It takes two hands to operate my stove door
Discussion in 'Modern EPA Stoves and Fireplaces' started by Kimberly, Oct 28, 2017.
  1. Kimberly
    Kimberly
    The Kangaroo State
    Too late to return stove to Lowe's.
    HDRock likes this.
  2. Kimberly
    Kimberly
    The Kangaroo State
    I have to leave for now; I will check this when I return later this evening.
    HDRock likes this.
  3. Kimberly
    Kimberly
    The Kangaroo State
    OK, I inspected the hinges again because someone thinks the door is up too high on the stove. It appears the top hinge may be welded too high. Look at the photos and see what you think. I will label which hinge is which for the photos. I will send these photos to ESW and see what they say.
    First photo is the top hinge; notice how the door part of the hinge is sitting flush with the stove part of the hinge.
    This is the bottom hinge. Notice there is a gap between the door part of the hinge and the stove part of the hinge. This may be all that is needed for the door to hit the damper knob.
    concretegrazer and papadave like this.
  4. Kimberly
    Kimberly
    The Kangaroo State
    I also noticed a small gap; enough to see light from the fire through it; on the hinge side of the door. I thought it seemed that the fire was not damping down as much with the damper all the way closed; although it is not a huge gap, just a minor one.
  5. papadave
    Hmm, it does look like the top hinge is holding the door up.
    Maybe someone got a bit lazy when placing the jig while the body hinges were being welded.
    Without knowing the exact procedure, it's all conjecture.
    concretegrazer likes this.
  6. concretegrazer
    concretegrazer
    Southwest MO
    Also looks to have a bit of a burr on the bottom of the door side of both.
  7. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I noticed that and that is probably why the door gets hard to open when you go past 90 degrees; however, that would be easy enough to grind off. Moving the door hinges is not.
  8. concretegrazer
    concretegrazer
    Southwest MO
    How much sealing room do you have for the door on the face of the stove?
    I'd probably file the hinges down some if you have the room. Might be able to use a bigger gasket rope to fix the gap.
    papadave likes this.
  9. Eric VW
    Based on this pic-
    You could eat down a little of the [bottom surface of] top hinge....or not. That’s what I would do, 5 minutes and done.
    CoreyB and papadave like this.
  10. saskwoodburner
    saskwoodburner
    Just a thought if you were to trim down hinge metal (either the door or the stove) is how would the door handle/latch between door and stove be affected? If at all?
    papadave and concretegrazer like this.
  11. huskihl
    huskihl
    That spring handle for the damper control, it moves in and out?
  12. Kimberly
    Kimberly
    The Kangaroo State
    Yes, I could ground down the top hinge; making it less tall, the amount of the gap at the bottom but that is outside the fact that ESW's worker put the hinge on in the wrong place.
  13. Kimberly
    Kimberly
    The Kangaroo State
    Looking at the amount of the gap on the bottom hinge, I would not say a little. In the photo; have not took a scale to it yet as the stove is hot, that gap appears to be significant.
  14. concretegrazer
    concretegrazer
    Southwest MO
    They messed something up for sure. Sounds like they're not going to be of much help though. So you're gonna have to fix it yourself.
    CoreyB likes this.
  15. Kimberly
    Kimberly
    The Kangaroo State
    Yes, it is attached to the rod; to be used for the damper position but also to rotate to operate the Automatic Air Setback (AAS).
  16. Kimberly
    Kimberly
    The Kangaroo State
    Oh, you don't know me :D; once I latch on, I don't release. :rofl: :lol: I will post my Tractor Supply story that started back in May and was just recently settled to my satisfaction.
    Woody Stover likes this.
  17. papadave
    Here's what may be the simplest "solution".......grind down enough of the top of the door to clear the rod. Make it nice, repaint, and call it gooder.
    I doubt pulling a bit of material off there would compromise the integrity of the door.
    Eric VW and concretegrazer like this.
  18. papadave
    Tell everyone it's a "feature", not a bug. That's what Microsoft does. :rofl: :lol:
    Eric VW, concretegrazer and Kimberly like this.
  19. huskihl
    huskihl
    Is it possible to bend the lever up out of the way? Like slip a cheater pipe or box end wrench over the end?
  20. Kimberly
    Kimberly
    The Kangaroo State
    Take a look at this photo again. That would be a large grove in the top of the door to accommodate the spring knob.
