Recomendations on a new Smoker
Discussion in 'The Smokehouse' started by Randy, Apr 27, 2017.
  1. Randy
    Randy
    Chapman KS
    Hello all:
    Just wanted to see what you guys recommend for smokers brands etc.. or just build a smoke house ? If you don't mind maybe show what you use.
    TurboDiesel and Chvymn99 like this.
  2. Babaganoosh
    Babaganoosh
    Jersey Shore
    I use a pellet smoker. I can't recommend one enough. To be able to set it and forget it is what sold me. Want a little more smoke flavor and you can throw a 20 dollar smoke tube in there. Basically a mesh tube that holds pellets.
    dylskee, MikeyB, Jack Straw and 7 others like this.
  3. Babaganoosh
    Babaganoosh
    Jersey Shore
    However if you can build a smokehouse. Go for it
  4. Chvymn99
    Welcome to FHC and another Kansas Hoarder....:D
  5. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    hi Randy!! i gots lots o smoker recommends just aint gonna bust em out quite yet....what do you want to accomplish ??
    NortheastAl and Chvymn99 like this.
  6. wildwest
    x2. Pit Boss. Was not impressed with the puck feeded from Cabelas many years ago.
  7. BHags
    BHags
    Massachusetts
    I have no problem smoking with my 22" weber kettle grill
  8. NortheastAl
    NortheastAl
    Putnam County NY
    Especially if you have a Slow 'n Sear in it. Makes the Kettle an awesome smoker.
    SKEETER McCLUSKEY, BHags and FatBoy85 like this.
  9. BHags
    BHags
    Massachusetts
    a Slow 'n Sear?
  10. NortheastAl
    NortheastAl
    Putnam County NY
    BHags and SKEETER McCLUSKEY like this.
  11. bocefus78
    bocefus78
    My Weber smoky mountain is as close to a set it and forget it kinda smoked there is without going pellet or with an automated controller.
    They make them in 18 and 22 inches.
    I gave away the big offset once I got this thing.
  12. NortheastAl
    NortheastAl
    Putnam County NY
    That's what I've heard from most everyone that has one. It's one of the all time greatest smokers and always high on the ratings lists.
  13. SKEETER McCLUSKEY
    SKEETER McCLUSKEY
    Taconic Range
    randy has left the room.......
    BHags, jeff_t and NortheastAl like this.
  14. g60gti
    g60gti
    NY West
    I have a Weber kettle, masterbuilt electric, akorn, used to have a cheap charcoal box and also have a homemade UDS(ugly drum smoker). The UDS is by far my favorite. It cost me about 125 bucks to build and it cooks the best food. I use briquettes and chunks of wood, probably about 12 pounds of briquettes and 4 or 5 pounds of wood chunks. I've went 16 hours on a load like that and could have easily went 24. It's extremely fuel efficient and very good at maintaining temps. There's all sorts of plans and ideas floating around the net.
    OhioStihl, BHags and NortheastAl like this.
  15. Sean
    Sean
    NortheastAl likes this.
  16. Randy
    Randy
    Chapman KS
    Thanks
    Br
    NortheastAl, BHags and Chvymn99 like this.
  17. Randy
    Randy
    Chapman KS
    I have been using an electric smoker and I hate with a passion that thing is always broken, so I have been saving some money, but I don't know if I should get a vertical smoker like a Stump but man they are expensive. I very thankful for all you guys suggestions and advice thank you all.
  18. Chvymn99
    I've got the Oklahoma Joes from Home Depot and a vertical smoker that is heated by propane and I just add wood chips for the smoke. I'm going to make a reverse smoker one day. I've got all the metal pretty much. Just need time to weld it up. There's a thread on here about a reverse smoker and some good reading on the barrel smokers.
  19. lukem
    Weber Smokey Mountain is a high quality unit. Night and day difference between it and the el cheapo drum smokers.
    I share a brick smokehouse with my FIL. If you have the time and inclination to build one, it can't be beat.
  20. MikeyB
    MikeyB
    Long Island NY
    I have to get a smoker one day. Randy, let us know what kind you decide on.
