Bar talk
Discussion in 'Chainsaws and Power Equipment' started by J. Dirt, Nov 9, 2017.
  1. mdavlee
    mdavlee
    Got to be quick for deals.
  2. Cold Trigger Finger
    Cold Trigger Finger
    Easern Central Alaska
    The stump my hard hat is sitting on is an ancient yellow cedar. It was 96" at the wide point perpundicular to the face. I fell it with my 044 Stihl Madsen modified with a ProTec filter. Pulling a 34" Sugi Hara bar with Oregon 75 CK with a 7 tooth. . The tree my saw is dogged into was around 48" on the stump. Fell with the same saw, bar and chain . Chisel ground chisel chain.
    I've fell a few ship loads of timber with 4 cube saws with 30, 32 + 34" bars. And made good money doing it. 082800_114202.JPG
    The stump I'm standing on is a Sitka Spruce fell with a 372 Husky , 32" Oregon bar Stihl 3/8,063 Semi Skip. Chisel ground chisel chain . With ( get this ) an 8 tooth rim sprocket. Stump was about 50 "
    A 372 will pull a 32" just Great. A 30" is kinda perfect tho.
  3. J. Dirt
    J. Dirt
    It came today!!:faint::bug: 0C39DFA5-D4D2-4DDA-A2F4-86DF88B9A998.jpeg
    eBay find 28” used husqvarna bar and I picked up a new full skip chain too.
  4. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    Am I the only one who got excited at reading "Bar Talk?" I mean, it's Friday night. Made me thirsty. But then, I was interested enough about the long bars to keep readin'!
  5. RCBS
    :popcorn:
    Looking to upgrade my 550 bar. Started out looking at Sugi, now interested in Tsumara 18x.050 .325 (Total, I beleive?) light & tough. Thinking of giving my 2166 a 24" lightweight in .058 gauge also. Christmas has wiped out funding currently, so just doing research at the moment. :binoculars:
  6. Cold Trigger Finger
    Cold Trigger Finger
    I'm guessing the Jred2166 is a red and black version of the Husky 266.
    If so , it's a great saw. I've had some 266s. Fell a bunch of timber with them.
    It will handle a 24" bar easy pie. As I usually ran them with a 32" bar on them. It would be great if these bar outfits would make a 30" light /reduced weight bar. That would be SAWEET
    p61 western, RCBS and J. Dirt like this.
  7. RCBS
    She's a sister saw to the current Husky 365 (and 372). 70.1cc I usually run a 20" bar most of the time. I have an OEM 24", but dang she gets to be heavy with that setup. A bit nose heavy too. I think a light bar would balance perfectly at 24" possibly 28", but I have no need for that much saw.
    Chainsaw CS 2166
  8. Cold Trigger Finger
    Cold Trigger Finger
  9. jon1212
    jon1212
    Utah........ugh!
    Just make your own reduced weight bar. I picked up this 32" Power Match for free, dressed the rails, stripped the paint and got busy. I used a carbide hole cutter, lots of thread cutting oil, a right angle grinder, and a few bucks worth of two part epoxy. The inside edge of the cutouts I beveled on both sides, to act as a mechanical fastener.
    huskihl, mdavlee, walt and 1 other person like this.
  10. Cold Trigger Finger
    Cold Trigger Finger
    Which brand of epoxy did you use ?
    Looks like it is not affected by the heat.
    mdavlee likes this.
  11. Cold Trigger Finger
    Cold Trigger Finger
    I have a real soft spot for the 394/395 Husky . I've cut many millions of board feet of timber with 394s I started running 394s the first year they came out. Had 5 of them .
    p61 western and J. Dirt like this.
  12. jon1212
    jon1212
    Utah........ugh!
    Whatever Harbor Freight sells. I knew I would use a fair amount, so I went with the inexpensive product.
    huskihl and Cold Trigger Finger like this.
  13. Cold Trigger Finger
    Cold Trigger Finger
    In 1990 I swiss cheesed a 36" Oregon bar. I used carbide drill bits and a drill press. I took around 2 lbs off the bars weight. My cuttin partner looked at it when we went to work on Monday morning and said . That ain't gonna work Hugo. I said , oh ya , it'll work. Sure is nice and light too. He said OK. We'll see. About an hour later he had bucked me out a couple times already . He said , change it or go home. I ain't bucking you out again today.
    If only I had thot about epoxying the holes closed.
    I filled the holes with nuts and washers and welded it all full and ground it all flat and buffed it smooth. Then I painted the bar with Emron automotive paint.
    Sold it with a 281 Husky I wasn't running any longer.
    J. Dirt, jon1212 and p61 western like this.
