Nice Find....I hope
Discussion in 'Chainsaws and Power Equipment' started by M2theB, Apr 15, 2017.
  1. The Wood Wolverine
    If the muffler is already loose, pull it off and let's have a look at the piston. Difficulties with the low side raise a flag right away on possible air leak.
    And btw, awesome score! These are my favorite home owner series chainsaws.
    Hammy, M2theB and Eric VW like this.
  2. Eric VW
    M2theB you really S. to the U.C.K. :rofl: :lol:
    :thumbs:
    Nice find tho...you'll have 'er figured out in no time:yes:
    Hammy, M2theB, Chvymn99 and 2 others like this.
  3. brenndatomu
    Sure hope it wasn't the chair that was free! ;) :rofl: :lol:
    Nice find! From what you describe I would suspect a leaking fuel line (in the tank) or maybe even leaky crank seal(s), hope not, hopefully it is just carb related...:yes:
    Hammy, Loon, M2theB and 3 others like this.
  4. cnice_37
    cnice_37
    Address the intake boot as first mentioned by MasterMech and pull the muffler check the piston for scoring.
    Before my 351 died due to the leaky clamp (Stihl intake clamp used during my rebuild) it had similar symptoms.
    Nonetheless, nice saw if you get it running proper. Good aftermarket top ends now available to turn it into a 346xp for decent price.
  5. Jnb
    Jnb
    New Brunswick
    That is a much better free saw then the one I just got, good find, and for the price you have into it right now putting a few $ into it to get a good running saw isn't so bad.
    Hammy and Eric VW like this.
  6. Warped5
    Warped5
    Northwest IN
    Hammy, cnice_37, brenndatomu and 2 others like this.
  7. M2theB
    M2theB
    Central Massachusetts
    Near minute 10:30 and on he gives a nice explanation of the issue with the clamp.
    Piston looks dirty, but not scored and the exhaust port is clean. Fuel line is in good shape. I'm going to head down the road to change to the metal clamp.
    Thank everybody and Happy Easter!
  8. M2theB
    M2theB
    I think you nailed it. Although not cracked, even when the latch is engaged there's no compression on the seal. That might explain why it will run better when I baby it and gets hot, allowing the cylinder inlet port to expand so eventually a seal is created.
    cnice_37, Hammy, MasterMech and 2 others like this.
  9. The Wood Wolverine
    All I do is cut off the plastic clamp and put on a 372 screw type metal one. Pretty cheap fix. I'll find the part number for ya.
    cnice_37, cus_deluxe, Hammy and 4 others like this.
  10. The Wood Wolverine
    So for the cost of this clamp, you'd be good to go.
  11. concretegrazer
    concretegrazer
    Southwest MO
    Nice find. :thumbs:
    Soooo did you get the chair?
    94BULLITT, cnice_37, Hammy and 4 others like this.
  12. MasterMech
    Stopped clock is right at least twice a day.:D
    cnice_37, Eric VW and M2theB like this.
  13. M2theB
    M2theB
    IMG_0443.JPG IMG_0439.JPG IMG_4087.JPG I bought the $7 clip/boot transition. I pulled the jug to deal with it and I'm glad I did. Put it all back together and it runs like a champ. Went out and got a 16" bar for it.
    It was a good find. If for no other reason than I've never torn a saw apart. Excellent learning experience and I've got another saw to boot.
    Thanks for all the help!
