Building an owb
Discussion in 'OWB's and Gasification Boilers' started by Dmorris, Dec 5, 2016.
  1. Eric VW
    Tapalk Pics not working
    Horkn and Thor like this.
  2. Dmorris
    Dmorris
    Terre haute Indiana
    Trying to get ready for next year when I start using this thing, have no idea how much wood to expect to burn so I am getting as much as I can IMG_0688.JPG
    Horkn, milleo and fox9988 like this.
  3. brenndatomu
    OK, that's the first two weeks...watcha burning after that?! :D
    JK :whistle: (kinda...OWB's do tend to be a lil gluttonous, Dad uses more in his OWB in a month than I do in my IWB all year, to be fair though, he is also heating much more space than me too)
    Farmchuck, OhioStihl, Horkn and 3 others like this.
  4. milleo
    milleo
    Lol...I was thinking the same thing...
    Horkn and Dmorris like this.
  5. Dmorris
    Dmorris
    Terre haute Indiana
    IMG_0702.JPG Got door frame and door welded up today, frame opening is 21"x20". Left a 2" raised area in door to add a baffle insulation, and have a 4" piece of tubing going through for my air intake IMG_0700.JPG does anyone know of a web sight or place where I could order a 120v actuator cylinder to open and close damper? IMG_0698.JPG
    Horkn, blacksmith and brenndatomu like this.
  6. brenndatomu
    People that I have seen build these in the past seem to often times use some sort of rotary actuator (whatever is "cheap" on ebay) with linkage to the damper...
  7. Dmorris
    Dmorris
    Terre haute Indiana
    IMG_0768.JPG Finally got back to working on this for a few minutes today, door is hung on the hinges, now I need to make a cap for my damper tube. IMG_0770.JPG
    blacksmith and milleo like this.
  8. Dmorris
    Dmorris
    Terre haute Indiana
    IMG_0839.JPG IMG_0840.JPG Finally got a little time to work on this again, got a lifting lug on and top cut and laid on, now just need to bolt too down, come up with a damperner control, and light a fire to check everything out, can't wait to see how it will work!
    milleo, Horkn, Brad38 and 4 others like this.
  9. Boomstick
    Boomstick Banned
    Saratoga county ny
    Electric Motors | www.surpluscenter.com
    They have weird stuff sometimes, some things are priced better than others, quality seems to vary as well.
    blacksmith, Dmorris and Eric VW like this.
  10. Dmorris
    Dmorris
    Terre haute Indiana
    IMG_0844.JPG Got door latch put on, needs cleaned up and some slight adjustment, but very happy with how it turned out IMG_0842.JPG
    milleo, fox9988 and Horkn like this.
  11. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    My central boiler unit uses a magnetic actuator to open draft door. Didn't read entire post to see if it's been said already. I like it. Seems like less to go wrong vs a motor.
    Sent from my SM-N910V using Tapatalk
  12. Dmorris
    Dmorris
    Terre haute Indiana
    That
    That is what I ended up ordering. It was pretty cheap and about as simple as I could get, and in the event of a power outage the draft door would just fall closed shutting air off to boiler
    Hydro Farmer likes this.
  13. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    Also forgot to note.... My draft inducer (highly highly recommended) is on the same circuit. When the door opens the fan comes on.
    milleo and Horkn like this.
  14. Dmorris
    Dmorris
    Terre haute Indiana
    I may end up putting a blower fan on it, want to try it out and see how it drafts and if I really need one, definitely left it easy to put one on if needed though
    Horkn likes this.
  15. Hydro Farmer
    Hydro Farmer
    Hinckley, MN
    It's just nice if you let it go too long and only have minimal coals or none and starting a fire from scratch. Not to mention wood that isn't perfectly seasoned. I swear by it. Saved my butt numerous times on ultra cold 30 below nights.
    30 Clip Magazine On My Ghost Gun
  16. Dmorris
    Dmorris
    Terre haute Indiana
    Good advise, hopefully we won't see any -30 temps here, but I just looked at blowers the other day and found one I could mount in about an hour or so!
    Horkn and Hydro Farmer like this.
  17. Horkn
    When I worked for one local company, we used these honeywell ones for high temp applications.
    Actuator Motors: Honeywell Modutrol IV Low-Torque Rotary Actuator Motors at Lesman.com
    By high temp, I mean on a Regenerative Thermal Oxidizer, or RTO. Which is essentially a blast furnace with a burner.
    Dmorris likes this.
  18. Dmorris
    Dmorris
    Terre haute Indiana
    IMG_0924.JPG Got my dampener hooked up, put ports in for my thermometer and aquastat. Getting close to wiring up temporary and letting it burn a few days to make sure all is good before insulating! IMG_0925.JPG
    Eric VW, brenndatomu and milleo like this.
  19. Gasifier
    Wow. :popcorn:
    Eric VW likes this.
  20. fuelrod
    fuelrod
    Western Maine
    I'm concerned that you won't get enough air through your 4" inlet without a good sized blower, but that's just from what I've seen and building a few smokers that don't need much air. Any up dates?
