GMC Duramax 2.8 l Diesel
Discussion in 'Chainsaws and Power Equipment' started by Unicorn1, Feb 2, 2017.
  1. TurboDiesel
    Like I said....talking :binoculars:
    Maybe it's time the Donald puts the EPA in its place:yes:
    pjcalla, basod, brenndatomu and 3 others like this.
  2. Horkn
    Pictures proving as well isn't just talking.:yes:
    The Ford designed 3.0 diesel hasn't been slapped yet, and it's been out for a while in range rovers and in other ford products outside of the USA. The 2.8 in the Colorado has been out there a little while as well, but nowhere near as long as the FCA ecodiesel or the Ford designed 3.0 diesel has, so we'll see.
    But we also said that about the 3.0 ecodiesel, and before that 3.0 Audi Porsche VW diesel that had a DEF system that we were told would be well within EPA limits. Well, you can't buy any new Audi VW TDI of any kind anymore, and VW/Audi has said that they'll never bring a diesel back to the states again. You also can't buy a 2017 ecodiesel from a FCA dealer either as sales have been halted.
    With all of the buyback program $ out there, of be nearly impossible to back track on that front. Unless Donald wants to pizz off VW/ Audi.
    I have a feeling the FCA ecodiesel might be going the same route as the TDI.
    I think there's a big reason why Ford hasn't introduced the f150 diesel yet. They are waiting to see what pans out with the EPA. They'll find out soon on the range rovers that have this motor soon enough, and since ford doesn't own Rover anymore, they are at zero liability. Just sit back and watch.
    :binoculars:
    In states and areas that have emissions testing, you can't do any of that delete stuff. If you do it'll cost you a lot more than just repairing what broke. You also can't sell a deleted diesel to anyone that will register it in an emissions county, at least here in my state, unless you want a lawsuit. As a buyer of a vehicle on an emissions county, the previous owner is liable for selling faulty/ deleted emissions equipment on vehicles.
    With all the added costs to maintain a diesel, and advancements in gas and gas turbo motors, most people would be far better off steering clear of diesels. Yes turbos on gas enginesare expensive to fix, but most diesels have those too.
    You'd have to tow a lot, to make a diesel make sense. That would eliminate any non HD truck.
    Obviously there are exceptions, and for some a diesel still makes sense, but that number of people has gotten a lot smaller with current EPA regs. We'll see what happens EPA wise, but I don't see there being much change on diesel regs in the EPA.
    94BULLITT, bassJAM and TurboDiesel like this.
  3. Boomstick
    Boomstick Banned
    Saratoga county ny
    Hopefully things do get reigned in. I think we have a fighting chance.
    I don't think Ford is just sitting back, they either have R&D and the build done or they don't. I do suppose a one year engine choice might look bad, but not as bad as not selling.
    I do lots of "tuning" deleting on road emissions is illegal......But it's totally possible and is done ALOT in emissions states.
  4. TurboDiesel
    this really doesn't apply here as this was brought on by their own stupidity/ignorance/arrogance !
    What did they think was going to happen? Nobody would notice?!?
    I'd like to say good for them, but I'm a VW diesel fan. And I'm due for a newer one. But there wont be any to be had. :doh:
    Barcroftb, Boomstick, Horkn and 2 others like this.
  5. Horkn
    The odd thing was that the 2.0 4 cylinder TDI models had no DEF system, and we were told that they were EPA compliant. They were, but only in test mode where the abs sensors noted a stationary vehicle. Aka cheat mode.
    The 3.0 6 cylinder tdi's had a DEF system, and didn't technically need a test mode cheat. Last I heard, was that they didn't actually have a cheat mode, but it all got lumped together as a "TDI problem" and everyone threw the baby out with the bathwater. We don't even know what the "fix" or buyout fit the 3.0 TDI is.
    The 6 cylinder TDI EPA non compliance is as far as we know, is the same issue with the FCA 3.0 ecodiesel. Both motors have DEF systems, and cats. It should just be a tuning issue, but we will find out what FCA faces with the non compliant 3.0 ecodiesel.
    What's interesting is that the ford designed 3.0 diesel makes more HP and TQ than the ecodiesel did. So, did FCA tune their motors to make more power to try to have bragging rights? The f150 didn't even have the diesel for purchase yet. It seems to me if that's what they did, it was foolish because there was no competition yet technically.
    Ford designed EPA compliant ( for now) Rover v6 turbo diesel is 254 HP, and 440 TQ.
    FCA 3.0 v6 turbo Ecodiesel, pre EPA non compliance figures are 240 HP and 420 TQ.
    Idk, we'll see what happens.
    One thing I did see was the new Ford/ GM co-developed 10 SPD tranny is specified for the 2018 f150 3.0 diesel that's going to certainly have well over 400 lb ft of TQ, if not the 440 or more the rover version has. It's also in the new raptor and zl1 Camaro with 640 HP and 640 TQ. That tells me it's a stout tranny.
