Chimney Cleaning
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Nov 25, 2017.
  1. wildwest
    Hmm, it works on my PC, but I have clicked on other Amazon links here that just take me to Amazon home page. Interesting.
    SHEKAR
    [Slim 7mm Dia.] USB Endoscope Borescope Waterproof Inspection Camera Snake Camera for PC Notebook and Andorid Deivce (22.9ft Cable)
    35 customer reviews
    | 10 answered questions
    Price: $10.00 Free Shipping for Prime Members
    Amazon Prime
    Flatlander Pete likes this.
  2. thewoodlands
    thewoodlands
    It looks good Kim, i after_cleaning.jpg s this a crack in the pipe or just nothing.
    Flatlander Pete and Thor like this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    That is the tee; this is trying to look up the chimney from the bottom. So anything below the tee is not really that dirty. I might try getting a photo above the tee.
    Flatlander Pete and thewoodlands like this.
  4. MightyWhitey
    MightyWhitey
    "Paralysis by Analysis" for Kimberly!!!!:headbang::doh: If your stove glass is relatively clean, and the stove bricks are relatively clean, and the chimney cap ain't plugged..................just sweep the damm thing and call it good.
    If'n you're worried; sweep again in a month, that's what I did my first year burning to put my mind at ease.
  5. Kimberly
    Kimberly
    The Kangaroo State
    You are not being very nice and you really don't understand my question. It appears that the chimney AFTER I CLEANED IT might have some harder (creosote maybe?) left on the interior of the chimney. I was asking if the soot-eater thingy would knock this off or not; would it leave the chimney cleaner? I figured those with the soot-eater might could possibly answer this question. If you don't have the soot-eater then you probably cannot answer this question.
    Flatlander Pete and wildwest like this.
  6. brenndatomu
    I'm saying almost no non pro cleaning tool will not take off much, if any, heavy stage 3 creosote (the wet, or heavy, or tarry, or shiny stuff) But many non pro tools (including SE) will take off what you have laying on the deck there...
  7. MightyWhitey
    MightyWhitey
    My point is that you continually look at the minutia and miss the "big picture". Even when it's told to you time and again. Remember your Madison hinge thread???? IOW's; you look at the blade of grass, and miss the lawn......................you see the bark on the tree, but miss the forest..........................
    You got some flaky brown/black, coffee grounds looking stuff out of your chimney; which is normal..............................you weren't able to clean the horizontal section of your set up..........................continue burning and clean the whole thing next time when you get the tools.
    So I'm not nice....................
  8. yooperdave
    Look at it this way...the ones on here that have a soot eater probably don't have the creosote to begin with.
    So it's hard to say if the soot eater will remove the creosote.
    Was that nice and precise and concise?
    I can type it twice!
    My advice would be to check the price and then decide what type of cleaning/sweeping device will suffice without you having to make too much of a sacrifice.
  9. Eric VW
    Yer such a softee......:rofl: :lol:
    Must come with age-:eek:
    :handshake:
  10. Chvymn99
    Just buy the soot eater, it's a one time deal. Just have to replace strings maybe every 4 or 5 years... piece of mind is what you and everyone wants... no guarantees in life, the best we can do is burn seasoned wood and be vigilant...
    bocefus78 and brenndatomu like this.
  11. BDF
    BDF
    The answer is no. The plastic strings on a soot eater will not attack that hard, glassy creosote at all, whatsoever. They will not even polish it up. :) To remover that stuff takes much more aggressive cleaning methods that often not compatible with modern, stainless steel lined chimneys. The most effective way I have seen is a set of chains rotating on a drill- driven metal disc; sort of like a soot eater gone nuclear. But they would beat the S.S. liner to death.
    As I previously recommended, Anti -Creosoot is a mild acid that will attack and break down those hard deposits without apparently harming anything else. A little chemical treachery and cunning to replace stone- age hacking and chipping. :)
    Brian
    VOLKEVIN likes this.
  12. VOLKEVIN
    VOLKEVIN
    Shenandoah Valley, Virginia
    brenndatomu likes this.
  13. yooperdave
    Yeah, and it seems I've been getting a lot of age, lately!
    Eric VW and Chvymn99 like this.
  14. Suburban wood snob
    Suburban wood snob
    Milwaukee
    damm British.
    MightyWhitey likes this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    I haven't returned to the chimney yet. I forgot that I can take the bottom section of chimney off so that will make it easier for me to see into the chimney. Plus, that gives me another foot to get into the chimney.
    $50.00 is like two tanks of petrol. I was going to take time to go to Lowe's and get what I needed to extend my chimney cleaner but things get in the way. I will go out tomorrow; DG has coffee on offer and with an extra $1.00 off manufacturer's coupon.
  16. Suburban wood snob
    Suburban wood snob
    Milwaukee
    If you are looking to save money on a sweeper, look on Craigslist. The pole sections are usually available cheap online, and it's not like they wear out. A new bristle is like 12 bucks at menards... Combine that with a second hand pole and Bob's your Uncle.
    Kimberly likes this.
  17. bocefus78
    bocefus78
    $50 May Be Alot Of Money, But You Sure wont Be Worrying About Coffee If Your Place Burns Down. This should be top of the priority list.
  18. Kimberly
    Kimberly
    The Kangaroo State
    That is true. Which is why I wanted to know if my cleaning is doing a satisfactory job or not. I looked at the anti creosote stuff and if that stuff does work, I am going to invest in it as well as doing chimney cleanings.
  19. Skier76
    Skier76
    CT and SoVT
    I've got a similar setup; exterior chimney (8") with a bottom clean-out. I use an 8" poly brush with Rutland flexible rods. Takes under 30 minutes to clean it out and have it all back together and the brush/rods taken apart.
  20. Woody Stover
    Woody Stover
    Southern IN
    Right, like a "boot" or a "Laurie." :)
