hows you thread
  1. wildwest
    Black, positive on bottom. Green negative bottom.
    Stump Shot, p61 western and huskihl like this.
  2. wildwest
    Red wire is spliced, one goes to starter and one to (we don't know).
    Stump Shot likes this.
  3. huskihl
    huskihl
    Ok. So you have it wired in series. 24 volt system. To use a 12 volt charger, you'd need to hook the leads to + and - on only 1 battery at a time
    Make sure what you're hooking it up to is a 24v system
  4. concretegrazer
    concretegrazer
    Southwest MO
    So your in series 24v. I'm betting on a bad cell in the old battery. Or a corroded cable
  5. concretegrazer
    concretegrazer
    Southwest MO
    My beast is alive.
  6. wildwest
    Is this the problem ? Or are we just hooking the leads on wrong?
    Stump Shot and huskihl like this.
  7. wildwest
    M35
  8. concretegrazer
    concretegrazer
    Southwest MO
    Tested with a voltmeter? Yes.
  9. concretegrazer
    concretegrazer
    Southwest MO
    You need to separate them and charge 1 at a time or 2 12v chargers or 1 24v charger.
  10. wildwest
    ITS ALIVE and running muahahaha. Thanks to all of you "hows you" guys!!
    (his truck on one batt and the charger on the the other batt)
  11. p61 western
    p61 western
    Northern California
    Good evening fellas.
  12. wildwest
    We used to have a tool, I will order another one. The thing with multicolor balls in a tube?
  13. concretegrazer
    concretegrazer
    Southwest MO
    Some do. A battery hydrometer is what your after.
  14. TurboDiesel
    Is this WWW's new work truck? :dex:
  15. Armbru84
    Armbru84
    Sparta, Michigan
    I always tell myself I need one of those.
  16. p61 western
    p61 western
    Northern California
    Yep +1 I would like to have one for sure.
  17. wildwest
    He's still in his unleaded work truck, he bought this from a neighbor that moved away, we don't want to be snowed in again like last spring.
  18. huskihl
    huskihl
    Speaking of needing one of those, how is the grinder you picked up from TSS?
  19. wildwest
  20. TurboDiesel
    :eek:
    that should do it! :handshake:
