? 4 New England users PART DEUX
Discussion in 'The Pellet Bag' started by Pete Zahria, Nov 22, 2017.
  1. Pete Zahria
    Pete Zahria
    New Hampster
    I was not clear enough I guess...
    It wasn't whether or not you liked softies...
    It was what BRAND of softies do you like, AND are available to you,
    and IF it was a good blend, what brand were those..
    I'm looking for BRANDS... not necessarily your "type" preference..
    Thanks.... sorry I was not clear enough in the original question..
    :emb:
    Dan
    Russell, CleanFire and slvrblkk like this.
  2. jtakeman
    Nope, You weren't. Be more specific and ya might get what ya be looking for. Another suggestion is once you get a few brands. Post a poll and see which comes out the winner.............
    Softies.......
    La crete's - Vermonts - North Country - Vandies Plat - Orford(AKA Eagle Valley) - Lg's - Easy Blaze. Oops forgot Spruce pointe.
    Hardwoods..........
    Cubex - Thurman - Hamer - Ambiance - Somersets
    Blend.........
    MWP - Energex - Dry Creek - Easy Blaze - NEWP(but only from the NH mill)... Several others but tooo lazy to type!!
    Another FYI. Dry Creek has super softies and a super hardwood available(or used too). Don't see them locally, But I have burned them in the past and they did pretty well.
  3. Dpopps
    Dpopps
    MI
    I'm not in new England so.....
    Russell, CleanFire, jtakeman and 3 others like this.
  4. Pete Zahria
    Pete Zahria
    New Hampster
    Well... often times when you are writing something, you know exactly what you mean
    but the words don't come out for others to know.
    Then sometimes, no matter what you write, some don't get it regardless..
    Have had that issue before on the website..
    As for your favs, those are pretty much what we have now... (no EZ's, and no more Pointes..)
    I'll let you do that!
    Dan
    Luneyburg, Russell, CleanFire and 2 others like this.
  5. Douglas Middleton
    Douglas Middleton
    Valley of the Sun in AZ
    Orford is Eagle Valley???...I always thought Orford was a hardwood pellet...and I know for a fact Eagle Valley doesn't bag any hardwoods.....am I wrong on this?
  6. daffonce
    daffonce
    Uxbridge MA
    Orford produces a hardwood. They bag a softwood that someone else produces. I havent seen em in 2 years now.
    Russell, CleanFire, ttdberg and 2 others like this.
  7. Pete Zahria
    Pete Zahria
    New Hampster
    Might be LG.
    Dan
  8. Douglas Middleton
    Douglas Middleton
    I know that Eagle Valley last bagged Orford about 4 years ago...but Eagle Valley is 100% softwood out of BC...so I think you might be referring too another version of Orford....maybe someone can clarify.....
  9. slvrblkk
    slvrblkk
    Northampton, PA
    IIRC BT maybe had both flavors of Orford? It was one of those places up there....
    For Dan....for the price down here the EZBB are a very good pellet for the price here....but I do love other softies but just can't get the ones I like all the time.
  10. Pete Zahria
    Pete Zahria
    New Hampster
    Thank you.... have heard they are pretty good...
    I did look into them.
    problem is, we don't have :makeitrain"
    Dan
  11. slvrblkk
    slvrblkk
    Northampton, PA
    Th blend and the softie EZB are very, very good but I'm just a tad more partial to the blend....
    Russell, CleanFire, will711 and 3 others like this.
  12. Orson_Yancey
    Orson_Yancey
    Portsmouth, NH
    Blends: MWP, Energex=FSU=Nature's Own
  13. daffonce
    daffonce
    Uxbridge MA
    Last i saw orford softies in the ne was the year if the fire sale. I picked up 1-2 tons @ $199 a ton. Since then i havent seen them around here. I can still get the hardwoods. According to orfords website back then they produced their own hardwood, but bagged someone elses softwood in orford softie bags. Not sure who. They seeemed very similar to a bc softie.
  14. CleanFire
    CleanFire
    Greetings Dan,
    LaCrete, LG, Vandy Plats, Olympus DF - in order of $$$ vs. heat output:
    1.6 lb/hr (optimal setting for stove, room air temp. output (probe) measured 1/2 " from center lowest Heat Exchange tube exit)
    Edit: optimal setting = highest room air output vs. stack flue exit temp., temp. difference at this setting is 50-55 F, e.g. room air exit = 200 F, combustion probe temp. = 250 F.
    Vandy Plats = 190-195 F
    LG *Satisfaction bagged = 200-205 F
    LaCrete = 210-215 F
    Olympus DF = 220-225 F
    All readings avg., temps. taken 1 hour after stove up to operating temp. (stove fully heat-soaked), combustion air fine-tuned for each brand, to provide clean burn.
    Heat output vs. cost - LaCrete wins in the stove here.
    * Spruce Pointe was the best value vs. Heat output (195-200 F), but 4 cups of fines/breakage per bag was a bit excessive, on the (5) test bags ran here last season.. Got tired of vacuuming the pellets, quickly.
    Hope the feedback is helpful to you,
    Regards, Rob
    PelletHound, Russell, ttdberg and 3 others like this.
  15. jtakeman
    Yep, So I'm told!!
    BT gets them in from time to time. This year is because some of the others are limited or MIA.
    slvrblkk, Russell and CleanFire like this.
  16. IHATEPROPANE
    IHATEPROPANE
    Softwood =Vermonts
    Blend=MWP
    Hardwood=Somerset
    pell it, slvrblkk, Russell and 4 others like this.
  17. subsailor
    subsailor
    Winthrop, Maine
    Not much of a selection here. MWP for a blend, Lacrete for softies. Tried some Crabbe softies this year and not impressed.
    slvrblkk, Russell, CleanFire and 2 others like this.
  18. vtktm802
    vtktm802
    Hyde Park, Vt
    North Country
    LG's
    LaQrete
    North Country has a slight edge over the LaQrete's....... :Djust say in, burn clean and hot.
    Russell, CleanFire, ttdberg and 3 others like this.
  19. Luneyburg
    Luneyburg
    Hills of Central Mass
    Softwood - Eagle Valley, 802 Wood Pellets, North Country
    Blend - Fireside Ultra
    100% Hardwood - Northern Max, Ambiance
  20. jtakeman
    Sure, Lemme know when your ready!! I can do one for each(soft-blend ect) if need be.
    Edit: Had sometime, So I tallied the Softwood brands mentioned and started a poll on them!!
    Poll: For your favorite Softwood brand.......
    CleanFire, Pete Zahria and slvrblkk like this.
