Gas grill burner split and broken - fix or replace grill?
Discussion in 'The DIY Room' started by don2222, Jul 25, 2017.
  1. don2222
    don2222
    Salem NH
    Hello
    This is an older Webber propane 2 burner gas grill. We just bought new 21-1/2" flavor bars.
    Now I see the crossover air tube between the front burner and rear burner is almost broken at the front burner and split in two other places! Yikes!!!
    A new 2 burner Webber is $399.00 at Lowes
    Shop Weber Spirit E-210 Black Porcelain Enamel 2-Burner Liquid Propane Gas Grill at Lowes.com
    The igniter and everything else seems fine.
    Looks like the 27" 2 burner replacement kit should work for approx $35
    Weber Grill Parts: 27" Stainless Steel Burner and Crossover Set | grillparts.com | BBQ Repair and Replacement Parts
    This grill model Genesis Spirit A cost $349.95 when we purchased about 1/16/2002 - 15 years ago. :)
    See pics
    Well Seasoned and Horkn like this.
  2. yooperdave
    Might be a quick fix for a weld shop, no??
    (ps....there's always charcoal grills!)
  3. don2222
    don2222
    Salem NH
    Good idea but so rusted not a lot left to weld?
    Well Seasoned, Horkn and yooperdave like this.
  4. Horkn
    Just get a new burner. It's easy. And cheap when you consider what a replacement new grill will cost.
    I even have replaced burners on cheap gas grills
  5. yooperdave
    Yup, did that too. Lasted another year or two......
    Horkn likes this.
  6. Horkn
    That's it huh? I got like 6 more years out of the grill on my old Aussie grill by changing the burner. I also found out over the years to use one side of the grill one day, then the next time use the other side. The grill ,and burner, lasts a lot longer then. My theory is that the grease/ oil fat etc keeps the metal from rusting.
    brenndatomu and yooperdave like this.
  7. yooperdave
    Thats probably why ....I would always use the same side....
    Horkn likes this.
  8. don2222
    don2222
    Salem NH
    Hello
    Just changed it. :)
    Only had to remove 4 screws and yanked the gas Feeder control out and then slide in the new Stainless Steel burners and connecting rod. Easy Peasy. :) Now we are cookin!
    Maybe it will last another 15 years?
    Thanks guys for your comments.
  9. yooperdave
    Hope so, right? :thumbs:
    Horkn likes this.
  10. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    I replace burners, too. The last one lasted about 10 years. They wear out but alternating burners is a good idea. As is a grill cover and just general up keep.
    The latest one I put in early this summer is all stainless except for the Al venturi.
    My cousin is a big scrapper... I was into it for a while. We both agree that grills are the #1 throwaway item of value at curbs. Most could be fixed, all have decent scrap value.
  11. brenndatomu
    Our grill was given to us by a friend that was moving and didn't want it anymore...said it was "junk" and had already bought a new one...not a darn thing wrong with it except the "new" was wore off...still usin it 8 years later (not often, but still)
    Even came with a 1/2 tank of gas and a cover
  12. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    Exactly. I don't plan on ever buying a new grill. If you ever need one for a cottage or cabin, just hit up a suburb before garbage day (gotta beat the scrappers, though).
    343amc, Horkn and don2222 like this.
  13. don2222
    don2222
    Salem NH
    I bet if you sandblasted the inside and repainted the grill with that spray grill paint you could sell it used and make some money!!
    Horkn, yooperdave and BuckthornBonnie like this.
