No time for a woodshed...need a cover strategy for this season's wood
Discussion in 'The Wood Pile' started by Rangerbait, Aug 15, 2017.
  1. Rangerbait
    Rangerbait
    Shepherdstown, WV
    I'm still neck deep in the project to install my wood stove, and am not going to have the time to get to build a wood shed like I had originally planned...my wood hoard consists of 4 partial Holz Hausen, two of which will be used for this season. I am considering just building a quick 4x4 frame around the two I'm using, with a metal roof and slats for the sides, and figure I'll bring .5 cord into the garage for my ready pile...any other suggestions?
  2. blacksmith
    blacksmith
    central Pa
    Reclaimed rubber roofing from your local demolition company works nicely and it doesn't get all tore up from the wind like a tarp does! Simply fasten it with some deck screws and washers directly to your stacks. Also place a couple of larger rocks on top to keep the wind from flapping and tearing where you have it screwed down. This will last you for years to come!:thumbs: So keep on splitting and stacking:stacke::stacke::axe::axe:
  3. MikeInMa
    Any kind of flexible material will sag to the middle of your round stacks, as indicated in your picture. At least, it looks like it would sag. You'd want to raise the middle of your stacks to more of a dome and less of a bowl. If no roofing rubber is availsble, then tarps would work for a season or two. First few dome pallets to toss on top to hold it down. But you need to get those stacks to shed water first.
  4. Jon_E
    Jon_E
    Southwestern Vermont
    That's a tough one. I am assuming you will be using those for this winter's firewood? If it were mine, I would just throw a tarp over each one and secure the edges somehow, do it right before you get snow. The wood will still continue to dry out as long as it is not sealed up tightly. I am not a fan of holzhausens because once you start getting into them, there really is no good way to cover them up. The simple wood shed (see the one in my avatar to the left) is 8' deep by 16' wide (each bay is 8x8) and holds 6 cords when full to the roof. It's just banged together from rough sawn 5x5 and 4x4 pine and a bunch of Timberlok lags. Metal roof on 2x6 rough rafters.
    blacksmith, Eric VW, Horkn and 8 others like this.
  5. Rangerbait
    Rangerbait
    Shepherdstown, WV
    My plan is to keep my seasoning wood in HH configuration since it looks badass, and then move the upcoming season's wood into the shed around mid-September. Just didn't get around to doing it this year since the stove project took a good bit of time, and I'd rather do some recreating with my rugrats once this work is over.
    I wonder if making some sort of tee pee over the HH might work?
    blacksmith, Eric VW, Horkn and 3 others like this.
  6. HDRock
    Used pool covers on craigslist , I have seen a lot of round and ovel ones on there
  7. DaveGunter
    DaveGunter
    EZ-up type canopy
    blacksmith, Eric VW, Horkn and 4 others like this.
  8. Rangerbait
    Rangerbait
    Shepherdstown, WV
    I thought about something like that too, but it's freaking wind tunnel here in the winter, and I doubt any tent-like structure would survive.
    HDRock, blacksmith, Eric VW and 2 others like this.
  9. brenndatomu
    I think you could build a quick "shed" out of pallets for walls. Even if you just put 4 pallets up to make 4 corners...maybe a couple 2x4s to tie 'em all together some how...and then some old rubber roofing or pool cover for a "roof" Or if you are feeling fancy nail a few sheets of old metal roofing on 'er (or could just buy new roofing...if you're feeling real fancy ;))
    If you shop around a lil, you can buy metal roofing for $0.50-0.60 per sq ft.
  10. Rangerbait
    Rangerbait
    Shepherdstown, WV
    Hmmm...you might be on to something there
  11. TurboDiesel
    X2
  12. wildwest
    x3
    Here it all goes into a dumpster, so keep your eye out while driving for commercial roofing going on. I'd pull over and ask for some.
  13. TurboDiesel
    Heres what i do.
    5 big skids (5'4" square)
    Holds 3.25 cords (about 1 years worth for me.
    Used rubber screwed down to skids on the ends and into the ends of 3 splits along esch side with deck screws and fender washers.
    Chaz, Ashwatcher, VOLKEVIN and 10 others like this.
  14. HDRock
    You could throw a pallet or a sheet of OSB on to keep from sagging in the middle and just tarp them.
    Put some 8d nails in bottom splits to attach rope or bungees to the tarps , I us rope with nails in the pallets , I tie an adjustable hitch knot that you can slide and tighten or loosen up.
    I use these Tarp Tie-Downs now, they work the best ,they will not come off. Don't get the black clips in the pic they don't hold as good
    Could do this to I guess
    FatBoy85, Lucy, Timberdog and 8 others like this.
  15. justdraftn
    justdraftn
    On the road
    I use the ever popular scraps of chip board, dipped in Thompsons Water seal and screws.
    I know these won't come loose.:cool:
  16. Rangerbait
    Rangerbait
    Shepherdstown, WV
    I think I've decided based on your post...I'll take four 12' 2x4s (HH are 12' in diameter) and make a tic-tac-toe grid, then use OSB to make a sort of lid. Then I'll cover it in a 20x20 tarp, and tie off with a trucker's hitch around the base. When I need more wood, I'll take the tarp and lid off, then just remove as many layer of the HH as I need.
    Thanks for the spit-balling, fellers!
  17. Mirkwood Jim
    Mirkwood Jim
    Devon, England
    I've just picked up a load of galvanised roof sheets, some were free as I helped removed them, others I paid £5 per sheet (2.5m x 1m) for. I figured it was worth the investment as I'll be able to top cover all my stacks and they'll last a fair time :)
  18. Rangerbait
    Rangerbait
    Shepherdstown, WV
    I ended up just deciding to use the garage as a month's worth of wood storage, and leave the Holz Hausens just out in the elements. I've been burning about a cord/month so far based on my calculations, but expect that to pick up a bit if it ever gets cold this season.
    Timberdog, Horkn, Duvekot and 2 others like this.
  19. Reddingnative
    Reddingnative
    Hornbrook, CA
    Woah?! Someone stole everything out of your garage. Seriously where do you put all your uh... "Stuff"?
  20. Ejp1234
    Ejp1234
    MD
    I have a "drying rack" i built, it holds a cord... My stacks stay in the elements..
    I have a 1 cord rack in the house garage I fill up from drying rack, and then restock the drying rack. Basically 1mo's supply for me. Any residual moisture they get from being in elements is well dried off for the 1mo they are in the drying rack.
    The drying rack is basically a smaller wood shed... I do plan on building a 4-5cord wood shed this spring.
    Horkn and Rangerbait like this.
