I'm 'Bout Ready to Toss My 661 in the Trash!!!
Discussion in 'Chainsaws and Power Equipment' started by Ralphie Boy, Sep 7, 2017.
  1. dall
    dall
    West Virginia
    I like to have spares lol
  2. clemsonfor
    Wj69 is the carb on those saws. I think there is a few of them, different models but it is on the saw. The 650/660 have it for sure. I have one on the 650. I am positive of that because when I rebuilt it from the box of parts after i got it from being crushed I had a slight issue with the wj69 and had to fix it. Not a kit, but a fuel inlet was broken.
    blacksmith likes this.
  3. clemsonfor
  4. dall
    dall
    West Virginia
    The carb I showed is a non mtronic 661 carb
    Shows zama on it
  5. dall
    dall
    West Virginia
    Those are the ones definite dave sells
  6. clemsonfor
    Yea zama china. I guess its the wj69 copy
  7. 94BULLITT
    94BULLITT
    Frederick County, VA
    Zamas are made in china.
  8. clemsonfor
    Yea.
  9. dall
    dall
    West Virginia
    It's not a wj69 copy of you look at the plastic linkage for the choke you will see the difference
  10. Moparmyway
    Moparmyway
    New York
    Most every 661 that I've had go past me that had problems needed the wiring harness either soldered or replaced with a new one.
    I actually had a couple of multimeters hooked up with clips a while back, trying to learn how to trick out the M-tronics with a regular carb.
    In 2 minutes without doing anything but touching the harness, the reading on the meter changed a few times. Once soldered, it was rock steady
    Dancan, huskihl, Chvymn99 and 10 others like this.
  11. clemsonfor
    Again a process that would add $0.50 to the final product and stop several problems but it was not done. I'm sure the robot could have been sent up with heat and solder and it all been done with the crimp:picard:
    blacksmith, Moparmyway and 94BULLITT like this.
  12. Ralphie Boy
    Ralphie Boy
    Rabbit Hash, Kentucky
    Well I used the 661 on Saturday and.....
    It starts!:dancer:....well most of the time anyway.:picard: Now the problem appears to be flooding. About every 5th. start she won't fire and you can smell fuel, not something you could smell before.
    A couple of fellow hoarders from this site, who are 50 pounds heaver and a whole lot meaner than me, pegged the throttle and drop started it and got her to light off on the second or third pull.
    I though the intake boot had been replaced, but a review of the service records tell a different story. So she's at the shop again this morning with instructions to replace the intake boot.
    In any event, it's better than it was and I'm betting the boot fixes it.
    And so it goes....
  13. Redfin
    Redfin
    central Pa
    Or one of these.:D Mating a coil and flywheel from 1122 is a bit of work but nets a completely adjustable/unlimited 661. IMG_2677.JPG
  14. 94BULLITT
    94BULLITT
    Is the flywheel a direct swap?
    Sent from my SM-G950U using Tapatalk
    Eric VW, leoht and clemsonfor like this.
  15. Redfin
    Redfin
    central Pa
    No. I used a poly flywheel and had to surface the rear circumfrence to clear the case.
  16. 94BULLITT
    94BULLITT
    Does it fit the crank without modification?
  17. Redfin
    Redfin
    central Pa
    Yes. Crank tapers are the same.
  18. MasterMech
    Nice job!!!
    Eric VW, Moparmyway and clemsonfor like this.
  19. definitive dave
    definitive dave
    Columbus, Ohio
    Redfin builds a wicked good MS661 :)
  20. blacksmith
    blacksmith
    central Pa
    Yes he does I have personally run some of the ones that he built! Redfin helped me put a tunable WJ-69 carb on my 661 at the GTG this weekend and so far so good, it runs excellent! Think about it Ralphie Boy !
