Underwhelmed by my 036
Discussion in 'Chainsaws and Power Equipment' started by fox9988, Jan 9, 2014.
  1. BuckthornBonnie
    BuckthornBonnie
    Penn Yan, NY
    My non-pro 036 does not have a decompression hole. It was an original cylinder. I have seen 1 48mm (034Super/036) AM jug that didn't have a decomp hole, but Dex is right that most new AM 48mm jugs have a hole and come with a plug.
    I'm thinking that's an original cylinder, but you'll have to clean up around the base and look for Mahle or Stihl to make sure. Or you could rip it apart and see what exactly the previous owner put into it.
    fox9988 likes this.
  2. Chvymn99
    Here's what my 034 AV looks like. It's completely stock.....
    HoneyFuzz, clemsonfor and fox9988 like this.
  3. Thoreau's cabin
    Thoreau's cabin
    Vandalia, Ohio
    Kind of an old post, but it's worth mentioning, the valve core in compression testers are NOT the same as in a tire valve stem. I lost mine and put a valve core from a tire, ended up selling a motor job because of low compression. Nothing looked bad inside, rebuilt, and retested. Same low comp. Ordered correct valve stem, voila! I want to say it went from right around 100 or less, to like 180 with the correct stem. Just a FYI.
    HoneyFuzz, clemsonfor and DexterDay like this.
  4. fox9988
    fox9988
    NW Arkansas 72717
    I was thinking of this thread yesterday while bucking a 29" Red Oak with my 036. Not sure what I was thinking before. I used my 036 against my old 290, my Echo CS-510 and a friends Husq 350 recently. None held a candle to the 036, as it should be.
    The comp gauge was all original, but good to know about the schrader valves.
    Chvymn99 and DexterDay like this.
  5. komatsuvarna
    komatsuvarna
    The 036 responds well to porting. I done one and gave it some much needed help. I wasn't really impressed with mine either stock. My ported 346xp would kill the stock 036...big time.
    Chvymn99 and HoneyFuzz like this.
  6. HoneyFuzz
    HoneyFuzz
    Northeast , Ohio
    An old post for sure..but it was brand new to me today :) Interesting read !
    the GOAT and Chvymn99 like this.
  7. Hedgerow
    Hedgerow
    SW Missouri
    How well do you trust your compression gauge?
    If it idles good and runs out well, 110 may be suspect...
    How many times did you pull the saw over? Keep pulling till the gauge stops climbing.. And it's not necessary to hold the throttle open.
    clemsonfor likes this.
  8. Chvymn99
    I just got my 036 this week, finally got enough time to play with it. Wow! I was quite impressed. I'm going to do a write up later on. I'll see if I can find a compression tester to see what it's pulling.
    clemsonfor, Jon1270 and DexterDay like this.
  9. DexterDay
    I ran mine stock for 2 years. Then this year I did a Muffler mod to it. I highly recommend it. Double the stock hole opening. Then re-tune. :thumbs:
    I was impressed with it being Stock. Now it's got the Muff mod it runs much better, and now it's out for a Woods port :thumbs: Thanks Randy!
    Just got my shipping info on my 441C-M! ! Can't wait to get it back!!!! :)
    clemsonfor, MasterMech and Chvymn99 like this.
  10. fox9988
    fox9988
    NW Arkansas 72717
    Considering the saw starts, idles and runs fine (as do the other three saws tested) I suspect the gauge.
    I pulled on each saw many times, until the gauge quit rising.
  11. JRSDWS
    JRSDWS
    Central Illinois
    Just got my first 036 and it's a Pro and I must say I'm pretty impressed so far. It's a stocker but will have a Muff mod this weekend.
    clemsonfor, Chvymn99 and DexterDay like this.
  12. SawDoc
    SawDoc
    FWIW, that gauge does NOT have a Schrader valve. You want one that has a valve at the tip where it screw's into the head. Most gauges do not have them. Small engines only make 10% of the air volume that automotive engines do. The volume of the hose creates artificially low readings. I suspect that the gauge you used to get 90PSI had an even longer hose. The gauge with Schrader in the tip is required for an accurate reading on a saw engine.
  13. fox9988
    fox9988
    NW Arkansas 72717
    Makes sense, did not know that.
  14. bogydave
    036 is a 60 cc saw, to be over or underwhelmed by a mid size saw may be asking a bit much.
    036 is one of the great Stihl "Icon" saws.
    But it is a mid size , which is what made it one of the top selling Stihl saws of it's time.
    Works well with a 20" full comp chisel, it's in the mid size class of 60 cc saws like the MS362 & 562xp.
    Step into the 70 cc class, big difference, then you learn what it means to hang on :
    If you are looking for power & throttle response when in a log;
    Step up one size & you gain more than 1 full hp over the 036.
    Try a MS41 C-M Magnum, 70 cc, 5.6 bhp, then you'll be impressed by the difference. :)
    You can tinker & do some mods, but when you are done, it's a mid size, 61 cc saw.
    A great 61 cc saw though. One of the all time workhorse saws made.
    For many , the perfect saw for a serious/pro firewood guy.
    Just my 2ยข
    Chvymn99 likes this.
  15. Hedgerow
    Hedgerow
    SW Missouri
    I got a 562 that has some serious wow factor... It's only 59cc..
    That being said, the 036 can be made to run real hard too.. I ran one the monkey built, and it was a snotty bugger.. So the potential is there at least..
  16. DexterDay
    I'm hoping mine comes back Angry... Very angry.
    I have ran many 036's, a few 361's, and one 362. Out of that entire series of saws. The 036 is still my favorite. I know the Quad port on the 361 should make it run better. But all the 361's I ran lacked the Pazazz that the 036 has (dual port).
    A slow evolution of that saw, that was a hit, then seemed to lose a little, and now with the new 362C-M? Maybe it's back??
    The evolution - 036 - 360 - 361 - 362 - 362 CM. As much as I love the 036, I really think that the 362C-M will be my next saw. The Mtronic thing is really growing on me. :thumbs:
  17. lukem
    I think you should get one and report back, for the good of the site. Duty calls, Dex. Duty calls.
    MasterMech and DexterDay like this.
  18. DexterDay
    If it gets you to buy one? I may just do it... :) I know you loved your 361. So the 362C-M should fill it's shoes nicely.
  19. lukem
    If I wasn't right in the middle of remodeling my kitchen I'd be filing a full report. Need to get a couple more paychecks first. Too bad they only come once a month...:mad:
