LG Granules Wood Pellets Review chatter thread
Discussion in 'The Pellet Bag' started by slvrblkk, Dec 29, 2016.
  1. slvrblkk
    slvrblkk
    Northampton, PA
  2. jtakeman
    Thanks Steve!!
    :thumbs: + :cheers:
  3. ttdberg
    ttdberg Pellet Pig
    CT
    X2 thanks for the review Steve!
  4. CleanFire
    CleanFire
    Nice review Steve! :cheers:
    (That's Exactly as they burn here. :yes:)
  5. will711
    will711
    Pocono Mts.
    FYI Steve ash pic looks great , I know we talked about this yesterday , looks like coffee grounds .
  6. CleanFire
    CleanFire
    x2 - that pic looks spot on. And the ash is grainy, like coffee grounds.
    The ash is heavier vs. other pellets, but on the small stove here, that's not necessarily a bad thing: the ash stays in the firebox, and doesn't get carried into the passages/venting as much, vs. other brands. * Not disputing your testing, just offering a different viewpoint.
  7. slvrblkk
    slvrblkk
    Northampton, PA
    Exactly..
    IHATEPROPANE, ttdberg and CleanFire like this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    X3...they burn well just not one of my personal favorite.....but a good pellet!
  9. vtktm802
    vtktm802
    Hyde Park, Vt
    Slvrblkk, are you taking your temperature reading at the burn pot I assume? , I am using a raytek mini temp gun
    that I use for HVAC work. Want to compare temps when I burn the Lg's and 802's. May have to consume a few
    brews for best results. :thumbs::thumbs:
  10. slvrblkk
    slvrblkk
    Northampton, PA
    No...I take it with a digital thermometer on the same place on the stove door. I haven't figured out a way to get a better reading yet but it is just a home test. I would like to get it a bit more "perfected" though.
  11. vtktm802
    vtktm802
    Hyde Park, Vt
    Rodger that, it is a digital gun......
  12. slvrblkk
    slvrblkk
    Northampton, PA
    I guess I should clarify, it's actually a thermocouple thermometer....sorry about that
    IHATEPROPANE likes this.
  13. vtktm802
    vtktm802
    Hyde Park, Vt
    So I made the trek east to the dealer yesterday and picked up both Lg's and the green mt pellets. Wow!!, I gained 10 - 15 degrees with the
    Lg's and a nice whiter flame. Burning the green mts today. Very close to the Lg's in heat. Think I will sick with Lg's the stove
    seems to like these. Happy new year to all and thanks for your input........
  14. slvrblkk
    slvrblkk
    Northampton, PA
    What is the price on those?
  15. vtktm802
    vtktm802
    Hyde Park, Vt
    Both were 5.40 pr bag or 270 a ton....
  16. ttdberg
    ttdberg Pellet Pig
    CT
    Very nice, glad to hear you got some and are liking them! Happy New Year to you!
  17. CleanFire
    CleanFire
    Burning new stock of Satisfaction ( '16-'17 ) pellets now:
    Notes:
    Pellet length is consistently longer, 1" vs. 3/4" (avg.) on old stock, and there is a greater mix of longer pellets vs. shorter ( 1/2" avg. ) in bag,
    no issues with any hopper bridging, or auger crunch on feed,
    * Ash was building up on edges of burn pot (vs. old stock settings) - had to increase combustion air RPM by (70) to keep the burn pot edges clean.
    ( No additional carbon buildup, etc. noted, just needed some more air to push the heavier ash, clear of the burn pot.)
    * Heat output is exactly the same @ 225 F / 1.6 lb/hr @ the Heat Exchange exit: no change in ash volume, or appearance: a very consistent pellet - just longer pellets, in this new batch.
  18. vtktm802
    vtktm802
    Hyde Park, Vt
    Very interesting CleanFire, a few weeks ago I bought Lg's and have been happy with the higher heat output. Then last week a local feed store
    has LaCretes. So after reading the reports on them here decided to try them. Seem to burn even hotter but a bit more ash. Cost more then the
    Lg's but saves me the 50mi round trip for the Lg's. Just my 2 cents on the LaCretes as we went back into the icebox this weekend.:thumbs:
    ttdberg, CleanFire and Russell like this.
  19. Russell
    Russell
    South Coast , Massachusetts
    X's 2
  20. CleanFire
    CleanFire
    Greetings vtktm802 , good to hear the LG's are treating you well, and we really like LaCretes here also - an excellent cold weather pellet.
    We find the same vs. the (2): LG's have less ash in appearance - but denser..,
    LaCrete's a little more ash volume, but lighter & fluffy - keeps the burn pot cleaner between stove cleanings.
    Lacretes burn 5F - 10F hotter @ the Heat Exchange exit here vs. LGs, depending on feed rate & intake air temp., which translates to using less pellets at a given feed rate. * On our small stove here, that works out to about a $15.00 differential between the (2) brands for approx. the same BTU output.
    Our situation is reverse: LG's available within 30 miles :yes:, LaCrete's are 1.5 hours away. :( ... It may be time for a road trip. :D
    ttdberg, will711 and Russell like this.
