Advice on smallerish tractor for the woods
Discussion in 'Chainsaws and Power Equipment' started by basod, Dec 29, 2016.
  1. basod
    basod
    Mount Cheaha AL
    If they're anything like shoes on an old plow you'll hate em.
    A strip of old conveyor or similar material in place of the bucket blade(if not replaceable just drill/torch holes) or poor man's plow shoes countersink bolts into hockey pucks
    jtstromsburg, Dancan and mike bayerl like this.
  2. basod
    basod
    Mount Cheaha AL
    There's a lot of orange influence in my area and the used market thus has more inventory B or L series depending on how good of a deal I can find/drive for. The JD 2/3 series draw my attention but no way I'm buying new. I really just need to get on a lot a play with a few as I've been out of the tractor game for ~15yrs
  3. clemsonfor
    Don't even have a FEL, I have a box blade. And I probably would do it in my grass for that reason, my drive is deteriorating aspalt and its like one step above a gravel drive, I would just tear it upm
    basod and nosurprise87 like this.
  4. mike bayerl
    mike bayerl
    Try to find an L series for a woods tractor. Go to a dealer and compare the size/mass of the axles. A B series will do fine, but you will always be worrying about over stressing it. An L series will be better prepared for "unexpected" surprises you find all to often in the woods and much less often doing field work.
    94BULLITT, clemsonfor and basod like this.
  5. RCBS
    L also gives hydraulic ram steering.
    Plenty of good tractors out there. I like green ones, red ones, orange ones, blue ones. For woods work I personally like 30hp or better to deal with the hills. Stay clear of tier 4...dont think they have it figured out yet. Hydrostatic trans changed my life. I have an L that handles bulk of my chores. It's never asked for anything other than fluids and filters over the past 12 years. The one attachment I still covet (have box, scraper, brush hog, rake and post digger) is a forestry winch. No loader. Backhoe and sub compact have them. It's nice to be short and maneuverable in the woods. AG tires > R4.
    Fanatical1, Gasifier, basod and 4 others like this.
  6. Woodsnwoods
    Woodsnwoods
    Syracuse, NY
    If I decide to upgrade from a 3038E to a larger Deere, I will let you know. 2012 with 250 hours. Where are you located?
    Chvymn99 and basod like this.
  7. 94BULLITT
    94BULLITT
    Frederick County, VA
    A 44hp L series is a great size!
    Chvymn99, basod, clemsonfor and 3 others like this.
  8. Rusty1034
    Rusty1034
    St. Lawrence County NY
    Just to add to your burning for a logging winch- I picked up,a Wallenstien FX 110 Bush Pilot in 2015. I cant believe I ever tried cutting and dragging trees without it. My productivity easily quadrupled, with the amount of work being cut in half. Its on a big old Kubota with about 60? HP. Im thinking about getting a FX 85 to,use on my JD 4520. That will allow my partner and I to both skid logs, as our woods,time is limited to a few weeks in winter when the ground is frozen enough to get tractors into the swamp. While you are at it, splurge for the self releasing pulley that attaches to trees. It allows you to pull logs around corners !
    Anyone know of a Wallenstein dealer in Canada near Ottowa ( or close to Ogdensburg NY ?) Im wondering if the exchange rate for the Canadian dollar might make it worth my while to visit our neighbors to the north.
    basod, Woodsnwoods and 94BULLITT like this.
  9. basod
    basod
    Mount Cheaha AL
    this size/category is way too big for my needs but a very nice machine
    Woodsnwoods likes this.
  10. basod
    basod
    Mount Cheaha AL
    Alabama;) Thanks for the offer
  11. basod
    basod
    Mount Cheaha AL
    Mike I know you said you're not an expert but maybe someone can chime in and school me on where the Kubota B series depart to the L series.
    The manufacturers sure as heck don't give you any pros/cons of any of their equipment
    Woodsnwoods and clemsonfor like this.
  12. concretegrazer
    concretegrazer
    Southwest MO
    It's just the frame size. What's better just depends on your needs.
  13. basod
    basod
    Mount Cheaha AL
    that can't really be the end all be all
    as there are 2-4 different B series as well as L series
    there has to be something in the working interior that creates the step change?
  14. 94BULLITT
    94BULLITT
    The current B's are 2301, 2601, 2650, and 3350. The 2301 and 2601 are the same size, the 2301 loader does not lift as much. The 2650 and the 3350 are the same size, larger the then 2301 and 2601.
    The previous generation small frame B was 2320, 2620, and 2920. The larger frame B was 3200 and the B3000 (cab model). The B3200 was about $1000 less than an L3800.
    The B's also have a mid PTO where the standard L does not.
    Woodsnwoods and concretegrazer like this.
  15. basod
    basod
    Mount Cheaha AL
    you're mixing BX's with B's;)
    this is all maddening either way...kind of like a stihl/husky chainsaw showdown:doh:
  16. 94BULLITT
    94BULLITT
    No those are all B's.
  17. Gasifier
    basod, Chvymn99, Woodsnwoods and 3 others like this.
  18. concretegrazer
    concretegrazer
    Southwest MO
    Yes. Just look at the specs. The larger the rig the bigger the motor & stuff.
    Screenshot_2017-01-07-19-03-55.png Screenshot_2017-01-07-19-03-11.png Screenshot_2017-01-07-19-02-17.png
  19. Gasifier
    On 6 January 2017, 1.00 Canadian Dollar(s) = 0.76 U.S. dollar(s), at an exchange rate of 0.7567 (using nominal rate).
    But is the equipment built in Canada or U.S.? Duty?
  20. 94BULLITT
    94BULLITT
    The old Bs don't have position control. The new ones do.
