2nd story garage
Discussion in 'The DIY Room' started by SolarandWood, Mar 20, 2017.
  1. SolarandWood
    SolarandWood
    Syracuse NY
    I am trying to come up with a solution of getting everything i own under a roof without an outbuilding on my suburban lot. My entire house originally had a flat roof - kinda dumb with ~10' a year of snow but hey. My attached garage is block on three sides with 2x10s on 12" centers with an 18' span and a piece of steel in for good measure. The deck is then tongue and groove on the diagonal. The trusses I went over it with create enough height to get my tractor in from the side (i can fill from the side street) but I am curious if this is just one of those really stupid ideas that should just be dismissed? I think the floor is good for the weight and it has a roll roof on it that is in decent shape. But, eventually, I think I am just asking for problems? Any thoughts/experiences either way are appreciated.
    TurboDiesel likes this.
  2. TurboDiesel
    I put an attic truss on my garage and gained 600 sq ft.
    Only cost like $70 per truss extra when I built it
  3. SolarandWood
    SolarandWood
    Syracuse NY
    yep, those things rock. My trusses achieved an 11' ceiling height over most of the garage, a 9' cantilevered overhang on the south side that I use for my woodshed and a perfect pitch to optimize net metering for the solar array. I always thought that a barn would be in the mix too but I'm thinking less is more now if I can make it work.
  4. My IS heats my home
    My IS heats my home
    Albany, NH
    Trusses may be the right way to go. They can be ordered for your exact specs and will be less expensive than traditional framing using 2x8/10's.
  5. SolarandWood
    SolarandWood
    Syracuse NY
    Yep I love trusses; they are already up over the garage. I originally intended to put a media room in the space but was up there yesterday thinking my tractor would fit in there with the right door and it would make superinsulating the house a lot simpler.
