241 or 261?
Discussion in 'Chainsaws and Power Equipment' started by Farmchuck, Nov 28, 2017.
  1. TurboDiesel
    I love my 241.
    It's fast and light. I cut a lot of tops. I have a 362 for the bigger stuff.
  2. concretegrazer
    concretegrazer
    Southwest MO
    Have you had a chance to handle the new lightweight version?
  3. MasterMech
    Not yet. I should just waltz into a dealer and paw one to death.
    OhioStihl and concretegrazer like this.
  4. Fabz
    Fabz Banned
    Buffalo ny
    I own both saws ... I prefer the 241c with the ps63 picco chain ... I do have a 261c that is like new with a decked cylinder ; muffler mod ; spikes with chain catcher and runs 16” bar with picco ... also have 18” 3/8 .050 if u want that set-up ... 261 c is for sale
  5. Fabz
    Fabz Banned
    Buffalo ny
  6. Fabz
    Fabz Banned
    Buffalo ny
    I have a 261c running picco -
  7. MasterMech
    I’ve got a Picco setup for mine too.
  8. XXL
    XXL
    Ontario, Canada
    Interesting, Stihl.ca has them both listed as 10.8 lbs but that doesn't make much sense.
    I think that if you go with the 241 you would use it as intended and have a great 2 saw combo with the 044. However, if you go with the 261, i think it would become your goto saw and take on some of the 044's duties too.
    If you are limbing on the ground, you can run a little longer bar on the 261 so that you don't have to bend over as much. Easier on the back at the end of the day.
  9. Farmchuck
    Farmchuck
    Nepa
    All great info. Thanks everyone. Which one is available in a new lightweight model?
  10. dall
    dall
    West Virginia
    the 261 is the new version
    PA Dan likes this.
  11. Farmchuck
    Farmchuck
    Nepa
    Thanks Dall. So are all the new 261s lightweights or is that a special lightweight model?
  12. dall
    dall
    West Virginia
    the new version of the 261 is lighter than the first version the new version has a smaller more sleek clutch cover and a way you can tell what version is to look at the cylinder fins
    old version is perpendicular to the stroke and the new version is at a angle
    new version was started about a year ago
  13. Farmchuck
    Farmchuck
    Nepa
    Stihl website I'm looking at list three model 2 @ 10.8 lbs. & one with a quick stop chain brake @ 11.46lbs.
  14. Farmchuck
    Farmchuck
    Nepa
    Wonder if I order a new one I'll get the new design or whatever is the oldest stock in the distribution center
  15. dall
    dall
    West Virginia
    i dont think id want the quick stop version they failed on the 036 version and parts for it are no longer available
    if it was me id go into the dealership and see what they do have
    Redfin has my new one right now to port
  16. XXL
    XXL
    Ontario, Canada
    The heavy model is likely the Arctic version with heated grips.
  17. dall
    dall
    West Virginia
    im only seeing 2 the 261cm and the 261cmq which is the quickstop
    the quickstop looks to be the old version
    when they came out with the new version they dropped 1/2 pound from the saw
  18. Farmchuck
    Farmchuck
    Nepa
    There is the regular 261 as well correct? Fall did you get a 261 or 261cm?
  19. dall
    dall
    West Virginia
    i dont think they make the non mtronic 261 anymore but i could be wrong
    PA Dan likes this.
  20. Farmchuck
    Farmchuck
    Nepa
    Oh okay. Thanks
