  1. Earl764
    Earl764
    CT
    Loving this weather.
  2. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    Frost this am!!!
    IHATEPROPANE, slvrblkk and bogieb like this.
  3. jtakeman
    :eek:
    We were close at 39ºF............ We'll need jackets on the water this morning!! :shiver:
    :seasoned:
  4. bogieb
    Turned on stove again last night. 38* was the low this morning. Have almost run out the little bit of pellets left in the hopper from last year. May see if there are more old pellets in the basement stove's hopper and put them in the P43 before I start opening bags.
    PelletHound, IHATEPROPANE and imacman like this.
  5. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Not so fast on the done it right. The lot is not good for much in the way of fruit trees we lost one of our apple trees and almost lost both of them. Have problems with them wanting to tip over due to the soil conditions and we won't even mention the fact peaches are iffy in Maine. I don't have a clue about the plum tree, as the nursery we got it from doesn't carry them anymore. The expensive trees are the ones we have had the most trouble with the cheapo Wall mart end of season ones have been no trouble at all. The boss made a mistoke on the pears and as a result we have an overage in that area and one full sized tree to go with our dwarf trees.
  6. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    One other thing I dug up enough 60 lb plus boulders to last many lifetimes. I tried to plant a row of cedars and I could only roll one stone out of the way, I estimate it is over 300 lbs I couldn't get that one out of the hole. Got me an extra large pry bar. Ah for the tools of ignorance. Got a full supply of them.
  7. slvrblkk
    slvrblkk
    Northampton, PA
    :thumbs:
    IHATEPROPANE, imacman and will711 like this.
  8. will711
    will711
    Pocono Mts.
    IMG_0330.JPG Sitting on my azz watching the fire :cheers:
    savemoney, bogieb, slvrblkk and 4 others like this.
  9. imacman
    imacman
    Denver, NC
    UNLIKE!!! :eek:
  10. wildwest
    bogieb, slvrblkk and IHATEPROPANE like this.
  11. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  12. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
  13. ttdberg
    ttdberg Pellet Pig
    CT
    37 degrees here this morning. After it warmed up a bit, we had perfect weather today, cool and sunny all day. Did a load of yard work and cleaned the flue pipe as well.
  14. slvrblkk
    slvrblkk
    Northampton, PA
  15. IHATEPROPANE
    IHATEPROPANE
    I think it means you are gonna like this winter.
  16. bogieb
    You beat me to it
  17. bogieb
    Going back thru pictures to find my earliest serious burn time of the season (which is this year on 8-31-17), I found a picture from May 2014. It is hard to see progress when it is slow, but this just made me feel good about what I can accomplish.
    May 2014: The used Englander that lasted a whole month (that fall - not hooked up in this picture). I had torn out walls to find there was an 8-9" gap from the plywood to the ceiling so I scabbed in custom cut pieces, caulked, insulated. Then I waited for new windows to be installed, late July of 2014, before I installed vapor barrier, sheetrock and painted. The Englander stove was installed September of that year (the St. Croix was installed in November of that year).
    Now (picture taken a few moments ago) on my 3rd main floor stove (St. Croix was great but hopper not big enough and the P43 works much better in that space). Last winter I finally trimmed out the window and put up blind. I then decided to take out the table and put in coat area. Yeah, the FHW system is still an eyesore but otherwise this section is finished.
  18. StEarl
    StEarl
    millinocket, maine
    Stocking cap for my morning walkies.
    imacman, bogieb, IHATEPROPANE and 2 others like this.
  19. jtakeman
    Pay no attention to them, They always lie!! :rolleyes:
    Maybe I should tune up dat sn*wblower this weekend!! :whistle:
  20. will711
    will711
    Pocono Mts.
    IMG_0333.JPG Breakfast
    gbreda, savemoney, slvrblkk and 9 others like this.
