Quadra fire 1200 newbie
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by tammysteve1971, Sep 3, 2017.
  1. tammysteve1971
    tammysteve1971
    Screws are out. So does the whole top panel come off
    Sent from my SM-S820L using Tapatalk
    IHATEPROPANE likes this.
  2. tammysteve1971
    tammysteve1971
    Ok.it's going to be a long day
  3. tammysteve1971
    tammysteve1971
    I don't like messing with electronic parts but it has to be done
  4. tammysteve1971
    tammysteve1971
    Trying to get it started
  5. tammysteve1971
    tammysteve1971
    Auger isn't moving
  6. tammysteve1971
    tammysteve1971
    Auger isn't packed full off crap
    IHATEPROPANE and imacman like this.
  7. tammysteve1971
    tammysteve1971
    They were mushy and caked in
  8. tammysteve1971
    tammysteve1971
    Does the auger need pellets to start. We cleaned it all out and still not moving
  9. tammysteve1971
    tammysteve1971
    Does it need pellets to start
  10. tammysteve1971
    tammysteve1971
    Everything is cleaned. Auger still not moving
  11. imacman
    imacman
    Denver, NC
    as we mentioned before, you probably have to connect the 2 stat connections together if you didn't get a one yet. Otherwise, the control board thinks you're not calling for heat.
    If you want to make sure the auger motor is working, try making a power "jump" lead to put 120V to the motor directly. Make sure stove is unplugged before you do that, and remove the power connections from the auger motor first too. A lot of us have made something like this out of an old lamp cord to do testing of auger motors, blowers, etc:
    IHATEPROPANE and will711 like this.
  12. tammysteve1971
    tammysteve1971
    Doing that now lol
  13. imacman
    imacman
    Denver, NC
    Also, if the front door isn't sealed (broken or missing glass), there is probably a vacuum switch that won't close to turn the auger on.....hence the need for the power jumper I mentioned above.
    Most pellet stoves have this saftey feature so the stove won't continue to feed pellets if the door is left open or there is a large vacuum leak. The exhaust blower must cause a low pressure in the firebox to allow the auger to run.
  14. tammysteve1971
    tammysteve1971
    Motor is bad
  15. imacman
    imacman
    Denver, NC
    Did you remove it from the stove to test it?
  16. tammysteve1971
    tammysteve1971
    Yes. Our friend is loosening it up to see if it is seized
  17. imacman
    imacman
    Denver, NC
  18. tammysteve1971
    tammysteve1971
  19. Russell
    Russell
    South Coast , Massachusetts
    Very good info on the vacuum switch . When I was cleaning that area yesterday I was wondering about that .
    Sent from my Moto G (4) using Tapatalk
  20. imacman
    imacman
    Denver, NC
    Does that include shipping? The one I posted has free shipping.