    Barcroftb, Chvymn99 and TurboDiesel like this.
  6. cwn877
    cwn877
    Central Pa
    Build it yourself 4bts are easy to find and make run by themselves.
    Barcroftb likes this.
  7. Boomstick
    Boomstick Banned
    Saratoga county ny
    HP ratings can change significantly with better or different engine management, exhaust systems etc . Ford has been severely lagging in pcm/engine management for the past 20 years until(they had to change ) recently. So I wouldn't expect them to have the modularity between subsidiary companies that they have acquired such as range Rover.
    The 10 speeds are also not identical between Ford and gm. Cases are known not to be(no biggie) and probobly some Interals are going to be different. Along with pcm/ tuning differences the Tq ratings will be different.
    With that said, most new transmissions are impressive compared from anything 10 years ago.
    Both manufactures 6 speeds were good (GM's were better took ford a while to get them kinda right) so the 10 speed should handle the baby TQ numbers from most cars/trucks just fine.
    Barcroftb and TurboDiesel like this.
  8. Unicorn1
    Unicorn1
    Amarillo, TX
    All the 4bt I run across are from questionable sellers.
    Barcroftb, MasterMech and TurboDiesel like this.
  9. cwn877
    cwn877
    Central Pa
    Well that a whole other story.
  10. MasterMech
    I have driven a 2016 BabyMax Colorado. I was in love. Some may know I drove a mid-size pick'em up as a DD from the time I was handed my license until I bought my 2013 Silverado 1500. The four banger growl combined with the turbo is intoxicating driving around town with the windows down. And while it's no Raptor in the performance department, the unladen truck I was driving felt plenty nimble around town and on the highway on-ramps. Is it worth $40k+? Is an F350 Platinum PowerStroke worth $80k? My '05 Canyon (crew, z71, SLE) was a $30k truck 12 years ago. New prices have always been high, 2017 is no exception.
    I think these pocket trucks make great daily drivers with having some capability for the occasional Home Depot run or spontaneous CraigsList find. Perfect for us rednecks that commute to work in more "crowded" environments. Hell, I even hauled a bunch of firewood and towed some small tractors with mine. But I have always either owned an older "big" truck or had access to one.
    One word about diesels and the grocery-gettin' crowd in the full size trucks. If you want the heavier equipment for towing/hauling, you have no choice other than diesel at the moment that I am aware of. Brakes, suspension, transmissions, axles, hell even frames are sometimes different with the oil-burner option box checked. And so the occasional hauler is forced to spend an additional $xx,xxx dollars to get these items and is also forced to pay the upkeep on the diesel. Which was never cheap and certainly shows no signs of improving.
    Barcroftb, OhioStihl, rdust and 4 others like this.
  11. Boomstick
    Boomstick Banned
    Saratoga county ny
    Good Info.
    I see it as a better option for most diesel owners that want to tow on the weekends but ego rules the roost.
    For most people this would be a good weekend hauler.
    I tow more with my small SUV than just about any privately owned diesel I know.
    It would probably save me quite a bit of fuel.
    Barcroftb and DexterDay like this.
  12. Unicorn1
    Unicorn1
    Amarillo, TX
    I still have my eye in a friend's first gen Dodge 4x4 Cummins, 5 speed.:)
  13. cwn877
    cwn877
    Central Pa
    Now you're talking about a combo that's almost bulletproof.
  14. brenndatomu
    The neighbor farmer has two, a 1st gen 4x2 and a second gen 4x4, both of 'em I'm sure were sold off by the PO as "all but dead"...nope, they just keep on tickin...for years now.
  15. MasterMech
    The motors will run forever,it's just a matter of what you are willing to fix or ignore with the trucks. :rofl: :lol: Of course, up here in the NE, they are all a hobby (regardless of brand) after 15-20 years.
    Barcroftb, Boomstick, Horkn and 3 others like this.
  16. 94BULLITT
    94BULLITT
    Frederick County, VA
    That is they way it is getting here in VA. They put brine water on the roads with just a threat of a dusting of snow. Then if we get any accumulation they are out salting the roads like crazy. After the roads dry off from the snow the roads are white from salt. Most pre2000 trucks are rusted up pretty bad.
    Barcroftb and Horkn like this.
  17. MasterMech
    Can't like that. I miss driving ON snow. Love snowpack on the roads.
  18. 94BULLITT
    94BULLITT
    They plow here once the tires make a track in the snow. Last Sunday it was flurrying and I saw a truck sitting in the crossover ready to go.
    Horkn likes this.
  19. MasterMech
    Imagine the money we could save if we all learned to drive! :whistle::emptywallet:
  20. 94BULLITT
    94BULLITT
    Or if people would just stay home.
    Canadian border VT and Horkn like this.
