How to pull this recoil off.
Discussion in 'Chainsaws and Power Equipment' started by clemsonfor, Jul 20, 2017.
  1. clemsonfor
    This is my engine off my generator. Its a 10HP briggs. About 15 years old. If you need the model number i can post that.
    But my rope is worn and i shortened it before it broke. But i was going to put a new rope on it so it doent bust as i try to start it in a power outage. How do i take it off? Looks like its rivited? Do i have to drill those out to get it off?
    TurboDiesel likes this.
  2. clemsonfor
    I'm in a spot with almost no signal. I'm having getting the pic to upload.
  3. TurboDiesel
    I did mine like this guy.
    It's a really bad video but the info is good. Worked on my splitter.
    I didn't cut the metal like he did. Just bent it enough to get the knot through then straightened it back out.
    dougand3, Butcher and 94BULLITT like this.
  4. TurboDiesel
    With the rivots you need to remove the 5 screws that hold the whole motor cover on
    J. Dirt likes this.
  5. clemsonfor
    J. Dirt likes this.
  6. clemsonfor
    That's some good info I can only hope the side shaft is designed the same way and it works.!
  7. 94BULLITT
    94BULLITT
    Frederick County, VA
    Yeah do like TurboDiesel said and remove the cover/ blower housing. No need to drill the rivets.
    J. Dirt and brenndatomu like this.
  8. clemsonfor
    So can I not do like the video and cit part of the recoil cover off and feed it through? I haven even went out to look since it got dark.
  9. 94BULLITT
    94BULLITT
    FatBoy85 likes this.
  10. RCBS
    I usually drilled and re-riveted these when I ran into them, but the method in the video looks promising.
    clemsonfor likes this.
  11. clemsonfor
    That video worked like a charm. My rope was a tad thicker, even though I think it was the same size he said, it's what I had and I was going to use it anyway. I keep 3 sizes on hand. 3mm, 3.5mm, and 4.5mm. I just had to work it though the recoil and the handle a little. Did it in like 10 mins. Wy better than pulling all that mess off.
    IT worked for me!! Did just like the video! THANKS TurboDiesel !:dex::dancer::rootintootin::banana:
    RCBS, brenndatomu and TurboDiesel like this.
  12. TurboDiesel
    :yes:
    :handshake:
    RCBS and clemsonfor like this.
