Mt Vernon combustion blower
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Robert Dunlap, Dec 15, 2017.
  1. Robert Dunlap
    Robert Dunlap
    Munith,Mi
    Where can I get one of these without breaking the bank? Mine locked up,so I took it apart and cleaned it up and oiled it. It spins freely now. It's not as quiet as I think it should be. It's a standard Mt Vernon not an AE.
  2. ivanhoe
    ivanhoe
    Northern Ontario
  3. ivanhoe
    ivanhoe
    Northern Ontario
    SRV7000-193 - 10-1111 G
    Is this the one looking for?
    I see why you are disgusted on the pricing, wow:picard:
    Replace the bearings in the old one for a spare, might also be cheap route to try :smoke:
  4. slvrblkk
    slvrblkk
    Northampton, PA
    Well...there are two ways of going about this. Te easiest is to order this Jakel motor:
    JAKEL INC J238-150-1571 DRAFT INDUCER MOTOR KIT 115 VOLT 3300 RPM
    Once you receive it you'll have to swap the 4 post motor base off of yours and install it on the new one. The new motor is on the right with the 4 post base already swapped
  5. slvrblkk
    slvrblkk
    Northampton, PA
    The link isn't posting.... Go to Amazon and search for that motor
  6. slvrblkk
    slvrblkk
    Northampton, PA
    The other is to buy a 1.8 amp Gleason Avery Harman combustion blower motor and use that BUT since it only a 3 post mount you'll need to drill two holes as it obviously won't line up with the 4 post mount on the mounting plate. You can reuse the one threaded post on the mount plate but need to drill the two holes and add two 8-32" screws and nuts
    BTW...don't forget to order a new 5" impeller (actual size is 5.75" I believe) right away!!! Might be difficult to get the old one off
  7. imacman
    imacman
    Denver, NC
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Thanks Pete!!!!! Since the forum change the the other week I believe posting links changed too
    ivanhoe, IHATEPROPANE and imacman like this.
  9. imacman
    imacman
    Denver, NC
    Weird, yours posted OK for a while.
    IHATEPROPANE, ivanhoe and slvrblkk like this.
  10. slvrblkk
    slvrblkk
    Northampton, PA
    Also for an FYI down the road, you can use the Fasco A120 blower to replace your convection fan. Now the A120 is a two speed motor, it's similar to the one in the CB 1200 stoves. So when you go to hook it up you're using the "high" side wires on the hook up which is the black wire. You will only be using the black and white wires. They run at the same 3000 rpm at full tilt
  11. slvrblkk
    slvrblkk
    Northampton, PA
    When I posted it it just had a big blank area where the link should have been....weird.....
    IHATEPROPANE, ivanhoe and imacman like this.
  12. imacman
    imacman
    Denver, NC
    No pic, but the blue "Jakel Inc" is the link that seems to work.
  13. slvrblkk
    slvrblkk
    Northampton, PA
    WTF. I'm not even seeing anything blue :rofl: :lol:
    IHATEPROPANE, imacman and ivanhoe like this.
  14. Robert Dunlap
    Robert Dunlap
    Munith,Mi
    Thanks for the info. That's so much better. Probably should replace the impeller/fan too. Much easier then trying to get the old one off.
  15. slvrblkk
    slvrblkk
    Northampton, PA
    Well, you'll need to get the old impeller off to use the backing plate for the new motor but if you've never had it off before, chances are you'll probaly need to cut it off or something.
  16. Robert Dunlap
    Robert Dunlap
    Munith,Mi
    Where can I get the impeller from
    IHATEPROPANE and ivanhoe like this.
  17. slvrblkk
    slvrblkk
    Northampton, PA
  18. imacman
    imacman
    Denver, NC
    ivanhoe, slvrblkk, jtakeman and 2 others like this.
  19. jtakeman
  20. Robert Dunlap
    Robert Dunlap
    Munith,Mi
