Wood cover
Discussion in 'The Wood Pile' started by NYCountry, Oct 29, 2017.
  1. NYCountry
    NYCountry
    Mohegan Lake NY
    Has anyone ever used a liner from a pool to cover their stacks? A friend of mine has one but just was curious about it, i think it might hoold up well what are your thoughts
  2. Midwinter
    I'd try that for sure!
    Backwoods Savage and NYCountry like this.
  3. FatBoy85
    FatBoy85
    Washington State
    Had this come up in the summer but no way to transport it home! Massive rolls though. 8-10 feet wide and about 75 feet.
  4. MikeInMa
    If I had it, and didn't mind a bright color, then I'd use it.
    Should cover your vault just right, with some trimming.
  5. Midwinter
    Now and then used liners pop up on Craigslist, maybe springtime will bring one my way.
    Backwoods Savage and FatBoy85 like this.
  6. bogydave
    Probably heavier duty than a tarp
    Give it a go
    (With pics of course) :)
  7. Gasifier
    So. What would you do? Would you cut it to correct width so you could cover top of stacks and just a little ways down? Allow for air flow.
  8. Sconnie Burner
    Sconnie Burner
    Western Wisconsin
    I came across billboard sign tarps that were 14x44 for $25 each. I'm giving one a shot to see how it does. I cut it in half and have it doubled up over my pile to burn for this year. It might get a bit rigid and hard to finagle around once it gets real cold outside though. I would think its similar to pool liner. We'll see how it does.
  9. bogydave
    What about pallets on top
    Then the pool liner/tarp ,
    nailed/stapled to the pallets ?
  10. HDRock
    I have looked for them to use for covering stacks, every time I find cheap used one they get snatched up before I can get em .
    I think they would work good , just cut em to size ya need
  11. billb3
    I've wanted to try a pool wall, just on top and also as roof material.
    I had one but can't remember what I did with it.
    I recall rolling it up, putting a band around it. Rolling it because it was a lot heavier than I expected but not where I put it.
    People give away an above ground pool every now and then but I never have the time at the time to go and disassemble one again.
  12. Backwoods Savage
    I've not used any but wood not hesitate to use them. I'm also sure others on this forum have used them but can't say who.
    HDRock and NYCountry like this.
