Ups battery backup
Discussion in 'Pellet Stoves, Pellet Fireplaces, Pellet Furnaces' started by corkman, Nov 15, 2016.
  1. corkman
    corkman
    Southeastern mass
    whats everyone using,recommend and where did you buy and how much should I spend. I need 2. Post a pic if you can
    ivanhoe, slvrblkk, Rich250 and 2 others like this.
  2. IHATEPROPANE
    IHATEPROPANE
    This is what I have and would recommend to anyone. The 1500 unit runs my stove for about an hour. The 1350 runs it for 40 min or so.
    They often go on sale. I bought my 1500 for like $130 last year.
    UPS System - CP1500PFCLCD | CyberPower
    ivanhoe, slvrblkk, Rich250 and 3 others like this.
  3. ttdberg
    ttdberg Pellet Pig
    CT
    We have the same units thanks to the advice from IHP. Got one for each stove and this our first season using them. Have not done a test yet to see how long they will last. They usually sell for $214-ish but we got really lucky and scored them on sale for $140. As a backup to these we also have a Champion 3100 inverter genny that has been tested successfully to run both stoves and both fridges at the same time. Just don't plug in a coffee maker LOL.
    ivanhoe, imacman, slvrblkk and 2 others like this.
  4. slvrblkk
    slvrblkk
    Northampton, PA
    APC SMX1000 free from work but looks like they are around $500. Works great on my Quad. I'm cheap, if I had to buy one I wouldn't spend this type of coin on one.
  5. wildwest
    I bought the CyberPower one too. Since Black Friday last year when IHATEPROPANE posted the sale link, I have seen the good one on sale a few more times. Whatever you buy this is the right time of year to do it, maybe wait another week or two too.
    ivanhoe, ttdberg, imacman and 2 others like this.
  6. slvrblkk
    slvrblkk
    Northampton, PA
    When I run on generator, I have to use this TrippLite...the APC doesn't like the generator power. I don't leave the TrippLite out all the time because it's too loud in the living room (fans running)
  7. wildwest
    We had to bypass the CyberPower last time we used the generator, the stove errored out with it.
    ivanhoe, ttdberg, slvrblkk and 2 others like this.
  8. IHATEPROPANE
    IHATEPROPANE
    So the Cyberpower thought the power from the genny was fine but the stove didnt?
  9. wildwest
    Yes, no error code on the UPS that I saw, and error code on stove was "reverse polarity" but the stove ran fine on a direct connection.
  10. IHATEPROPANE
    IHATEPROPANE
    That's very strange....did you try it again to see if you could duplicate the error message?
    ivanhoe, ttdberg and slvrblkk like this.
  11. ivanhoe
    ivanhoe
    Northern Ontario
    Are you looking for long/short periods of time is the question needed to really decide on what to get. I've built my own because I used to work 12hr shifts and needed time to get home and fire up the genny for even longer stints! Had to buy a CyberPower 1500 to rectify a Fahrenheit finicky shut-down mood swing as being a manual light model. Both stoves are provided UPS but not at the same time, inverter on the small side but I never really tried. The Fahrenheit wasn't in the cards at the time of putting a UPS system together. I did try the coffee maker but no dice:( They use a bit of wattage.
  12. IHATEPROPANE
    IHATEPROPANE
    Cyber Monday Amazon deal. $129 for the 1500
    imacman, Pete Zahria, ivanhoe and 4 others like this.
  13. CleanFire
    CleanFire
    Thanks IHP ! :yes:
    imacman, ivanhoe, bogieb and 3 others like this.
  14. badbob
    badbob
    So I gather using this ups,with the clean sine wave,defeats the Harman shut down mode,only allows the stove to run a bit longer?
    imacman, slvrblkk, CleanFire and 2 others like this.
  15. IHATEPROPANE
    IHATEPROPANE
    That's what I would gather as well. I bought mine (no Harman)so I would have time to set up the generator if I was actually home and I lost power. Otherwise, they would just burn out and restart when power comes back. I have had small blips of power loss, and the stoves just keep chugging along.
  16. ivanhoe
    ivanhoe
    Northern Ontario
    Also on Amazon.ca at $155.00 for us Canadian folks!
