Why is this chain not sharp?
Discussion in 'Chainsaws and Power Equipment' started by NBourque, Jun 5, 2017.
  1. NBourque
    NBourque
    Are u talking about the edge on the top part of the cutter?
    Shawn Curry likes this.
  2. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Mag Craft likes this.
  3. Shawn Curry
    Shawn Curry
    Western NY
    Yes; that is the business end that is making contact with the wood. It needs to be sharp like a knife. At this point any method to get you there will do. I've tried just about all of them and so far I get the best results with my Stihl FG2. But I can get them throwing chips freehand with just a round file too. Just takes some practice.
    That would be a great chain to practice on too. Two suggestions: get a new chain to compare with so you know what sharp should look like. Also take a sharpie to the cutter faces to see where your file / grinding wheel is getting to.
    HDRock and The Wood Wolverine like this.
  4. The Wood Wolverine
    I personally don't think an electric grinder is the best tool for a rookie sharpener to learn on. Just my .02
    5 degrees is splittin hairs. Won't hurt anything. BUT, I applaud you for digging that deep. I think your well on your way to doing things right, your way. Lots of great help here too.
    HDRock, Shawn Curry and Chvymn99 like this.
  5. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    After sore hands from filing I bet he will want an electric lol
    30 magazine clip on my ghost gun
  6. HDRock
  7. thewoodlands
    thewoodlands
    We have a Oregon Bench mounted Saw Chain Grinder and I hand file the chain in the woods when needed.
    When we paid to have them sharpened we only had one come back that needed to be taken back, there was no charge for them to redo the rakers the second time.
    Mag Craft and brenndatomu like this.
  8. NBourque
    NBourque
    So I just received the .325 husky roller file guide and it rides too high on my stihl RS chain. Any ideas?
  9. The Wood Wolverine
    Can you post pics of how you have it sitting on the chain? Here's mine on Stihl RS.
    If you zoom in, you can see it's Stihl chain.
    brenndatomu likes this.
  10. The Wood Wolverine
    Hard to get this phone to focus where I want it and hold the file in there.
    The guide does have a front and back. The taller end should be back and make sure it's all the way down. IF you want it lower, you could file the slot a little. I've never done it (haven't needed to).
  11. 94BULLITT
    94BULLITT
    Frederick County, VA
    What size file are you using?
  12. NBourque
    NBourque
    3/16" file.
  13. The Wood Wolverine
    That's the right size. Are you getting it all the way down into the guide slots?
  14. NBourque
    NBourque
    U can see the file is not inside the tooth.
  15. 94BULLITT
    94BULLITT
    Is the guide marked .325 or does it have a part number on it? I'm thinking it could be for 3/8LP.
  16. Nixon
    Nixon
    West Sunbury,Pa .
    Could be wrong . But I believe you have it on backwards . Note the arrows below the rollers .
    The Wood Wolverine and 94BULLITT like this.
  17. NBourque
    NBourque
    It's marked .325
  18. NBourque
    NBourque
    Either way I put it on the file does not fit inside the tooth
  19. brenndatomu
    Sounds like either the chain is not the size you thought it was? Or the file is not the size it is supposed to be...
  20. concretegrazer
    concretegrazer
    Southwest MO
    Is it .063 or .050?
    94BULLITT likes this.
