Least maintenance P68 , M55 or ?
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by Russell, Dec 21, 2016.
  1. Tullytown
    Tullytown
    North of Phila Eagles.
    wow.. u do like it warm.... just might do more than 3 bags a day as someone posted..
    ivanhoe, Russell and IHATEPROPANE like this.
  2. Russell
    Russell
    South Coast , Massachusetts
    Never put that much in Maybe , Maybe ! 2 3/4 bags that was the most . My heating season which ends in April 6 tons .
  3. Russell
    Russell
    It will get cooler down the hallway where the bedrooms are and I also use a small fan to help move the heat to those areas .
  4. Tullytown
    Tullytown
    don't forget that tight houses vrs drafty Not well insulated types the pellet consumption is up/down the scale.
    this time last year it was 70 degrees xmas day..
    warmer winter so i used 3/half tons..
    coldest winter and I am over 4 tons..
    ivanhoe, IHATEPROPANE and Russell like this.
  5. IHATEPROPANE
    IHATEPROPANE
    Yeah, I use the same amount!
    I guess my point is I am unsure if the cb1200 is actually too small. It doesn't sound like to me that it maxed out. Maybe close at the absolute coldest nights. But I think you are gonna see similar results with a bigger stove. Unless you don't mind it warmer downstairs and don't mind 4bags a day plus.
  6. Russell
    Russell
    My home is well insulated and pretty tight . :D
  7. Russell
    Russell
    Also I forgot to mention on those days I need to keep the office door next to the stove closed with a small wall heater on low in that room which is 25X 20 . During the day when my son is working that door is open and then closed at night .
  8. Tullytown
    Tullytown
    forgot to mention too that I always use room temp/auto with the Harman so on very sunny days my stove may shut off for few hrs at a time..
  9. Russell
    Russell
    I guess it's time to get back into almost Christmas mode . Have a great one everyone :tree:
    ivanhoe, ttdberg, will711 and 2 others like this.
  10. Tullytown
    Tullytown
    :thumbs::salute::yes:
  11. jtakeman
    You've got plenty of time to get this worked out, No hurries or worries!!
    Enjoy the season Russel! :cheers:
  12. DexterDay
    It's not that bad and takes a week or so to build up to where I think I "have" to do it. But I know they (SBI) ran around 3+ tons through these units in testing and never opened the doors. Member Fyrebug and I did a lot of talking on the Eurostar before I took ownership of this stove from them.
    All told I think I ran 5 bags through the Enerzone this year. Last year maybe a half ton? Now that I have been using the On/Off function of the furnace (first 3 years I only ran it below freezing). I honestly haven't ran the Enerzone since the beginning of November. Last year was the 1st season I used On/off and that was because my BIL ( chbryson ) used it all the time (was his only source of heat).
  13. chbryson
    chbryson
    Just switched it back to fuelmizer today before I left for work with it being warm and rainy. Also haven't cleaned it in about 3 weeks, just dump the ash pan and pull the scraper for the heat tubes and add pellets.
    IHATEPROPANE, Russell and ivanhoe like this.
  14. ivanhoe
    ivanhoe
    Northern Ontario
    You must of updated your control module:whistle:
    ttdberg, IHATEPROPANE and Russell like this.
  15. DexterDay
    I did a quick clean a month ago (just the pot) and a deep clean 2 days ago before the cold set in.. They really do run well without any maintenance. I've gone about 2 months in the past without doing anything other than emptying the ash pan.
    His furnace is pretty much the same as mine (newer pot, LED control board, updated combustion blower and impeller, sail switch, etc). Plus I did the burn pot mods as well as some other things he did.
    Being my Brother in law. I tend to help him out :) My whole family (wife and kids/kids slept in the living room and we stayed in the guest bedroom) spent 2014 Thanksgiving at his house so that I could help him install the updates and get it to where it needed to be.
    Here is the bigger impeller (Huge help/11 HUGE blades). The one on the far left that's really small is the stock one for Fahrenheit (13 blade but small blades). The middle one is a Quadrafire impeller (11 blades and a good improvement but smaller than the Don2222 upgrade) that I installed before the larger one on the right. This final impeller has done a world of wonder for my burn.
    The only thing that he has I wish I had? Is the extended hopper. In shoulder months? I can go 2-3 days without even looking at it. On cold days (today) I came home and it was running out of pellets (flame was almost out). Where he can still go 2 days.
    His furnace.. And a huge hopper
    My furnace.. and a small hopper (117 lbs which is still big by most standards)
    Bags, ivanhoe, Russell and 4 others like this.
  16. Lousyweather
    Lousyweather
    do you know if your efficiency took much of a hit putting that offspec impeller on? Possibly the original was undersized, I have no data on that, but have to assume it was engineered and tested with that impeller. Putting an impeller on with larger fins, at the same RPM, would move more air, possibly putting more heat out of the pipe rather than onto the heat exchanger.
  17. chbryson
    chbryson
    I broke down and cleaned the stove Saturday morning. I woke up to a 59 degree house as I forgot to load pellets for a few days. About 10 mins and I was back up and running all cleaned up and reassembled. About an hour and change later right back to 70 deg. I think I forced around 5 bags give or take in the hopper and we are good to go.
    eatonpcat, will711, ivanhoe and 5 others like this.
  18. ttdberg
    ttdberg Pellet Pig
    CT
    :heidi:
    :thumbs:
    ivanhoe, slvrblkk, Russell and 2 others like this.
