Chainsaw Pics...
Discussion in 'Chainsaws and Power Equipment' started by the GOAT, Oct 5, 2013.
  1. chipper1
    chipper1
    Grand Rapids Mi
    I like the look of those saws anyway, but the bar and the spikes bring it to a whole different level, then put it to some wood and :Dit all comes together:thumbs:.
    I also like the workbench, very nice.
    The link says it's compatible with the wrap model, is that the same ones you ordered.
    I have that guy in my favorites for bars, one day I'll get one.
    He also has the 24" small husky mount for you guys with a bad 262 or a 2260 :).
  2. hdtoolmkr765
    hdtoolmkr765
    Kokomo, IN
    The other day I was getting a little stir crazy at home and decided to go to a dealer that I had bought some "junk" saws from in the past. Found this partially disassembled and missing clutch cover. Had a tag with "low compression" written on it. I gave the dealer his $60 he wanted for it and brought it home cause I knew I had a 390 top end on the shelf. Got it home, pulled the rope and heard a nice air leak. The decomp valve was about one thread from falling out. Took decomp out and cleaned it up good, put it back in. Fresh gas and she fired on 3rd pull. Blowing 168 on my gage, finished tearing her all apart and cleaning her up this morning, put back together and ready to roll. It also had the front screw for the top cover stripped out, so put a helicoil in it, waiting overnight for loc-tite to cure. I figure she's nice enough to put a new recoil decal on as well, so I ordered one of those.
  3. Certified106
    Certified106
    In The Hills
    What a steal! That's a great looking 390XP!
  4. The Wood Wolverine
    Steal of the year!! Way to go.
  5. skylogger
    skylogger
    Arkansas
    Yes those are the same spikes I ordered they do make a good looking saw look a little better
    clemsonfor, Ronaldo and chipper1 like this.
  6. chipper1
    chipper1
    Grand Rapids Mi
    The only bummer about them is on certain saws the shortening effect they have on the bar ends up throwing the length off a bit.
    I wish there was a 22" for the 562, but then again I run a 20 on my 044 most the time and a 24 or 28 on the 461's 36 id the 660's job.
    If I decide to fire up the 562 I have I'd like to get a little more out of it than 20-the big dawgs is all.
    clemsonfor, skylogger and Mag Craft like this.
  7. cwn877
    cwn877
    Central Pa
    You suck
  8. cwn877
    cwn877
    Central Pa
    IMG_20170207_192713.jpg IMG_20170207_192645.jpg IMG_20170207_192615.jpg IMG_20170207_192537.jpg
    Don't mind the loose chain and broken clutch cover they are old spares and thanks to hdtoolmkr765 I have a nice replacement cover and brake assembly on the way.
  9. chipper1
    chipper1
    Grand Rapids Mi
    Many would say your lucky, I would say that is the result of much hard work, way to go :dex:.
    p61 western, clemsonfor and Chvymn99 like this.
  10. chipper1
    chipper1
    Grand Rapids Mi
  11. cwn877
    cwn877
    Central Pa
    chipper1 I am building a 288 saw to play with and that's what I plan to do with the cover and use it on that saw.
  12. chipper1
    chipper1
    Grand Rapids Mi
    Is that what they really do ;).
    Sounds like a beast.
    When I was at Randy's gtg I heard something fire up and start cutting (remember this is with a bunch of saws already running, and most every one ported) and I had to go see what it was as there was no mistaking this was a bad saw, ended up it was a 288 randy had done :).
    thistle and clemsonfor like this.
  13. jfhrtn
    jfhrtn
    Wilson, NC
    I do appreciate it they are both work horses. Thank you for the links will probably make an order in the next few days. This 24" husky bar seems really heavy for its size. Wouldn't mind getting one a little more balanced. Some decent spikes would really help too
    -Rick
    T2 Tappin'
    chipper1 likes this.
  14. Huntindog1
    Huntindog1
    South Central Indiana
    I guess another angle would be if anyone has twins show pics of your twin saws.
    chipper1, cwn877, clemsonfor and 2 others like this.
  15. Casper
    Casper
    Picked these up yesterday, only one 362 runs, but barely. Not sure about compression yet. It'll give my boys and I something to do while we wait on the cylinder for the Arctic Cat ZR440 to come back from being repaired. Hoping to get at least one of each running.
  16. mdavlee
    mdavlee
    For sure a you suck deal. Wish I could stumble into one of those.
  17. Mag Craft
    It is always amazing to me what they get for those top handle saws. Good find.
    chipper1, mdavlee and clemsonfor like this.
  18. thistle
    thistle
    Polk/Guthrie Counties,IA
  19. nosurprise87
    nosurprise87
    Sounds good! Love the way it sounds idling like that.
    Sent from my XT1650 using Tapatalk
  20. cwn877
    cwn877
    Central Pa
    Like this? My two echo cst610evl twin cylinder saw
