Kitchen Remodel (And Not Quite Dead Yet)
Discussion in 'The DIY Room' started by Garry Polmateer, Aug 13, 2017.
  1. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Got the trim up on the back window and back door finally. Panel installed around the quad gang switch... then I heard the call of the wild....
  2. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    That's the plan! My son is 4 and daughter is 2 and we're not moving until they're done with high school!
    G
  3. Jack Straw
    Jack Straw
    30 miles west of Albany Ny
    You should be very proud! You do excellent work.
  4. brenndatomu
    Took the words right outta mah mouth!
    You guys have a great eye for design...looks like a showcase house! :yes:
  5. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    You are too kind! We spent a year and a half planning the project, I'd like to think anyone could do the same with investing the time. Learned a ton! Thankfully we headed off the worst of the mistakes in the planning phase. Only real unanticipated item was that there was a vent pipe in a wall that we had to move and unrelated - our hot water heater died about halfway through the project, go figure.
    The last pics I shared are last weekend - almost caught up to the present! Then progress will be a bit slower as I work through the remaining punch list and split my energy between that and firewood. (no pun intended hahah)
    Bathroom is next!
    Garry
    HDRock, Woodwidow, bogieb and 5 others like this.
  6. Eric VW
    Definitely see a spot for a big ol' FHC decal.....
    :thumbs:
  7. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Bwahahahaha!
  8. cnice_37
    cnice_37
    You have no fear of the unconventional, and you pull it off in all your pics of the place. Nice build, well thought out, and obvious pride in what you do.
    What design SW did you use in that first post showing the 3D concept??
    bogieb, Eric VW and Well Seasoned like this.
  9. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    I have no idea - I hired a designer to do layout, it wasn't cad, wasn't sketchup, something else...
    cnice_37 and Eric VW like this.
  10. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    Thanks so much for the compliment - this is the 10th place that I've lived. Learned a lot fixing up the previous 9 residences and I'm trying to do it once, and do it right!
  11. lukem
    I'm a big fan. I designed my kitchen using it. Like you, me and the wife had umpteen bazzilion hours of planning involved. No regrets so far.
  12. Woodwidow
    What an awesome project and the results are spectacular. Thanks for sharing the journey with us.
  13. Stinny
    Very impressive work Garry Polmateer... enjoy the fruits of all that effort... :thumbs:
  14. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    More likely to enjoy the "Meats" of my labor... :)
    Thanks!
  15. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    I still have a few more updates and then I'm caught up to present day!
    Eric VW likes this.
  16. Woodwidow
    I am looking forward to the panoramic pictures of the finished project.
  17. Boogeyman
    Boogeyman
    Central Indiana
    That hood is fantastic! Two of my favorite things together right there, wood and copper!
  18. Garry Polmateer
    Garry Polmateer
    Alplaus, NY
    It was my wife's idea! But I'm a fan too :)
    Garry
    Eric VW, bogieb, Boogeyman and 3 others like this.
  19. eatonpcat
    That is awesome!!
    Eric VW likes this.
  20. chbryson
    chbryson
    I am going to guess either 20/20 Design depending on the cabinet brand you used (most cabinet manufacturers support this program with their products) or Chief Architect. I'm leaning towards the CA looking at the graphics.
    I was glad to see the thread about makeup air. I was going to tell you that in the end but you knew what you needed. I try to tell customers when I do a kitchen that if you have a big stove, you need a big vent, and when you do a big vent, you have to replace all that air you are sucking out of the house. I had a job that the contractor didn't do makeup air and the homeowner thought there was something wrong with their old hot water tank because the pilot light was going out. The vent was drawing so much air that it was sucking the pilot light out in the basement of the house. Now that contractor knows that big hoods need new air.
    Very neat building in the old pantry cabinet and and the hood. I've done the glass block before and as you well know, it is amazing how much stuff is in the walls that needs moved somewhere else and that turns into quite the project in itself on where to put it all so it looks decent in the end.
    Eric VW, Garry Polmateer and bogieb like this.
