Making progress on the McCulloch BP-1, but I need some parts....
Discussion in 'Chainsaws and Power Equipment' started by Scotty Overkill, Nov 15, 2016.
  1. Scotty Overkill
    I'm making some big leaps with this once-seeming impossible build.......I'll do a full thread detailing the entire project once I get it closer to finished. So far, I've got the pistons and cylinders ready to go, the case, crank, rod bearings and rotating assy ready,to go, NOS piston rings, new crank bearings, new crank seals, NOS air filter, and a carb rebuild kit in the works......now I have to do some body work. First off, which one of you guys can do some TIG welding on my magnesium parts? Nothing major, just some very basic repairs.....
    Second, does anyone have any parts for these saws that they'd either sell me or at least donate for a spell? I need to make a mold to re-cast a bar cover for my saw. It's the only major part that is missing. And if anyone has an original carburetor they'd part with (or if you know of anyone who does have the parts), please let me know.....
  2. Boomstick
    Boomstick Banned
    Saratoga county ny
    Good luck! Sounds like you are having a good time:bug:
    I have never seen a pb-1, but I don't actively scrounge eBay or the likes though. But I'll ad it to my search list!
    Post pics or description of the needed part that needs to be welded. Was it exposed to oil?
    clemsonfor likes this.
  3. Scotty Overkill
    yes the parts were exposed to oil, but I'll make sure they're media blasted and as clean as possible before any welding attempt....
  4. Boomstick
    Boomstick Banned
    Saratoga county ny
    Cast magnesium is porous, no matter how clean it is there will still be inclusions in the weld due to it being porous. It will bubble fizz and pop.
    Depending the part and how structural it needs to be and how hard the part is to find or replace, should depend on skill the welder as well.
    Some castings weld really well others don't.
    If you can't find anybody let me know, I'll look at it. If I can't do it("properly" anybody can melt it together), I know somebody who has oodles of experience with that stuff.
    I don't weld every day anymore my skills are waining otherwise I'd say send it here.
    clemsonfor and Scotty Overkill like this.
  5. Scotty Overkill
    These parts are nearly impossible to find. The areas needing repair aren't too crucial, I'd REALLY like to find someone with casting experience that could make me some replicas....
    clemsonfor and SKEETER McCLUSKEY like this.
  6. Redneck
    Redneck
    Burton mi
    Scotty
    Have you checked into the diffrent types of jbweld i used it on a cracked block for my truck and it held for another 90,000 miles before the frame rusted out. The motor was still running when i scrapped her out
    Scotty Overkill and clemsonfor like this.
  7. Well Seasoned
    Pa precision cast parts if you cannot find anyone else. They do good work, couple hours east of you
  8. clemsonfor
    Is a magnesium welder
  9. Mag Craft
    Yes this is true I have welded up a few chainsaws here and there. I did not know you knew that clemsonfor.
    Hence the name Mag Craft.
  10. clemsonfor
    I read more than one may realize. ;)Short term I have a pretty good memory. I knew that was the reason for your name.
  11. Mag Craft
    Then you know that my name on some other sites is 3000 FPS.
    Well Seasoned likes this.
  12. Scotty Overkill
    Would I be able to get your talents for my project? I'll take some detailed pics of what I need done, and I'll compensate you for your work......
  13. clemsonfor
    Yep.
  14. clemsonfor
    Wrong person, buddy! haha. I don't think my good short term memory will help much on this project ;).:rofl: :lol:
    You meant to quote Mag Craft one post above mine :D
    cnice_37 and Scotty Overkill like this.
  15. Scotty Overkill
    Thanks, Clem. So Mag Craft, would I be able to get your talents for my project? I'll take some detailed pics of what I need done, and I'll compensate you for your work......
  16. Mag Craft
    Take some pics so I can see what you need done. I never charge for what I do. I just like seeing the saw when it is complete.
    If you need some pics of my work I can post a few.
  17. Scotty Overkill
    There's a Crack in the back of the gas tank, part of the front handle mount is broke off, a small chip put of the top cover and a chunk out of the bottom.
    The handle mount is just a matter of building up layers of magnesium, I'll shape it to fit when I get it back from you.
    I'll media blast all areas that need repair, and get them as clean as possible for you.
    I'll get some pics this evening.
  18. Mag Craft
    I would prefer to do all the shaping myself. That way if more welding is needed I can take care of it right then and there. I just need to have all the parts that fit together so I know that they are welded together correctly. Blasting all the parts is good and really helps a lot.
  19. Scotty Overkill
    OK buddy, I'll get you some pics and descriptions this evening. Thanks a million!
    Mag Craft and clemsonfor like this.
  20. Unicorn1
    Unicorn1
    Amarillo, TX
    Any other vintage Mac that shares the same parts?
