  1. Stinny
    Monin... :coffee::coffee:... music day today. Gonna burn some lard off this ole man's azz... :rootintootin:
  2. Chvymn99
    My lot wasn't marked (1950). Just went off the neighbors, driveway, and an old fence line (at the end of the day wasn't totally correct). Till I had to build a fence on one side, then I hired my buddy and his coworker to mark my property. Wow, that was interesting for the land pin locations that they had to find to go off of.
    If yours is newer lot a metal detector could find them. Especially if you know one of your neighbors pin location and can give you a area to measure off of (assuming lots are fairly cookie cutter sizes).
  3. Pallet Pete
    Pallet Pete Moderator
    Ovid
    The wife loved them!!! So good apparently. :D:thumbs:
    Horkn, Backwoods Savage, Thor and 4 others like this.
  4. bogieb
  5. Stinny
    x2
  6. Eric VW
    X3:)
  7. NortheastAl
    NortheastAl
    Putnam County NY
    X4
    Horkn and Woodwidow like this.
  8. yooperdave
    Gonna rummage through an old outbuilding today to see if there is anything I want from it. New owners want it empty.
    Its raining anyway, no wood trip today. Sooo.....
  9. Stinny
    Good huntin'...
  10. scavenger
    scavenger
    saybrook township ohio
    What did that cost you as I remember my Pittsburgh neighbor having "our" line surveyed and it cost $500---then I had to move my shed---remember? (of course we do---the pallet wood challenge nobody won :(
  11. Chvymn99
    Yep... $500 dollars... plus he threw in some extra locators for me...
  12. scavenger
    scavenger
    What dat?
  13. Chvymn99
    Since my land has a slight hill too it and no direct line of sight from the two official line pins. He put a few extra "reference " in between so I could draw a straight line easier.
  14. scavenger
    scavenger
    Reminds me of how much prettier the topical map of the earth is verse the political
  15. Mastermind
    Mastermind
    Tennessee
    Good morning gents.
  16. Woodwidow
    Really foggy this morning. I am feeling old as our oldest daughter and her husband just celebrated their 20th wedding anniversary. 2oth!!! Also I have been working on the 50th celebration of our high school of which we were the third grad class from it. It really doesn't seem to be that long ago when these things happened. Of course, I shouldn't complain. Mom says that I will feel old when our oldest turns 65. That's what happened to her. I guess I have a few years to go then.
  17. schlot
    schlot
    NW Iowa
    A good metal detector should help. Survey grade stuff is a world above the typical ones though, but a regular one might just do the trick.
    Wisconsin should typically have "good" monumentation for property corners. Probably metal pins (usually cut rebar) but it may also be metal pipe, spikes or even nails. New laws dictate that property corners need to be "permanent" which would mean nails and even spikes aren't enough, but if it's never been surveyed before they still might be the monumentation you find. In some areas of the country a wood post, tree or even rocks are used as historical evidence still today.
    Word to the wise, just because you find a pin or such near a property corner, they might not actually be correct. Can't tell you how often we find erroneous evidence that we don't use because they were so badly set in the first place.
    NortheastAl, bogieb, Horkn and 4 others like this.
  18. lukem
    Two of my pins are in/under the road in front of the house. The other is a big pipe that sticks about 5' out of the ground that a cherry tree is growing into. There's probably a pin under that tree somewhere too. I have no idea where the third one is, but I have a pretty good idea where to dig if I ever need to locate it.
    Around here, they drive 3/4" x 4' pins all the way into the ground when you get something surveyed. If you want a visual marker, that's typically on you to add something yourself.
    I've seen property corners marked with Iris plants before. They live basically forever and don't migrate much, so I can see why the old timers would have used them.
    NortheastAl, bogieb, Horkn and 3 others like this.
  19. Backwoods Savage
    Such a shame. He had to get home to fire up the grill rather than drink beer. There has to be something wrong with that man... :rofl: :lol:
  20. Backwoods Savage
    Feeling old? We received a call from one of our sons today. He is 54! How did that happen?
