how long have you been a pellet roaster?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Rich250, Dec 12, 2016.
  1. slvrblkk
    slvrblkk
    Northampton, PA
    Congrats! Good luck with the new stove!
  2. wildwest
    :dex::dancer::rootintootin::banana:
  3. will711
    will711
    Pocono Mts.
    Welcome to the other side Eric :cheers: , you know the drill pic's or it never happened :whistle:
  4. Eric VW
    Forthcoming Sir! First cut to the first burn:yes:
    I was thinking about making a mobile hearth.... thoughts y'all?
  5. slvrblkk
    slvrblkk
    Northampton, PA
    As in with casters and such on it?
  6. Eric VW
    Yes. That's the thought. 4 locking ones.
    wildwest, CleanFire, Rich250 and 5 others like this.
  7. bogieb
    Um, why? Not like you're going to have a mobile thru-hole. You probably have a good reason, I'm just not imaginative enough to figure it out.
    wildwest, Eric VW, CleanFire and 5 others like this.
  8. slvrblkk
    slvrblkk
    Northampton, PA
    Hmm, very interesting, never thought of doing a mobile one. Is it so you can cart it outside to clean easier?
    wildwest, CleanFire, Rich250 and 4 others like this.
  9. ttdberg
    ttdberg Pellet Pig
    CT
    Congrats Eric and welcome aboard the pellet train. That stove has a pretty small hopper, 25 lbs. - just want to make sure you go into this knowing you are going to have to feed it very frequently. My stoves would not last an overnight burn on that amount of fuel, especially if the pellets bridge in the hopper. Is there a hopper extension available for this unit?
    wildwest, Eric VW, CleanFire and 4 others like this.
  10. Eric VW
    Perhaps, but mainly to free up room in the LR in the off season. :D
    Thanks TTB:handshake:
    This is more supplemental/ quick heat up... our home is small, on the order of 900 sq ft. The wood stove lives in the basement, another 800 sq. ft., but we don't spend much time down there unless tending the stove.
    Don't think I've seen any sort of hoppah extension.
  11. slvrblkk
    slvrblkk
    Northampton, PA
    :thumbs:
  12. badbob
    badbob
    Congrats!:cheers: as far as the casters,I am 99% sure inspectors and insurance will say no.
    wildwest, CleanFire, Rich250 and 6 others like this.
  13. SmokeyTheBear
    SmokeyTheBear
    Standish, ME
    Oh he!! one can't have any fun anymore what is this thing called insurance and inspectors all about, never heard of them.
  14. bogieb
    Ahh, makes all kinds of sense to me now.
  15. schoondog
    schoondog
    Dutchess County N.Y.
    Sorry I didn't see this sooner. The old US Stove had no t-stat and a crappy heat exchanger . I would set the heat rate according to outside temps and if we were home or not. It was a multi feuler with a agitator in the burn pot so I could burn any kind of pellet, but the higher BTU pellet was important when it was real cold. Stove was always on, and I didn't need to touch it for the week except to dump a bag in every day. It gobbled up pellets.
    The E2 is a much better heater in that the heat exchanger is far superior. With a t-stat it is much better on pellet use. However we have to manually swipe the burn pot a few times a day or risk having a missed ignition on restart. This has happened more than a couple times over the last few years. And we have had issues with the remote t-stat and have had a few missed starts which has resulted in a cold house. Pluses and minuses with both stoves. Gotta go turn down the t-stat so I can swipe pot before I go to work !
    Doggy
  16. DexterDay
    8 years since my Classic Bay 1200...
    It has since been replaced with an Enerzone Eurostar and installed a wood stove (Englander 30-NC) a pellet furnace (Fahrenheit Endurance 50F) in my basement.
    Love my heaters!!
  17. gbreda
    gbreda
    NH
    Been heating with pellets since 2009.
    Welcome over to this side Eric VW . Interesting take on a portable setup for the off season.
    wildwest, Rich250, DexterDay and 6 others like this.
  18. Eric VW
    Sooooo... finally got the Ashley AP5710 hooked up today....pics later (no casters, temp hearth)....burned great 3-4 hours...nice heat output, good flame running Pres-to-Logs pellets.... all ofa sudden, blower kicks in weird, “E1” code starts flashing....:mad::doh: :headbang: Fire goes out.
    Need HELP!!! Please and thank you!:handshake:
    wildwest, bogieb, ivanhoe and 3 others like this.
  19. slvrblkk
    slvrblkk
    Northampton, PA
    If you check your manual, there's about 5 things to check. Did you go over those things yet?
    wildwest, bogieb, ivanhoe and 4 others like this.
  20. PelletHound
    PelletHound
    SE Ma.
