I think it will pick up a good bit by getting the port timing dialed in.
  7. Red97
    Red97
    Mi
    Thank you, I like em pretty good. Trying to shed some light on the under dog.
    Now If echo would just steal this saw and put it into production.. think they would have a hit.
    Light weight 70+cc good antivibe..
  8. Scotty Overkill
    Well done, Red97! I'd say I'm impressed but that'd be a gross injustice to the work done here because it's much more than impressive, you've built a cool saw, one that I'd love to play with!
  9. Red97
    Red97
    Mi
    Thank you. It has been a fun project. I think it still has a bit more left in it.
  10. Red97
    Red97
    Mi
    Video from this last weekend at a gtg. With unlimited coil and larger carb nice hard beech. 28" lw bar
  11. Red97
    Red97
    Mi
    My thoughts
    Squishband half carbon half clean leads me to believe it needs more blow down/outlet.
    pattern on the crown. Seems the transfers don't have a ton of pressure, to wash the crown especially on the ex side.
    Very slight rubbing on the bottom of the piston at tdc ex side. Probably has something to do with the long dwell time? Has time to rock? Idk
    Time to trim the spacer.
  12. Redfin
    Redfin
    central Pa
    I really need to find one of these to mess with Joe.
    Barcroftb, Eric VW, Horkn and 2 others like this.
  13. HolsatiaRedneck
    HolsatiaRedneck
    Schleswig-Holstein
    I tip my hat sir, even though that doesnt mean alot as im a 10-left-thumbs-mechanic. Nice work!
    Barcroftb, Eric VW, Horkn and 3 others like this.
  14. Armbru84
    Armbru84
    Sparta, Michigan
    I was able to run this saw last weekend and came away very impressed!! Nimble and powerful.
  15. Red97
    Red97
    Mi
    Hopefully be better in a few hours :)
  16. Red97
    Red97
    Mi
    Feels better
  17. Armbru84
    Armbru84
    Sparta, Michigan
    Sounds good and seems a little snappier even??
  18. Red97
    Red97
    Mi
    Snappier, bit more rpm in the wood. Falls off faster. But that is the trade off. Be just about right with a 24"
  19. Armbru84
    Armbru84
    Sparta, Michigan
    Gotcha. Would be interested to see if noodle as well to see how it takes that added load. What did it tac at Joe?
  20. Red97
    Red97
    Mi
    Still round 13,600. Tried noodling like the last vid. Jam instantly lol, had to rock it.
    Barcroftb, Horkn and p61 western like this.
