Quad Castile - thermocouple??
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by PoolguyinCT, Nov 20, 2017.
  1. don2222
    don2222
    Salem NH
  2. PoolguyinCT
    PoolguyinCT
    Now I have ignition fire but can't sustain burning/heating fire
    imacman likes this.
  3. badbob
    badbob
    And what is making the fire die,does the auger quit running?(lack of pellets) or combustion blower die?
  4. PoolguyinCT
    PoolguyinCT
    It stops dropping fuel. No amber light & I did thermocouple replacement last
    Night.. I really appreciate your input, they say us poolguys are a pain to deal -
    I bought stove from a dealer that doesn't know his stove product line from a water balloon.. (don't know where I pulled "from a water balloon" out of but I think I'll keep using it )
    Thanks bob
    imacman and jtakeman like this.
  5. badbob
    badbob
    OK if the "call" light is not coming on,then auger is not being turned on.Way I see it only 2 things,contacts in thermostat(or wiring to thermostat),acting up,or control box acting up.You could unhook thermostat and put in a jumper wire for a test.Bedtime now,see ya tomorrow.
  6. don2222
    don2222
    Salem NH
    Check that the Thermocouple Red Wire is grounded properly or the Thermocouple will not function properly. See attached Quadrafire Tech Sheet.
    jtakeman and PoolguyinCT like this.
  7. PoolguyinCT
    PoolguyinCT
    I just popped on the above - since my lights are not agreeing speaking with my harness & switches.. I could have popped with an other vendor for 189$ but these guys will take a return on this product.
    & the other guy in CT so that's another 6.35% tacked on..
    I splurged on FedEx & hope to have this Friday.
    The dealer wanted 360$ and me to pick it up & install...
    jtakeman and imacman like this.
  8. badbob
    badbob
    You did try bypassing the thermostat(room thermostat)? Although it really sounds like the box is the problem,Hope you have it on a surge protector.
    jtakeman, imacman and slvrblkk like this.
  9. badbob
    badbob
  10. PoolguyinCT
    PoolguyinCT
    Repair is a little south $ of new board...
    this MF quad is driving me nuts[​IMG]
  11. PoolguyinCT
    PoolguyinCT
    I pulled the control box cleaned a ton chit out.. switched to 4 from 6 (why not at this point)
    I get great start up fire - now get proof of fire red light.. - I hear & see auger motor shaft engage, but now pellets stop drop when I get into past initial fire.
    I'm fixing to pull the dang auger now... but it drops plenty for ignition fire.
    jtakeman likes this.
  12. badbob
    badbob
    What is the yellow in first picture? is it connected to auger motor?
  13. badbob
    badbob
    Sure looks like a burned up auger motor capacitor
    PoolguyinCT likes this.
  14. PoolguyinCT
    PoolguyinCT
    Yes it is -- by why dropping fuel at ignition sequence.. that is what has me scratching my coconut
  15. badbob
    badbob
    Yea they can cause weird problems.They make a plug in kit for them.
  16. badbob
    badbob
    The part number is srv230-1920,but if you cannot get one fast,here is the newer specifications,electronics places have them. VWtRlwa-H54rcXcNUVL3rGxo0FAGG1y1A3y0hB-EPoG-RXEXFGcoi81n_i_0pW2NNIxbYhxs=w1024-h674.jpg
  17. PoolguyinCT
    PoolguyinCT
    Cool - is could my auger be reversing between start up & heat fires, hence only start up pellets ... I swear next house natural gas!!!
  18. PoolguyinCT
    PoolguyinCT
    Thanks for the electronic store top.,
    This is my old dead shot auger motor... is there a play? For a capictor switcharoo ?[​IMG]
  19. badbob
    badbob
  20. badbob
    badbob
    there was a complete kit,motor,harness and all,then later just the capacitor harness.You could crimp in your old cap to see if it works,but that might have been a problem with your other motor.Will leave some reading info. Wiring for feed motor on Quadrafire Castile Pellet Stove
    PoolguyinCT and jtakeman like this.
