New project showed up - MS290
Discussion in 'Chainsaws and Power Equipment' started by Certified106, Feb 18, 2014.
  1. clemsonfor
    Didnt they tell you to plug the vent and get the green venting cap? Or was that someone else? Heck after all these vents you could of bought you a new chiacom handle off ebay! I got a new one in stock I think I have $28 in.
  2. HittinSteel
    HittinSteel
    Wooster, Ohio
    Wow is that a beauty :drool:
    I epoxied a 262XP tank vent once...... sold the saw (with an appropriate disclaimer), so I'm not sure of the results long term.
    HoneyFuzz likes this.
  3. DexterDay
    Wow.... Beautiful saw!
    Let is know if you ever want to sell ;)
    HoneyFuzz and Certified106 like this.
  4. Certified106
    Certified106
    In The Hills
    Just got home from work a little bit ago. Dumped some gas in it and it fired on the third pull and stayed running. It idles well but just like guido mentioned it bogs out and dies if you try to give it some throttle. It will sit there and idle well though for quite some time. Piston looks really good also. Can't wait to tear into it this weekend.
    HoneyFuzz, Tang and clemsonfor like this.
  5. Tang
    Tang
    North Central Ohio
    Be sure to keep us updated as you go through this saw - take lots of pictures! I'm eager to learn more about saws so I can better maintain my own and I learn a lot here from reading and watching posts like these.
    Certified106 likes this.
  6. DexterDay
    I know Guido prob tried? But try turning the H screw out about a 1/2 turn?
    Or better yet, run it all the way in (seat the need . Making sure you count the revolutions (# of turns). Till it stops. Then back the H screw out the same exact # of turns as you ran it in. Then back another 1/2 turn. Then start and try to blip the throttle. Maybe do the same with the L and back it out a 1/4 turn more.
    Scotty Overkill and HoneyFuzz like this.
  7. clemsonfor
    Is this an 029? Or a 290? It has limited screws right? Unless he pulled them already.
  8. clemsonfor
    Maybe you get 1 1/4 turns on the. Limited, I dont remember?
  9. Certified106
    Certified106
    In The Hills
    Thanks for the info, I will give this a try tomorrow if I get off in time. Sitting here right now reading through the carb adjustment section to refresh my memory. I was surprised with how easy it quickly fired up.
    Definitely a MS290 and I don't think he has done anything with the screws
  10. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    Great saw there ! Not as cool looking as the old 450 IMO Good luck fixin it up !
  11. Guido Salvage
    Guido Salvage
    The heart of the Bluegrass
    Glad the saw arrived safely. I bought this saw at least 3 years ago and put a new Stihl chain on it, replaced the clutch cover and gave it 2 new bar nuts and then ran it dry and stored it. I pulled it out a couple of weeks ago and got it to fire and idle, but it would die when it was given a substantial amount of throttle. Not having any wood here to tune it in I did not do any adjustment to the carb and sold it as is with a full disclosure of the issue. I didn't really make any money on it, but it is now in the hands of someone who will use it and it funded almost all of the cost of my new Echo 610 EVL. :thumbs:
  12. Certified106
    Certified106
    In The Hills
    From what I could find the green vent won't work on this saw. I went looking for a cheap tank on Ebay and couldn't find one...... If you have leads on a $25 dollar tank with a vent in it let me know. I already have brand new AV mounts on this tank that could be removed.
  13. clemsonfor
    What saw again 272?. The chicom tanks come with AV mounts . At least stihl do.
  14. clemsonfor
    Sorry the 272 and 372 are different tank handle. All I saw is roached out ones on Ebay.
    Here is the handle I boug Screenshot_2014-02-20-07-45-31.png ht to prove I was not exadurating . Quality is pretty good on them too.
  15. Scotty Overkill
    MS290 is a great general purpose saw.......and I'm betting a simple carb tear-down-build will solve the throttle issues. While you have it apart check the fuel and impulse lines, as well as the carb boot. I've seen saws where carb boot had a tear and saw wouldn't run right under throttle due to the leak.......
  16. Certified106
    Certified106
    In The Hills
    I believe you on the 372XP tank but I have looked high and low for a 272 tank and have not been able to find one. I keep watching for a 272 parts saw but haven't seen one of them either. If anyone notices one let me know. Also if anyone has an idea what epoxy would hold up to fuel I would appreciate the input.
  17. HittinSteel
    HittinSteel
    Wooster, Ohio
    I'm not positive, but explore the possibility that the 61, 268 have the same tank
  18. Certified106
    Certified106
    In The Hills
    Tried adjusting the carb setting and it didn't do a thing but I did notice something. When it would start and run but bog out I'm seeing fuel on the outside of the fuel line. I'm thinking there is a crack in the fuel line. Gotta get it tore apart tomorrow hopefully. Should I start a new thread with MS290 in the title so if others are searching later on it pops up? If so maybe One of the mods can just change the thread title to MS290 project or something like that.
    Chvymn99 likes this.
  19. clemsonfor
    Yep thats exactly how my 390 was when it went bad, the fuel line that is. I chased a carb for awhile and rebuilt it before I realized like you that there was girl outside my saw. Which filled me off it was bad.
  20. Certified106
    Certified106
    In The Hills
    :rofl: :lol: I literally just spit my beer across the counter :rofl: :lol:
    The girl outside your saw was opposed to where you normally kept her inside the saw? but she filled you off.........:rofl: :lol:
    clemsonfor likes this.
