How often do you clean the stove glass?
Discussion in 'Modern EPA Stoves and Fireplaces' started by saskwoodburner, Jan 17, 2017.
  1. DexterDay
    I have cleaned mine twice. Once was at the beginning of the season and the other time was around the beginning of January.
    Dry Wood and burning hot keeps it nice and clean.
    No fire here tonight as the kids are at my parents. So me and the wife went out to eat and are being lazy on the couch.
    It is a little white/tan from the ash. But you can really see the airwash path from the top to the bottom.
  2. DexterDay
    What kind of stove are you burning? And what would you consider dirty to clean it daily? Got any pics?
    Look forward to seeing your future posts!
    Welcome to FHC!! Look forward to your future posts and pics! :thumbs:
    saskwoodburner likes this.
  3. tfdchief
    tfdchief
    Tuscola, IL
    That's how mine stays so I don't mess with it. As long as I can see the fire. Chief
    M2theB, yooperdave and saskwoodburner like this.
  4. DexterDay
    Try to avoid any glass cleaner with Ammonia. It can cause the glass to get a white Haze that will not wipe away. Ever... My pellet furnace has this haze from the previous owner. Told me all he used was Windex and could never understand why it did it?
  5. DexterDay
    Yep I agree.. :) I only do it beginning of year when I take the baffle out and clean the stove thoroughly and maybe once a year after that. When it has a fire you can barely see that stuff that's on it anyways.
    Valhalla and yooperdave like this.
  6. tfdchief
    tfdchief
    Tuscola, IL
    DexterDay, beautiful hearth and stove. Chief. Wish I was there warming my back
  7. DexterDay
    Thanks bud! It's just my basement. Many don't go down there. But we like it! :)
  8. yooperdave
    I thought I had read that somewhere also (about using glass cleaner).
    Just a damp newspaper dipped into the ashes and a touch of elbow grease-if needed-always does the trick!
    And thanks for more pics of your basement.....99 is wondering why I look green!
    ohio log slayer and DexterDay like this.
  9. Kimberly
    Kimberly
    The Kangaroo State
    I spray and clean, spray and clean until the glass is clean. Then I buff it with a dry cloth making sure I have all residue removed. So far have not seen a problem but will take notice and see. I may see what else is available without ammonia.
  10. M2theB
    M2theB
    Central Massachusetts
    Very seldom do we clean ours.
    At the end of the season, so it looks nice over the summer, and then when opportunity intersects ambition. I think it's been done once since October, maybe twice.
    We use a little water, paper towels and sometimes some scotch-bride in the corners and edges where the creosote sometimes deposits.
    When it was New and were learning how to run it, that's a different story.
  11. MasterMech
    Have you tried the damp newspaper method? The vast majority of us seldom need anything more to remove the light haze leftover from fly ash. If you are getting heavier deposits then either a hot fire or razor blade will be the best ways to clean it.
    I used to clean tractor cab windows with just damp newsprint. Was always handy and did the trick cutting through all that dirt.
    M2theB, saskwoodburner and Valhalla like this.
  12. Valhalla
    Valhalla
    Essex County, New York State
    Damp newspaper, with just some fine ash does a great job on the glass.
    Adjust the moisture and ash content to suit.
    Then I toss it in the stove and light up a cold start.
  13. BDF
    BDF
    Every couple of days when burning slow and longer when burning hotter. But I cheat: I have two doors and clean the cold one that is in the laundry room :) I use a single edge razor to scrape the actual deposits off and then use Rutland glass cleaner to take off any haze, streaks and that stuff leaves something behind (silicone maybe?) that makes it really easy to clean next time. Then I swap out the doors; on an Ideal Steel the hinges are just two pins that pop up and out so I can swap doors in about 30 seconds. Then let the hot door cool and do it all over again. Makes it easy 'cause 1) the door is not hot 2) I am not working in front of a hot stove 3) there is nothing leaking into my house from a gigantic open hole while cleaning the door and 4) I can adjust the door gasket anytime if it starts to leak at all.
    Brian
  14. M2theB
    M2theB
    That's how my mother taught me to wash our window, less the ash and plus some windex.
  15. saskwoodburner
    saskwoodburner
    So again I cleaned the window (a few weeks ago, forgot to mention) but it's not looking like a whole lot so far this year. Our weather is about to change, so the stove won't be running as hard, and gross hazey glass will be the result.:D
  16. HDRock
    I like my glass clean, clean and clear all the way around, if I'm burning full loads good and hot, when it's cold, I probably won't have to do anything at all for 3 or 4 days, but if there's any at all, haze or a little bit in the corners or on the sides when I Reload, I wipe it off with a dry paper towel, usually that does the trick unless a piece is too close to the glass and poops on it, then I will use a damp paper towel and buff it with a dry one, if that doesn't get it off then I use a damp paper towel with ashes, buff with a dry paper towel and that will take care of anything I have ever had.
    A couple times a year I use Magic glass cooktop cleaner, that shines it up real nice and leaves a coating that makes it easier to clean next time.
    If you have tough stuff the magic glass cooktop cleaner will take it off
  17. saskwoodburner
    saskwoodburner
    Here's one for you FatBoy85 . Maybe in a year or two, you'll be posting gross glass photos here.:thumbs:
    FatBoy85 likes this.
  18. FatBoy85
    FatBoy85
    Washington State
    Not likely. Im too keen on cleaning ny glass and with seasoned wood for at least a year, we’ll see how it works out. Thanks Sask!
  19. Suburban wood snob
    Suburban wood snob
    Milwaukee
    Almost never. It stays clean on its own... First year it didn't, but that was usually the fault of the wood... It wasn't dry enough. Now? Never.
  20. Richcode
    Richcode
    Oceanside NY.
    anyone here know how air wash works i see a vent looking thing across the top where does it take the air from ? i would like
    to add one to the Earth stove that i have pre EPA with secondary burn that i added, metal working hobbyist here
    Thor and Marvin like this.
