Another homemade splitter...
Discussion in 'Chainsaws and Power Equipment' started by Deer Meadow Farm, Apr 11, 2016.
  1. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Things are looking better. My nephew has a valve rated for 25GPM he is dropping off in my truck as I type. My additions to the cylinder mount and my backing plate are complete and primered. He is bringing over his gages tomorrow evening so we can check/set all the pressure relief valves correctly and I should be good to go. Sunday splitting (weather permitting) will be the test I guess.
    Horkn, amateur cutter and raybonz like this.
  2. Kimberly
    Kimberly
    The Kangaroo State
    Sounds good, keep us posted.
  3. amateur cutter
    Not smarter than you for certain, but 10gpm max is just that. You may not notice it in performance, but any restriction leads to friction, which leads to heat, which leads to death in hydraulics. Just a thought.
    Horkn likes this.
  4. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    OK, the reinforced cylinder mount and backing plate are installed:
    I replaced the hoist valve with the one from my nephew. We set the pressure relief valves on the control valves to 2080; this was the most I could get before stalling the engine. I need to tach the engine because we both feel that it doesn't "sound" like it's running as fast as it should. Even at 2080, I am getting a true 20+ tons out of it.
    What I found when working on the valve however was that one of my tie plates broke:
    It's kind of hard to see but the weld did not fail, the plate broke. I used an old plow blade cutting edge and it must have been hardened to some degree? In retrospect, I think the "bang" I heard was that plate breaking. I bought some mild steel plate today that I hope to replace it with.
    Horkn, raybonz and blacksmith like this.
  5. Kevin in Ohio
    Kevin in Ohio
    Yes, Plow shares are hardened and snap easy. I made the mistake of using one for a wedge cutting r=edge when I was still in high school. Snapped the first time a twisty know piece put an extreme force on it. May hold an edge better, but not stress. They aren't hardened like a good tool steel because if you try to weld that stuff, the porosity and cracking is obvious.
    Horkn and Deer Meadow Farm like this.
  6. Kimberly
    Kimberly
    The Kangaroo State
    Is the 20 ton from tests or from calculations?
  7. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Calculations. 5" piston = 19.635 square inches of area times 2080 psi = 40,840.7045 pounds divided by 2,000 pounds (ton) = 20.42 tons.
  8. Kimberly
    Kimberly
    The Kangaroo State
    We need a few more formatting options, such as sub and super script. Oh well.
  9. Kevin in Ohio
    Kevin in Ohio
  10. blacksmith
    blacksmith
    central Pa
    When you get all the bugs worked out I'd like to see a video of that beast in action!
    Till then I'll wait.:popcorn: :dennis:
    Horkn and raybonz like this.
  11. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Yup, there is no way a lot of these manufacturers are getting the tonnage they claim
    Horkn, blacksmith and raybonz like this.
  12. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    I bought some plate at the metal yard yesterday. I found an 8" wide plate that I will weld to the vertical legs of the angle that make up the beam. It will be placed around 2" forward from the leg of the angle that boxes in the back and coincides with the rear edge of the tie strap that broke.
    It is long enough that it'll reach the chassis on the other side so I'll cut it flush and probably bolt it to the chassis as well.
    I also have a 4" wide strap that I plan to weld to the vertical legs of the angle that make up the beam just forward of where the strap broke. Boxing the beam in this way along with the previous upgrades to the rear cylinder mount should eliminate my issue. Question now is, where will it break next? :emb:
    Kyle Mulligan, Horkn, raybonz and 2 others like this.
  13. amateur cutter
    Question now is, where will it break next? :emb:[/QUOTE]
    Answer: You won't know till you try it.:D
    Horkn likes this.
  14. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    yup.... :tears:
    Horkn likes this.
  15. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    So, I welded those plates to the beam (forgot to take pictures) and split wood on Saturday. So far, so good! 007.JPG
    Edit: Guess you can kinda see the welds in this pic.
  16. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    Found the next weak spot.... :(
    Broken push plate 1.JPG Broken push plate 2.JPG Broken push plate 5.JPG Broken push plate 4.JPG broken push plate 7.JPG
  17. Unicorn1
    Unicorn1
    Amarillo, TX
    That's Not good.
    Horkn likes this.
  18. Canadian border VT
    Horkn and blacksmith like this.
  19. blacksmith
    blacksmith
    central Pa
    Horkn and Canadian border VT like this.
  20. Deer Meadow Farm
    Deer Meadow Farm
    Warren, MA
    No it isn't...
    Thanks Lyle! I'll figure it out...
    I'm going to try to straighten/reuse this one first. Another cylinder of this size is around $400 +/- and has the same style of attachment.
    Horkn likes this.
