Putting flue through corrugated roof
Discussion in 'Modern EPA Stoves and Fireplaces' started by accidental forester, Feb 9, 2017.
  1. accidental forester
    accidental forester
    Ireland
    We're planning on installing a small stove in our out-shed. I could use the rear flue connection, go through the back wall (also corrugated), a 90° bend and then up past eves, gutter, etc. I'd rather use the top the flue connection and make a straight shot up and through the corrugated roof. My intuition tells me I can make a fairly tight opening and silicone the gap, but I'd like a cleaner solution. Does anyone have any suggestions?
  2. Deadwood
    Deadwood
    Does this scenario assume the pipe will not be near wood truss-members or other pieces of wooden structural support?
  3. jeff_t
    jeff_t
    SE MI
    This works really well. I didn't buy it from here, I have no connection whatsoever, and I certainly didn't pay that much less than four years ago. Excel's mobile theme doesn't seem conducive to copying a link for just one item, and this place was next in the google search.
    Installation is not as difficult as it may seem. I have some good pics somewhere that I can dig up if you want.
    I used it with Supervent pipe, by the way, and the Supervent storm collar seems perfect.
    wildwest and accidental forester like this.
  4. Fanatical1
    Fanatical1
    I used something similar to this.... It bends to form around the ribs.
  5. fox9988
    fox9988
    NW Arkansas 72717
    I ran mine through the ridge cap. Cut it tight, siliconed it and put a storm collar on it. No leaks.
    I'd cut the hole tight and silicone it regardless of how you decide to do it.
    greendohn and wildwest like this.
  6. accidental forester
    accidental forester
    Ireland
    Thanks lads, all the suggestions are good. Something like the Dektite collar in addition to silicone should do the trick. There's nothing combustible along the path so should okay on that front.
    wildwest and Fanatical1 like this.
  7. yooperdave
    I would have thought that by now the manufacturers of the steel roofing would have offered something.
    Ashwatcher, Fanatical1 and wildwest like this.
  8. Fanatical1
    Fanatical1
    They sure do... Lots of options.... lots of pipes coming the metals roofs, hot water tanks, plumbing and furnace vents, etc....
    Ashwatcher, yooperdave and wildwest like this.
  9. yooperdave
    Yup. Just doesn't look and fit as well as it would on a traditional (asphalt) roof. I have used the boots as pictured above and also the standard roof jacks and they just don't fit well.
    Can it be done and sealed up to prevent leaking? Absolutely.
    Fanatical1 likes this.
  10. Fanatical1
    Fanatical1
    Yep, make sure you get one for higher heat and I also used high heat clear silicone and self tapping screws per the instructions. No leaks to date.
    Ashwatcher and yooperdave like this.
  11. J. Dirt
    J. Dirt
    There's a local stove shop here I talked to about this and he showed me a heavy lead flanged set up to form to the roof since I was looking to go through aluminum corrugated roof myself
    yooperdave likes this.
